AIR for IOS not launching CS6 or CS5.5
May 21, 2012 2:54 PM
Tags: #air #flash #ios #5.5 #cs6 #palette
I am trying to select Air for IOS and nothing happens. All other palettes seem to work correctly. I own CS 5.5 and have the same problem. I downloaded CS6 trial to see if this problem still exists and it does. Any ideas?    MAC OSX 10.6.8
    May 21, 2012 3:36 PM   in reply to printfactory21
    Have you the p12 and the mobileprovision files?
    May 22, 2012 1:56 AM   in reply to printfactory21
    Hi ,
    Can you check whether you have the latest AIR SDK installed. Ideally this will be present in the "<Flash Installed Directory>/AIR3.2"
    To overlay the AIR SDK you can check this link : http://helpx.adobe.com/x-productkb/multi/overlay-air-sdk-flash-profess ional1.html
    It could be issues with an older AIR SDK and targetting a newer iOS.
    Let me know if this solves the issue.
    Thanks and regards,
    Sudeshna Sarkar
    Adobe Flash Professional Team.
  • kglad
    Jul 21, 2002
    May 15, 2013 6:13 AM   in reply to printfactory21
    attach a screenshot that shows what your clicking and a screenshot that shows the result of your click.
  • kglad
    Jul 21, 2002
    May 16, 2013 9:24 PM   in reply to printfactory21
    re-install flash cs6.
    if that doesn't solve the problem, contact adobe support: http://www.adobe.com/support/chat/ivrchat.html
  • kglad
    Jul 21, 2002
    May 22, 2013 4:09 PM   in reply to printfactory21
    i think tech support misunderstood the issue.  they may have thought you were describing an issue with an air app installed on an iOS device
    you have an issue with adobe flash pro installed on a mac.  they still may not be able to help but they do offer support for flash pro cs6 on macs.
    anyway, you should uninstall flash cs6, run the cleaner (http://www.adobe.com/support/contact/cscleanertool.html), restart your computer and then reinstall flash cs6.
