How can I read CPI files?
May 21, 2012 4:18 PM
Tags: #avchd #premiere_pro_5.0 #cpi_files
I need help!
I regularly transfer and edit (with CS5 PrPro 64-bit) the MTS files from the HS card in the Panasonic AG-HMC150P camcorder. Recently I needed some clip information that are stored on the same card in directory PRIVATE > AVCHD > BDMV > CLIPINF in files consecutively numbered from 00000.CPI. I couldn't find any way to access those information, even after extensively consult Adobe help files and the U2U forums, and also the Internet. (I read some comments as to Premiere Elements 10 and Premiere Professional CS6 can do this - but I have PrPro CS5.)
Thank you very much,
Laci.
    May 21, 2012 4:56 PM   in reply to LaciG
    You don't.  Hardware and software that needs them does.
    What do you suppose they contain that you need?
    May 21, 2012 5:15 PM   in reply to LaciG
    From the Project Window
    Open the Metadata Display in Premiere.
    Go to the Exif section and choose what you want it to display in the columns.
    May 22, 2012 6:45 PM   in reply to LaciG
    I couldn't find the way to import the metadata.
    You don't.  Like I said earlier, the hardware or software will make use of those files as appropriate, not the user.  If PP is showing nothing in those fields, then it's very likely there is nothing in those fields.  Just because they're their doesn't mean every camera will make use of them.
    Jun 27, 2012 7:46 AM   in reply to LaciG
    Hi LaciG and thanks for posting your findings. I have a Panasonic FZ150 that records AVCHD and has all the same folders. I wanted to copy videos into differnt storage folders on my PC but did not want to loose anything. In your item#1 above, you say it's important to preserve the file [folder?] structure. Yet in your item#3, you belive there is nothing useful in the cpi files. Anyhow, based on your understanding, could I just store the mts files by themselfs (discarding everyting else). Then when I needed to access the video, just insert the single mts file into a mock directory structure? Certainly storing a single file for each vid would be easier.
    Jun 27, 2012 1:58 PM   in reply to b6878
    It's not a good idea.  PP works best when you keep everything as is.
    Jun 27, 2012 2:01 PM   in reply to Jim Simon
    Ok, thanks. Better safe than sorry.
