According to the SDK doc page 117 on presets, you're supposed to install to "App installation path" but I can't find a reliable registry entry that indicates what it is.
Premiere Pro presets
[App installation path]\MediaIO\systempresets\[exporter subfolder]
I did find...
HKEY_CURRENT_USER\Software\Adobe\Adobe Media Encoder\[version]\AMECodecCache\64\en_US\AppRoot
and..
HKEY_CURRENT_USER\Software\Adobe\Premiere Pro\[version]\AMECodecCache\64\en_US\Default\AppRoot
and...
HKEY_CURRENT_USER\Software\Adobe\CommonFiles\Usage\Agent
What is the correct way to detect the installation path?
What if the user has CS5 and CS6 installed?
What if the user doesn't have en_US installed as the language?
Is it really a common preset system for CS5 and CS6 as the doc suggests or do you have to put it in both PPro and AME?
thx
Rallymax
I should put a link from page 177 to page 35 on plug-in installation. There it gives the Premiere Pro app path you’re looking for:
Presets and editing mode XML files are loaded from the application-specific folders, not from the
common location. On Windows, the root path for Premiere Pro is in the registry at
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\
Adobe Premiere Pro.exe. Then, just add the proper subdirectories.
For sequence presets:
\Settings\SequencePresets\[Your specific folder]\
Editing modes:
\Settings\Editing Modes\
Sequence preview presets:
\Settings\EncoderPresets\SequencePreview\[Your editing mode GUID]\
Encoder presets:
\MediaIO\systempresets\[Your exporter folder]\
Unfortunately there’s no Media Encoder app path given. I’ll log a bug if you’re interested.
However, now that the AME team has added the new Preset Browser for CS6, that info on installing the presets in a separate location for each app for better performance may no longer be relevant. Installing to the shared location here…
[User folder]\AppData\Roaming\Adobe\Common\AME\[version]\Presets\
might be fine and quite a bit easier.
That App Path Registry Key doesn't really help since you can't install, as you say, to the AME MedioIO too.
I'll use the User Key for now since I can detect CS4.0, 5.0, 5.5 & 6.0 and give options as to whether you want the plugin installed in each version you currently have installed.
please add a bug incident requesting registry keys for all the installation locations - and as noted previouly, not just for the current version - because LOTS of people use version x and x-1.
North America
Asia Pacific
