You can now find new versions of our XMP SDKs on Adobe Devnet:
http://www.adobe.com/devnet/xmp/
So please check out the CS6 versions of the SDKs and post your feedback in this forum!
The prior versions are still listed.
Updates:
The Adobe XMP Team
i used the previous version of the java XMPCore. I tried to upgrade however i got the following exception (using java 1.5 and 1.6):
java.lang.AbstractMethodError: javax.xml.parsers.DocumentBuilderFactory.setFeature(Ljava/lang/String ;Z)V
at com.adobe.xmp.impl.XMPMetaParser.createDocumentBuilderFactory(Unknown Source)
at com.adobe.xmp.impl.XMPMetaParser.<clinit>(Unknown Source)
at com.adobe.xmp.XMPMetaFactory.parseFromBuffer(Unknown Source)
On further investigation the problem is, that you are trying to call a method
factory.setFeature(XMLConstants.FEATURE_SECURE_PROCESSING, true);
on an abstract class however you are not catching that error, as you propably intended to.
The code has been introduced into the new version:
class XMPMetaParser.java:
try
// honor System parsing limits, e.g.
// System.setProperty("entityExpansionLimit", "10");
catch (Exception e)
// Ignore IllegalArgumentException and ParserConfigurationException
// in case the configured XML-Parser does not implement the feature.
The exception is of the type "Error" and thus won't be catched by the "catch (Exception)" block at this point. If you change the following to:
try
catch (Throwable t)
// Ignore AbstractMethodError, IllegalArgumentException and ParserConfigurationException
or to
try
catch(Error e){
// Ignore AbstractMethodError in case there is no implementation at all
catch (Exception e)
Everything is working as aspected again...
North America
Asia Pacific
