For Loop Problems?
May 24, 2012 2:28 AM
For Loop Problems?
I want to write a simple conditional statement
in which a button moves to a certain group of frames when clicked depending on its current frame. This is the code I'm using.
var group1:Array=["b1","b2","b3"];
var group2:Array=["b12","b22","b32"]
mainbutton.addEventListener(MouseEvent.CLICK, buttonflash)
function buttonFlash (e:MouseEvent)
     for (var i:uint=0; i<group1.length; group1++)
    {if
       (e.target.currentLabel == group1[i])
       {e.target.gotoAndStop(e.target.currentLabel +     "2")}
    else
       {e.target.gotoAndStop(e.target.currentLabel.slice(0,2))}
However, when I include the for loop in the function, it causes the function to run the number
of times of the variable. In testing, I switched out the else statement with a trace string and the string showed up in the output window three times.
When I place the for loop outside of the function, the output compiler says the variable is undefined. Any ideas as to what I'm doing wrong?
    May 24, 2012 3:00 AM   in reply to witherton
    it should be i++ not group1++
    May 24, 2012 5:24 AM   in reply to witherton
    start with i = 0 then while i is less than the length of the array group1 do something andthen add 1 to group1
    this makes no sense
    you need i++ so increases and the i<group1.length will eventually equate to false
    changin group1++ to i++ may not solve the problem but it's definately a correct change
    I am suprised group1++ even compiles
