• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
problem
Engaged ,
May 24, 2012 May 24, 2012
last time sinious help to me.
i using that script with little changes.
if i add "Kbps" in that bandwidthHandler my tests failing.
if i remove 'Kbps' that working good.
function bandwidthHandler(e:AppEvent):void
  downSpeeds.text = e.params.bandWidth +"Kbps";
  downTest();
function downTest()
if (Number(downSpeeds.text) >= 512)
  Pass.visible = true;
  Fail.visible = false;
else
  Pass.visible = false;
  Fail.visible = true;
TOPICS
ActionScript
Views
1.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , May 24, 2012 May 24, 2012
Your problem is adding a string to a number and trying to compare it as a number...
Try passing the e.params.bandWidth as an argument to the downTest function instead of using the textfield.
  downTest(e.params.bandWidth);
function downTest(dnSpeeds:Number)
if (dnSpeeds >= 512)
else
  Pass.visible = fal
Votes
Translate
Translate
LEGEND ,
else
Votes
Translate
Translate
Report
Report
Engaged ,
yes
working. Thank you Ned Murphy
Votes
Translate
Translate
Report
Report
Engaged ,
and one more same issue pls..
this is already string so ......
upSpeeds.text = String( int(( ( uploadFile.size/tm.currentCount ) / 1024 ) * 8 )) + " Kbps";
function uploadTest()
if (Number(upSpeeds.text) >= 256)
          upPass.visible = true;
          upFail.visible = false;
else
          upPass.visible = false;
          upFail.visible = true;
Votes
Translate
Translate
Report
Report
LEGEND ,
Show you learned something from the other and solve it.
Votes
Translate
Translate
Report
Report
Engaged ,
no, no
first i trying after i asking for solution. this is already i tried the as last time but not working.
Votes
Translate
Translate
Report
Report
LEGEND ,
no, no
this involves solving the same problem so you should learn from the first one and apply it to the second.  If you tried, you should show what you tried.
Votes
Translate
Translate
Report
Report
Engaged ,
May 25, 2012 May 25, 2012
LATEST
yaa i tried night, finally i got it.
Thanky you for ....
var upSpeeds:int;
upSpeeds= (( ( uploadFile.size/tm.currentCount ) / 1024 ) * 8 );
upSpeeds.text = upSpeeds + " Kbps";
if (Number(upSpeeds) >= 256)
else
Votes
Translate
Translate
Report
Report
