Import/Open SVG Files in Fireworks CS5!
May 24, 2012 11:42 AM
Tags: #cs5 #fireworks #vector #svg
Hey,
I really need to import/open SVG files in Fireworks CS5. I have been searching the Web for days now, but I can't find anything. The reason for this is that I get thousands of files sent to me in SVG format that I needto incorporate into my designs made in Fireworks. I solve it today by opening the files in Illustrator, copy each one of them, paste in Fireworks... WTF!
So please tell me someone made this easy for me?
Many thanks!
    May 24, 2012 1:26 PM   in reply to Erik Lydecker
    Fireworks doesn't have native support for SVG format. You can convert SVG files to PNG format with Fireworks. They will not be editable, however.
    http://www.ehow.com/how_8616478_convert-svg-fireworks-png.html
    May 24, 2012 2:35 PM   in reply to Erik Lydecker
    @Linda: I couldn't get File > Open to work on an SVG file (in FW8 or CS5). I was suprised; I didn't realize that format was such a problem.
    @Erik: My suggestion is to talk to the people sending you the files and to request an alternate format. Or charge them for the extra time.
    May 25, 2012 12:06 PM   in reply to Erik Lydecker
    You may be able to use Inkscape to open and export as a png.
    Jun 1, 2012 10:06 AM   in reply to Erik Lydecker
    I also have this problem. I didnt exatly find a solution, however here's the way i learnt to use .svg without losing editability in Fireworks.
    1. Download Inkscape as suggested by Joyce Evans Erb. Here
    2. Open the SVG file you need to work with in Inkscape.
    3. Go to File > Save As and select .eps (Encapsulated PostScript)
    4. Open the saved .eps file in Fireworks.
    Now you might get a bit of unnecessary space around the file but it should work out just fine.
    Also, if you havn't already go check out thenounproject.com . It's a great resource for us Fireworks types.
    As a final note, i'd just like to plead with Adobe to put a bit more effort into Fireworks. It's a great program that i feel is being dragged along with the suite. (Hope to see some really awesome stuff in Fireworks CS6.5 *wink* )
    Jun 1, 2012 3:14 PM   in reply to sylvesteraryee
    so glad it helped and you found a way :-)
    Apr 4, 2013 4:23 AM   in reply to Erik Lydecker
    The easiest way that I have found is to open the SVG in Ai, then copy and paste into Fw - works like a dream
    I would loe to see support for SVG in Fw...
    May 28, 2013 11:12 AM   in reply to A D H
    You can import SVG files directly into Fireworks using this extension: http://johndunning.com/fireworks/about/SVG
