I am trying to play recorded sound on my app. I recorded it by timing the time between player clicks on the instruments and the title of the sound. I am playing it with timers thet are set to the time between clicks that was recorded(to mach player clicking time).
When I play the sound not through a channel and sound transform it works fine.
I added a volume slider and a channel, and I am playing all sounds through that channel. The volume changes fine when i drag the slider but there is a ticking sound every time a sound is played, like it started at 100% volume and transformed to the actual volume after the first frame is played.
the code:
var guitarArray:Array = new Array;
var guitarChannel:SoundChannel = new SoundChannel();
var string1_mixer:Sound = new Sound();
string1_mixer.load(new URLRequest("sounds/string1.mp3"));
var string2_mixer:Sound = new Sound();
string2_mixer.load(new URLRequest("sounds/string2.mp3"));
var string3_mixer:Sound = new Sound();
string3_mixer.load(new URLRequest("sounds/string3.mp3"));
var string4_mixer:Sound = new Sound();
string4_mixer.load(new URLRequest("sounds/string4.mp3"));
var string5_mixer:Sound = new Sound();
string5_mixer.load(new URLRequest("sounds/string5.mp3"));
var string6_mixer:Sound = new Sound();
string6_mixer.load(new URLRequest("sounds/string6.mp3"));
// function gets recorded array if even contains time if odd comtains sound name (string)
function addArrays(guitar_array:Array):void{
guitarArray = guitar_array;
mixerPlay_btn.addEventListener(MouseEvent.CLICK, playAllArrays);
// play was clicked
function playAllArrays(e:MouseEvent):void{
playGuitar_mixer();
//////////////////////// Volume //////////////////////////////////////
drag_guitar_btn.addEventListener(MouseEvent.MOUSE_DOWN, changeGuitarVol);
drag_guitar_btn.addEventListener(MouseEvent.MOUSE_UP, stop_changeGuitarVol);
var guitar_slider_length:Number = slider_guitar.width;
var guitar_boundingBox:Rectangle=new Rectangle(slider_guitar.x,slider_guitar.y,guitar_slider_length,0);
var guitar_dragging:Boolean=false;
drag_guitar_btn.buttonMode = true;
function changeGuitarVol(e:MouseEvent):void{
drag_guitar_btn.startDrag(false, guitar_boundingBox);
guitar_dragging=true;
drag_guitar_btn.addEventListener(Event.ENTER_FRAME, adjustVolume_guitar);
function stop_changeGuitarVol(e:MouseEvent):void{
if (guitar_dragging) {
drag_guitar_btn.stopDrag();
guitar_dragging=false;
function adjustVolume_guitar(myEvent:Event):void {
var guitar_Volume:Number=(drag_guitar_btn.x-964.6)/guitar_slider_length;
var guitarTransform:SoundTransform=new SoundTransform(guitar_Volume);
if (guitarChannel!=null) {
guitarChannel.soundTransform=guitarTransform;
////////////////////// Guitar /////////////////////////////////////////
function playGuitar_mixer():void{
if(guitarArray!=null){
var counter_guitar:Number = 0;
soundaddGuitar();
//function add timer if counter_guiter%2 = 0, else it plays sound acording to content(string), execute as long as counter_guitar<guitarArray length, recursive
function soundaddGuitar():void{
if(counter_guitar<guitarArray.length){
if(counter_guitar%2 == 0){
if(guitarArray[counter_guitar]!=null){
var timerloopGuitar2:Timer = new Timer(guitarArray[counter_guitar]*10,1);
timerloopGuitar2.start();
trace(guitarArray[counter_guitar]);
trace(counter_guitar);
trace(timerloopGuitar2.currentCount);
timerloopGuitar2.addEventListener(TimerEvent.TIMER_COMPLETE, playSound);
else{
trace('END OF LOOP');
trace('array length ' + guitarArray.length);
trace('i = ' + counter_guitar);
//plays sound if guitar_counter is odd
function playSound(t:TimerEvent):void{
if(guitarArray[counter_guitar+1] != null){
if(guitarArray[counter_guitar+1] == 'string1_sound'){
guitarChannel = string1_mixer.play();
if(guitarArray[counter_guitar+1] == 'string2_sound'){
guitarChannel = string2_mixer.play();
if(guitarArray[counter_guitar+1] == 'string3_sound'){
guitarChannel = string3_mixer.play();
if(guitarArray[counter_guitar+1] == 'string4_sound'){
guitarChannel = string4_mixer.play();
if(guitarArray[counter_guitar+1] == 'string5_sound'){
guitarChannel = string5_mixer.play();
if(guitarArray[counter_guitar+1] == 'string6_sound'){
guitarChannel = string6_mixer.play();
counter_guitar= counter_guitar+2;
soundaddGuitar();
sorry if its long, can't specify a place in the code.
any help would be appreciated.
North America
Asia Pacific
