Ivan in Joetsu
Can't embed H.264 videos in Acrobat X Pro
May 25, 2012 1:37 AM
Tags: #acrobat #video #h.264 #mp4 #embed
Adobe Acrobat X Pro won't let me embed a video file which I created as
"MPEG4: iPhone H.264 (640x480)" in Corel Video Studio.
The video file plays fine in Windows Media Player, QuickTime, Corel Video Studio, and
Final Cut Express (on a Mac, which also displays "H.264 compression" in properties for the file).
Here's an analysis of the file from MediaInfo:
Format: MPEG-4;  Format profile: Sony PSP;
Codec ID: MSNV;    File size: 110 MiB;   Duration: 6mn 0s;
Overall bit rate mode: Variable ;  Overall bit rate: 2 556 Kbps;   Video ID: 1;
Format: AVC;     Format/Info: Advanced Video Codec;   Format profile: Baseline@L3.0;
Format settings, CABAC: No;   Format settings, ReFrames: 2 frames;   Format settings, GOP: M=1, N=15;
Codec ID: avc1;    Codec ID/Info:  Advanced Video Coding;
Bit rate mode: Variable;   Bit rate: 2 393 Kbps;   Maximum bit rate: 2 500 Kbps;
Width: 640 pixels;   Height: 480 pixels;   Display aspect ratio: 4:3;
Original display aspect ratio: 4:3;   Frame rate mode: Constant;  Frame rate: 30.000 fps;
Standard: NTSC;   Color space: YUV;   Chroma subsampling: 4:2:0; Bit depth: 8 bits;
Scan type: Progressive; Bits/(Pixel*Frame): 0.260;   Stream size: 103 MiB (94%);
Color primaries: BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177;
Transfer characteristics: BT.709-5, BT.1361;
Matrix coefficients: BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
I only have Adobe Acrobat X Pro CS5.5 and DreamWeaver CS5.5 (Educational/Academic versions),
and it seems I can't get Adobe Media Encoder separately. I have to get Adobe Acrobat X Suite or something similar.
Any ideas would be welcome.
Ivan Brown
University Lecturer
    May 25, 2012 2:56 PM   in reply to Ivan in Joetsu
    The Sony PSP codec profile is the issue - that's proprietary and isn't supported in Flash Player.
