CF10 and apache connector
May 27, 2012 2:07 AM
Tags: #error #install #apache #linux #connector #coldfusion10 #tomcat_connector
i can't install connector for apache and coldfusion10.
the installation of cf10 has been successful without errors.
but, when i star cf10 i get this error:
Starting ColdFusion 10 server instance named cfusion ...
The ColdFusion 10 server instance named cfusion is starting up and will be available shortly.
nohup: appending output to `nohup.out'
Running the ColdFusion 10 connector wizard
Configuring the web server connector (Launched on the first run of the ColdFusion 10 start script)
Running /usr/local/apache2/conf connector wizard...
There was an error while running the connector wizard
Connector installation was not successful
ColdFusion 10 server instance named cfusion has been started.
ColdFusion 10 will write logs to /opt/coldfusion10/cfusion/logs/coldfusion-out.log
this is my /opt/coldfusion10/config/wsconfig/wsconfig.log
(paths of apache are correct)
wsconfig -ws Apache -bin /usr/local/apache2/bin/httpd -script /usr/local/apache2/bin/apachectl -dir /usr/local/apache2/conf -v
os.name: Linux
os.version: 2.6.18-308.4.1.el5
os.arch: i386
platform: intel-linux
command line: -ws Apache -dir /usr/local/apache2/conf -bin /usr/local/apache2/bin/httpd -script /usr/local/apache2/bin/apachectl -cfide /opt/coldfusion10/cfusion/wwwroot/CFIDE -v
web server: Apache
web server directory: /usr/local/apache2/conf
apialloc: false
force resource extract from jar: true
Apache binary: /usr/local/apache2/bin/httpd
Apache control script: /usr/local/apache2/bin/apachectl
Apache apxs: false
Deleted directory /opt/coldfusion10/config/wsconfig/1
CentOS release 5.8 (Final)
OS version: 5 (5)
connector built with gcc3 or compat-glibc-7.x rpm required
Using Apache binary /usr/local/apache2/bin/httpd
LD_LIBRARY_PATH=/usr/local/apache2/lib:/opt/coldfusion10/jre/lib/i386/ client:/opt/coldfusion10/jre/lib/i386:/opt/coldfusion10/jre/../lib/i38 6
Server's Module Magic Number: 20020903:13
Using magic number 20020903 to determine connector
Using resource gcc3/mod_jk20.so.20020903
version 2.0.63 (min 43)
Server version: Apache/2.0.63
Compiled in modules:
  core.c
  mod_access.c
  mod_auth.c
  mod_include.c
  mod_log_config.c
  mod_env.c
  mod_setenvif.c
  prefork.c
  http_core.c
  mod_mime.c
  mod_status.c
  mod_autoindex.c
  mod_asis.c
  mod_cgi.c
  mod_negotiation.c
  mod_dir.c
  mod_imap.c
  mod_actions.c
  mod_userdir.c
  mod_alias.c
  mod_rewrite.c
  mod_so.c
Using Apache control script /usr/local/apache2/bin/apachectl
Parsing Apache configuration file /usr/local/apache2/conf/httpd.conf
Exec'ing chmod 777 /opt/coldfusion10/config/wsconfig/1
Set permission to 777 on /opt/coldfusion10/config/wsconfig/1
ColdFusion could not locate the connector for this configuration. Refer documentation for supported web server for your OS.
then i try to install connector by hand, following instructions at this link
http://helpx.adobe.com/coldfusion/kb/coldfusion10-apache-manual-connec tor-configuration.html
but, when i start apache, i get this error:
Syntax error on line 2 of /usr/local/apache2/conf/mod_jk.conf:
Cannot load /opt/coldfusion10/config/wsconfig/1/mod_jk22.so into server: /opt/coldfusion10/config/wsconfig/1/mod_jk22.so: ELF file OS ABI invalid
my system
Linux gundam 2.6.18-308.4.1.el5 #1 SMP Tue Apr 17 17:08:10 EDT 2012 i686 athlon i386 GNU/Linux
# cat /selinux/enforce
0
# cat /etc/redhat-release
# apachectl -v
on this machine cf9 works fine.
any idea?
many thanks.
    Aug 3, 2012 10:22 AM   in reply to robylab
    I've got the same error on CentOS, although I'm getting it from the mod_jk22.so that CF installed, not a self-compiled one.
    Cannot load /opt/coldfusion10/config/wsconfig/1/mod_jk.so into server: /opt/coldfusion10/config/wsconfig/1/mod_jk.so: ELF file OS ABI invalid
    My config:
    Linux 2.6.18-238.el5 #1 SMP Thu Jan 13 16:24:47 EST 2011 i686 i686 i386 GNU/Linux
    apachectl -v
    Server version: Apache/2.2.3
Bookmarked By (1)
