Encore cs6 bluray project crashes encore at the build start.
May 26, 2012 10:34 PM
Tags: #encore #building #bluray
I thing there is a bug in the new Encore Cs6. I have created a project in encore cs6 and when trying to build a bluray Encore crashes at the beginning of the build.
When I open the same project in encore cs5.1 it will work fine and complete the build and the burn (though if I am trying to use the same blank disk it will ask for a media even though I cannot see anything written on the blank disk, but it will build and burn just fine with a fresh flank media).
The DVD projects work fine in cs6, it is only the bluray that crashes every time.
    May 27, 2012 2:04 AM   in reply to dkitsov
    I found that old BD projects do not work well in CS6.
    Make new project, import menu and assets.
    See if that will work, did for me.
    May 27, 2012 10:22 AM   in reply to dkitsov
    Sorry misread, wont respond anymore.
    May 27, 2012 11:44 AM   in reply to dkitsov
    More information needed for someone to help... click these links and provided the requested information
    -http://forums.adobe.com/message/4200840
    -http://forums.adobe.com/thread/416679
    May 27, 2012 5:40 PM   in reply to dkitsov
    The questions in the links I posted include at least TWO things that might make a difference...
    Windows or Mac
    List of what kind of assets
    If you don't want to answer simple questions that may help someone provide an answer, so be it
    PS
    >submitting it to Adobe engineers
    You submit with the very little information you provided here and you will most likely be ignored
    May 27, 2012 6:55 PM   in reply to dkitsov
    The reason for this post is to confirm the bug with the community, as it is a good practice to eliminate a possibility of a  User Error on my side, before submitting it to Adobe engineers
    Users (Ann for example) are building successfully in CS6. So the most general version of your problem does not appear to demonstrate a repeatable problem.
    What kind of BD project? Assets, menu types, etc.
    But that is a very wide range, so I would narrow it down by checking some of what does work for you: can you build a simple menu only BD project? Short single timeline with single menu, etc.
    May 27, 2012 8:18 PM   in reply to dkitsov
    Were you able to identify what it was about the menu?
    May 27, 2012 9:15 PM   in reply to dkitsov
    Could you share that menu so that someone can identify what is wrong/different with that menu?
    I don't think this would be a general problem because people are building the Blu-ray projects successfully.
    -Ramesh.
