I am having a big problem when using the new CS6 on my Mac (os x 10.7.4). When switching to a new tool, like a brush, or clone stamp, or healing brush etc, Photoshop hangs for about 20 seconds before resuming. It's not 3rd party plug-ins, because I get the same behaviour when I run using the shift key and third party plug-ins are disabled. It doesn't happen every time, but it happens frequently. I've heard that others have had similar problems... are there any solutions - is it a known bug?
Having the same problem as you. Select brush tool > freeze 20 seconds, select type tool > freeze 20 seconds, select move tool > freeze 20 seconds.
Like you I tried disabling any third party plugs, brushes, fonts etc, which didn't help.
I noticed this bahaviour in the beta and did report it. Extrememly disapointed that it's still happening in the final and ruining what is otherwise a solid update.
My system: OSX 10.6.8, 2x2.26 Quad Core Intel Mac Pro Nehalem model. 16GB Ram, ATI Radeon HD 4870, Wacom Intuos 3, dual 30" Apple Cinema Displays.
Chrish - I uninstalled the beta using the Adobe uninstaller, then did a fresh reinstall of Photoshop from the trial. Still running in trial mode. I tried resetting the prefs today, hasn't stopped the hanging.
Not noticed anything in common that triggers the hang. It just happens when a tool is selcted.
Had a hang just now for about 60 seconds when I hit B for the brush tool.
Just to rule things out: Make a clean user on your computer and run Photoshop to see if it still hangs. If it doesn't hang anymore it might mean that Photoshop is fighting for resources that your computer is giving out to other processes on your usual user. You can always delete the user you've created later.
Same sort of problem here on my Mac Pro. The Intuos 4 pen hangs when using clone/heal type tools or if I'm using the space bar and pen to move the canvas. It hangs when I make a stroke but not when I select the tool. Typically, I make a stroke on the image and the pen will "not let go" - leaving a trail if the pen moves until it finally releases. The frequency of the problem is mixed. Sometimes I can go for an hour with no problem and other times it starts almost immediately. It usually will start with a random delay on strokes, getting worse until the pen is no longer usable.
I've updated Wacom drivers, uninstalled them completely and loaded the latest versions, and even tried prior driver versions. Nothing works and its seriously impacting my workflow. I may have to go back to CS5 until a fix is found.
This problem existed with both Beta version and the purchased version I am using.
Currently, I am not very happy with Adobe's product service due to major issues I had with CS6 this weekend (along with years of dealing with unresolved bugs in previous versions).
But for an employee of Adobe to come out and say out right that you are not familiar with this behaviour is very perplexing to me.
Just try googling this issue and you can see both PC and Mac users are having the same issue.
Are you saying at Adobe, you don't have enough QA time put into reviewing your product? Or are you saying your QA testers are incompetent? Or are you saying your customers are all fools?
At least admit the issues with your softwares and just fix it. Dragging on known issues willl make your customers very unhappy.
I for one, if there is replacement for Adobe products, I would jump on it right away. Adobe definitely is not the same company that I used to know. All their latest apps are blotted and doesn't really resolve core issues in time.
This particular issue is very troublesome for industry professionals. I run into it daily and it's a huge hassle.
Make a clean user on your computer and run Photoshop to see if it still hangs. If it doesn't hang anymore it might mean that Photoshop is fighting for resources that your computer is giving out to other processes on your usual user.Thanks for the information and success. http://www.kabbanet.ro
I'm seeing the same issue. Mac OS 10.7.4, Mac Pro 2010 8-core with 32gb ram. NOTE that it seems it is not photoshop itself that becomes unresponsive, it appears to be only the document window (photoshop still lets me open the file menu, for instance). It becomes unresponsive when a tool is selected, after which I can't do anything with a document, or any of the pallets. I am using a Wacom Intuos 4; updated my drivers yesterday, and the freezing still happens.
I'm going to try and watch activity monitor for the rest of the day and see if anything jumps out at me. But honestly, with the specs on this machine, if photoshop is using up all resources it's a software issue. If this machine can't run PS effectively without constant unresponsiveness, then I might as well give up now.
I notice that nobody has posted their System info from Help > system Info inside Photoshop -- That can really help in obtaining information that might be easily discovered by looking through the sysinfo data.
So if you are still seeing this trouble and looking for help via the forums, that is a great place to start --- How about getting a few System Info's to this thread?
Thanks!
Pete
Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
Operating System: Mac OS 10.7.4
System architecture: Intel CPU Family:6, Model:44, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Physical processor count: 8
Logical processor count: 16
Processor speed: 2400 MHz
Built-in memory: 32768 MB
Free memory: 13998 MB
Memory available to Photoshop: 30256 MB
Memory used by Photoshop: 70 %
Image tile size: 1024K
Image cache levels: 4
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Version: 2.1 ATI-7.18.18
OpenCL Version:
Video Card Vendor: ATI Technologies Inc.
Video Card Renderer: ATI Radeon HD 5770 OpenGL Engine
Display: 2
Display Depth:= 32
Display Bounds:= top: 0, left: 1920, bottom: 1200, right: 3520
Video Renderer ID: 16915202
Video Card Memory: 1257 MB
Video Rect Texture Size: 16384
OpenCL Version:
Display: 1
Main Display
Display Depth:= 32
Display Bounds:= top: 0, left: 0, bottom: 1200, right: 1920
Serial number: [removed by admin]
Application folder: Macintosh SSD:Applications:Adobe Photoshop CS6:
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 222.8G, 185.6G free
Required Plug-ins folder: Macintosh SSD:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
Primary Plug-ins folder: Macintosh SSD:Applications:Adobe Photoshop CS6:Plug-ins:
Additional Plug-ins folder: not set
Installed components:
adbeape.framework adbeape 3.3.8.19346 66.1025012
AdbeScriptUIFlex.framework AdbeScriptUIFlex 6.2.29.18602 66.490082
adobe_caps.framework adobe_caps 6.0.29.0 1.276181
AdobeACE.framework AdobeACE 2.19.18.19243 66.492997
AdobeAGM.framework AdobeAGM 4.26.17.19243 66.492997
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.7.101.18636 66.26830
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.7.101.18636 66.26830
AdobeBIB.framework AdobeBIB 1.2.02.19243 66.492997
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 66.492997
AdobeCoolType.framework AdobeCoolType 5.10.31.19243 66.492997
AdobeCrashReporter.framework AdobeCrashReporter 6.0.20120201
AdobeExtendScript.framework AdobeExtendScript 4.2.12.18602 66.490082
AdobeJP2K.framework AdobeJP2K 2.0.0.18562 66.236923
AdobeLinguistic.framework 17206
AdobeMPS.framework AdobeMPS 5.8.0.19463 66.495174
AdobeOwl.framework AdobeOwl 4.0.93 66.496052
AdobePDFL.framework AdobePDFL 10.0.1.18562 66.419471
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 6.0.0.1654
AdobeScCore.framework AdobeScCore 4.2.12.18602 66.490082
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 66.145661 66.145661
AdobeXMPFiles.framework AdobeXMPFiles 66.145661 66.145661
AdobeXMPScript.framework AdobeXMPScript 66.145661 66.145661
ahclient.framework ahclient 1.7.0.56
aif_core.framework AdobeAIF 3.0.00 62.490293
aif_ocl.framework AdobeAIF 3.0.00 62.490293
aif_ogl.framework AdobeAIF 3.0.00 62.490293
AlignmentLib.framework xcode 1.0.0.1
amtlib.framework amtlib 6.0.0.75
boost_date_time.framework boost_date_time 6.0.0.0
boost_signals.framework boost_signals 6.0.0.0
boost_system.framework boost_system 6.0.0.0
boost_threads.framework boost_threads 6.0.0.0
Cg.framework NVIDIA Cg
CIT.framework CIT 2.0.5.19287 145486
data_flow.framework AdobeAIF 3.0.00 62.490293
dvaaudiodevice.framework dvaaudiodevice 6.0.0.0
dvacore.framework dvacore 6.0.0.0
dvamarshal.framework dvamarshal 6.0.0.0
dvamediatypes.framework dvamediatypes 6.0.0.0
dvaplayer.framework dvaplayer 6.0.0.0
dvatransport.framework dvatransport 6.0.0.0
dvaunittesting.framework dvaunittesting 6.0.0.0
dynamiclink.framework dynamiclink 6.0.0.0
FileInfo.framework FileInfo 66.145433 66.145433
filter_graph.framework AdobeAIF 3.0.00 62.490293
hydra_filters.framework AdobeAIF 3.0.00 62.490293
ICUConverter.framework ICUConverter 3.61 "gtlib_3.0" "." "16615"
ICUData.framework ICUData 3.61 "gtlib_3.0" "." "16615"
image_compiler.framework AdobeAIF 3.0.00 62.490293
image_flow.framework AdobeAIF 3.0.00 62.490293
image_runtime.framework AdobeAIF 3.0.00 62.490293
LogSession.framework LogSession 2.1.2.1652
mediacoreif.framework mediacoreif 6.0.0.0
PlugPlug.framework PlugPlug 3.0.0.383
UpdaterNotifications.framework UpdaterNotifications 6.0.0.24 "6.0.0.24"
wrservices.framework
Required plug-ins:
Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc. All rights reserved. - from the file “AdobeADM.bundle”
Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Camera Raw 7.1 (354), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 13.0 20120315.r.428 2012/03/15:21:00:00 ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
Collada DAE 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 13.0 20120315.r.428 2012/03/15:21:00:00 ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Difference Clouds 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 13.0 20120315.r.428 2012/03/15:21:00:00 ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Embed Watermark NO VERSION - from the file “DigiSign.plugin”
Enable Async I/O 13.0 20120315.r.428 2012/03/15:21:00:00 © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
FastCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 13.0 20120315.r.428 2012/03/15:21:00:00 ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Measurement Core 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
MMXCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Picture Package Filter 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 13.0 20120315.r.428 2012/03/15:21:00:00 ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
Read Watermark NO VERSION - from the file “DigiRead.plugin”
Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins:
BackgroundFilter NO VERSION - from the file “BackgroundFilter.plugin”
Dfine 2.0 NO VERSION - from the file “Dfine2.plugin”
FineStructuresFilter NO VERSION - from the file “FineStructuresFilter.plugin”
Hidden Topaz Labs Denoise - from the file “TopazRemaskAutomate.plugin”
HotPixelsFilter NO VERSION - from the file “HotPixelsFilter.plugin”
Nik Selective Tool 2.103, Copyright © 2000-2012 Nik Software Inc. - from the file “SelectivePalette.plugin”
ShadowsFilter NO VERSION - from the file “ShadowsFilter.plugin”
Silver Efex Pro 2 2.004, Copyright © 2000-2012 Nik Software Inc. - from the file “Silver Efex Pro 2.plugin”
SkinFilter NO VERSION - from the file “SkinFilter.plugin”
SkyFilter NO VERSION - from the file “SkyFilter.plugin”
StrongNoiseFilter NO VERSION - from the file “StrongNoiseFilter.plugin”
Topaz Adjust 5 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_adjust5.plugin”
Topaz Clean 3 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_clean3.plugin”
Topaz DeJpeg 4 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_dejpeg4.plugin”
Topaz DeNoise 5 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_denoise5.plugin”
Topaz Detail 2 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_detail2.plugin”
Topaz InFocus CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_infocus.plugin”
Topaz ReMask 3 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_remask3.plugin”
Topaz Simplify 3 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_simplify3.plugin”
Plug-ins that failed to load: NONE
Flash:
Mini Bridge
Kuler
Installed TWAIN devices: NONE
Thanks for the system info -- All looks pretty good from my perspective at least from Photoshop's end -- Not sure why you're seeing the slowdowns your'e seeing.
I use an Intuos 4 on my 10.7.4 Imac with 12 gigs of ram here, AMD Radeon HD 6750M, an i5 and I don't experience the hangs you're describing.
Have you tried a different admin user? Do you see the same hangs there?
What about an uninstall/reinstall of Photoshop? This isn't the most fun step, but it is pretty worthwhile for troubleshooting.
My Wacom tablet utility shows I'm using v6.2.0w4
I can reproduce it with a new, clean admin user.
Your Wacom drivers are out of date, I am using 6.3.1w2 which I downloaded yesterday in an attempt to resolve this (see the previous posts). Updated drivers didn't seem to change anything.
I faill see what another install will accomplish, aside from taking up lots of my time. I assume by "troubleshooting" you mean "hope the goes away". This has been happening since I went to CS6 (although it only became intolerable in the past day or so, as my work over the past few weeks was pretty straight photography with very little ps work). The problem didn't just start happening, it's been that way from the first install of CS6. What's the next step if a clean install wouldn't change anything? It's pretty much unusable at the moment.
Does it always sit on 100% CPU (like right after you launch PS), or does it do that only after you've done certain functions in the app? It would really help if you could say I did X, Y, and Z and then PS starts using 100% CPU.
Also, if anyone is experiencing this slowdown and is anywhere west of the rockies, please let me know. I might want to pay you a visit so we can try to get this issue understood and resolved.
Adam
Disabling third party plugins/addons didn't fix the tool lag for me.
Despite earlier improvement after updating my Wacom drivers I'm still getting the occasional lag. Will keep Actvity Monitor open to monitor any CPU spikes, but didn't notice anything in Menu Meters' CPU gauges during previous tool lags.
I can see it hit 100% CPU whenever it hangs like this. As others have also reported, it hangs for around 30 seconds when a tool is selected (but not every time a tool is selected). I'm pretty confident it's the act of selecting the tool that is the trigger - this morning I hit J to get my patch tool, and immediate tried to use it; then noticed it was hanging again. When it finally was responsive again, there was no "patch" in the history, leading me to believe the actual hang began when I selected the tool, not when I tried to use the tool.
Normal CPU load for photoshop is less than 1%, and there's no reason the simple act of selecting a tool should do this.
Well I am seeing the same thing too, and suspect this is a much more prevalent problem than what has so far been reported. System Info http://www.dypinc.com/DYP_Sys_Info.rtf
When I select tools the selection seems okay but I cannot start using the tools right away. I have to wait for 10 or more seconds before I can do anything with the tools. So far this seems to be for all tools. I havn't had time to really try to diagniose this yet so that is why I havn't really mentioned it before except that the updated wacom driver did not really help any.
I spent about 6 hours in CS6 yesterday and would estimate I lost atleast a half hour waiting for the tools to respond. I this point when I need to push jobs through I am going to be using CS5.
North America
Asia Pacific
