I have a Mobile Project in FB 4.6 with a TabbedViewNavigator. I have 4 buttons at the bottom, which are ViewNavigators, and act as the Tabs. For this instance, lets say the tabs are labeled, HOME, ADD, DELETE, and ABOUT. I am running into the following situation:
How can I have the functionality changed so that upon pressing a Tab, the user is ALWAYS taken to the firstView property of that tab. As referenced above, this is not happening. I have tried creating an IndexChangeEvent listener on the tabbedNavigator and then changing the tabbedNavigator's selectedIndex, however this doesn't work.
protected function tabbedviewnavigatorapplication1_applicationCompleteHandler(event:FlexEvent):void {
this.tabbedNavigator.addEventListener(IndexChangeEvent.CHANGE,onIndexChange);
protected function onIndexChange(event:IndexChangeEvent):void {
this.tabbedNavigator.selectedIndex = event.newIndex;
trace(' THIS DOESN'T WORK');
Any help is appreciated. Thanks, in advance.
Hi sleblang,
Did you manage to get an answer to your question? I am also struggling with this problem!
Yes, I ended up using the following code:
tabbedNavigator.activeView.navigator.popToFirstView();
Hope this helps!
North America
Asia Pacific
