Snap Caulfield South Dave
Acrobat Pro 9.5.1 Document Properties glitch
May 28, 2012 5:51 PM
Tags: #acrobat #pro #properties #glitch #9.5.1
When trying to view the document properties in Acrobat Pro 9.5.1 I get the below screenshot. The box is tiny and so small nothing can be viewed. I have to press ESC to close the window. I can only use ALT+SPACE to move  it also.
PC config:
Generic Dell Crap Vostro 200.
Windows XP SP3
CS4 DP - only Acrobat, Distiller, Bridge, Illustrator and Photoshop, no InDesign.
CS5.5 DS - Everything but Acrobat X as it isn't compatible with our plugins and add-ons.
All Adobe software is updated, as is the windows OS. AV is AVG Business.
  • David Kastendick
    Apr 7, 2010
    May 31, 2012 1:11 PM   in reply to Snap Caulfield South Dave
    Hi there,
    This is certainly odd.  Have you tried to repair your Acrobat installation via Help > Repair Acrobat Installation?
    -David
    Jun 3, 2012 4:59 PM   in reply to Snap Caulfield South Dave
    Did you try the repair as David suggested?
  • David Kastendick
    Apr 7, 2010
    Jun 4, 2012 10:21 AM   in reply to Snap Caulfield South Dave
    Try initiating the repair from Add/Remove Programs instead of from within the application.
    -David
    Jun 4, 2012 1:20 PM   in reply to David Kastendick
    Also, 2 hrs sounds excessive for a repair. It usually takes my systems 10 mins at most. Sounds like you have something corrupt on your system.
  • David Kastendick
    Apr 7, 2010
    Jun 6, 2012 10:51 AM   in reply to Snap Caulfield South Dave
    Sorry, missed that AcroX was installed as a part of CS4 DP.  Try uninstalling Acrobat from within the CS4 installation, then reinstall.  Check to ensure the base installation is functioning properly.  Then begin the update process.  Each update will ask you to restart the computer.  You don't need to until the final update has been applied.
    -David
