can't select 'stroke path' in photoshop CS6 to taper pen tool edges
May 29, 2012 1:01 PM
Tags: #select #lines #stroke #pen_tool #stroke_path
For some reason I can't select the "stroke path" option with the pen tool in photoshop to add tapers to my pen tool strokes. I can only get dead lines. small screen shot.jpg
why is this not working?
    May 29, 2012 6:12 PM   in reply to JimFro
    In your screenshot you have a shape layer selected. In order to stroke paths you need to either save the path if it's a shape layer and make a new blank layer to add the stroke
    or make your path using the paths option instead of shapes and use a non shape layer, smart object, adjustment layer to put the stroke on. In other words the active layer needs to be a pixel layer (such as layer 3 in your screenshot) in order to stroke a path with one of the brush tools.
    Oct 15, 2012 6:34 AM   in reply to JimFro
    If its smart object, it wont work.
    Nov 10, 2012 2:14 PM   in reply to JimFro
    When you use the pen tool, make sure path is selected in the top right corner. You have it selected to shape not pathPenPath.jpg
    Jun 25, 2013 3:12 AM   in reply to JimFro
    I've just figured out while trying to stroke on a layer using ellipse shape.
    Just select the shape with path selection tool and press ctrl+x then ctrl+v (just cut and paste it anywhere). Now the stroke options must be available.
    Cheers
    Mar 21, 2014 8:14 AM   in reply to JimFro
    If I understand you correctly JimFro, you want to draw a path with the pen tool then apply a stroke that tapers to nothing using the path as your guide.
    To do this in CS6:
    First draw out your path, making sure to draw in the direction you want the line to fade to.
    Then you need to create a new layer onto which your stroke will be drawn. Make sure you have it selected.
    Next you need to set up your brush. Select the brush you wish to use (size, colour etc.) - then open the brush panelbrush_panel_icon.gif and under 'shape dynamics' select fade in the control for size jitter. then enter in pixels the distance you want to fade the stroke in. You'll probably have to trial & error this figure.
    Finally in the path panel select the 'stroke path with brush' icon (second from left at the bottom of the panel) to apply the faded stroke to the selected layer.path_panel.gif
