Error With AME 6 on export
May 29, 2012 8:50 PM
Everytime i que, to AME 6 my sequence will render until around half way and stop, it fail, it just freezes, at that point in the timeline, it happens at different stages everytime i try to render the project, it happens with all of my projects, has this happened to anyone else before if so how did you resolve it?
    May 30, 2012 7:57 PM   in reply to eyreadri
    I am having the same trouble. I tried rendering parts of the project but the same happens. All my sequence has the Colorista Filter. So far I haven´t been able to solve it . I only had success when i removed the fx. i need to deliver this job and will have to reconstruct the project in CS5.5.
    May 31, 2012 7:29 AM   in reply to H Hugo Montes
    HUgo, are you from Sydney?
    I'm also having the same problem. I have a few different frame size videos in the timeline which I have scaled to frame size, however it's in its original size sequence which I've nested in this one if that makes sense? Each time I export it hangs on the same clip. However, when I export from Premiere directly, it exports perfectly with no glitches. I have deleted the media cache and loaded them again. However,I was getting heaps of problems with my blackmagic decklink card and since uninstalling the drivers, I haven't deleted the cache files and reloaded them. The sequence is around 40 minutes long. It usually hangs 40 an hour into encoding.
    May 31, 2012 7:53 AM   in reply to eyreadri
    I am also having the same problem.
    If I export directly from Premiere it works fine.  If I open AME and import a video to convert, it works fine.  But adding to the que from Premiere causes the freeze.
    Also, this did not happen untill I updated CS6 with the new updates.
    I'd love to have a fix for this.
    May 31, 2012 10:15 AM   in reply to thelostjeff
    First thing I'd check is whether CUDA hardware accelleration is  on.  In Premiere go to Project > Project Settings > General and check if the Renderer menu is set to Mercury Playback Engine GPU Acceleration.  If so, set it to Mercury Playback Engine Software Only and queue your sequence to AME again.  Note: if Mercury Playback Engine Software Only is the only choice in your Renderer menu, that means  you don't have a compatible NVIDIA graphics card and can disregard this...
    Another thing to check for is large image stills  in your Premiere sequence (greater than 1920x1080).  If so, try replacing these with 1920x1080 versions.
    Let us know if either of these fixes helps...
    May 31, 2012 7:01 PM   in reply to eyreadri
    Saad Khan
    ,  I am From Lima Peru
    eyreadri, I didn't have the time to look for other answers. My entire sequence was a title followed by several clips with colorista. My queue started rendering the title fast, but then when it reached the clip it froze. I tried to export  a reduced working area but it froze at the bigining. I even tried to inmport the sequence as a ADL into After Fx and it didn´t render either. The only thing that worked was ro remove colorista from the sequence and then it could export.
    As i wanted my sequence with the colorista i had to rebuild it into Premiere 5.5 with the same colorista settings and it worked fine. I didn´t have the chance to try if it was just colorista or if this problem would have happened  with other plug ins.
    So far, i am very disapointed with the upgrade.
    BTW how do you export directly from premiere without passing trough AME??
    Jun 1, 2012 9:16 AM   in reply to eyreadri
    I have used the colorista on my clips too
    I've had this freezing issue using both Looks and Colorista with an ATI graphics card.  The issue was resoled when I went to an nVidia card.
    Jun 1, 2012 9:45 AM   in reply to Jim Simon
    I use an Nvidia Card. Ill check if there is an available driver update to see if it solves the problem
    Jun 1, 2012 11:04 AM   in reply to H Hugo Montes
    I downloaded the Colorista II plugin (trial mode) and did some tests on my non-NVIDIA Mac but so far haven't hit any issues.  Exporting both direct from Premiere and via AME have worked okay on my simple tests.  One thing I did notice was a Render Using setting under the Options setting in the effect, with choices for "CPU" and "GPU (Open GL)".  See if switching this setting changes anything, especially if your system has a NVIDIA card for GPU rendering.
