I got this graph that I can slide with my finger, Im wondering if its possible to update it automatic with this code?
//Function for sliding graph.
protected function mouseDownHandler(event:MouseEvent):void
lastX = event.stageX;
systemManager.addEventListener(MouseEvent.MOUSE_MOVE, mouseMoveHandler);
systemManager.addEventListener(MouseEvent.MOUSE_UP, mouseUpHandler);
protected function mouseMoveHandler(event:MouseEvent):void
var delta:Number = (lastX - event.stageX) / chart.width * viewportMax;
if (hAxis.minimum + delta < 0)
hAxis.minimum = 0;
hAxis.maximum = viewportMax;
else if (hAxis.maximum + delta > chart.dataProvider.length - 0)
hAxis.maximum = chart.dataProvider.length - 0;
hAxis.minimum = hAxis.maximum - viewportMax;
else
hAxis.minimum += delta;
hAxis.maximum += delta;
protected function mouseUpHandler(event:MouseEvent):void
systemManager.removeEventListener(MouseEvent.MOUSE_MOVE, mouseMoveHandler);
systemManager.removeEventListener(MouseEvent.MOUSE_MOVE, mouseUpHandler);
The only thing I see in there that's unexplained is your usage of some object named "hAxis". Apparently changing the "maximum" or "minimum" property alters it. That code simply pays attention to your finger and adjusts those properties. You could adjust them youself to alter it without your finger. Just try setting it manually in a range that makes sense.
e.g.
// set explicit, 200 for example, change to taste (not sure what the value represents)
hAxis.minimum = 200;
hAxis.maximum = 200;
Here is the whole graph code, the source is the "myArray", it gets updated thru UDP.
I guess something have to be done in the "mouseMoveHandler". Tried to change different things, but it
still scolls with finger only, and does not update by itself. There should be a way to make it scroll by itself, dont you agree?
<fx:Script>
<![CDATA[
import flash.events.TimerEvent;
import flash.utils.Timer;
import flashx.textLayout.events.ScrollEvent;
import mx.collections.ArrayCollection;
import mx.events.FlexEvent;
import mx.rpc.events.AbstractEvent;
public var NewValue:Object;
public var Value:String;
public var myTimer:Timer;
public var PowerNumber:Number;
//Function for UDP graph.
protected var lastX:Number = 0;
[Bindable]
protected var viewportMax:Number = 10;
private function creationCompleteHandler():void
completeHandler();
init();
protected function completeHandler():void
chart.dataProvider = myArray;
hAxis.minimum = 0;
else if (hAxis.maximum + delta > chart.dataProvider.length - 1)
hAxis.maximum = chart.dataProvider.length - 1;
else
public var myArray:ArrayCollection = new ArrayCollection();
public function initTimer():void
var myTimer:Timer = new Timer(500, 0);
myTimer.addEventListener("timer", timerHandler);
myTimer.start();
public function timerHandler(event:TimerEvent):void
var obj:Object = new Object();
obj.time = getTimer();
obj.Value = NewValue;
myArray.addItem(obj);
protected function applicationCompleteHandler(event:FlexEvent):void
udpSocket = new UDPSocket();
udpSocket.addEventListener(DatagramSocketDataEvent.DATA, udpDataHandler);
udpSocket.bind(1000);
udpSocket.receive();
initTimer();
//Incomming UDP for graph (Tracking).
protected function udpDataHandler(event:DatagramSocketDataEvent):void
var Value:String = event.data.readUTFBytes(event.data.bytesAvailable);
if(Value)
NewValue = Value;
else
NewValue = 0;
</fx:Script>
<fx:Declarations>
<mx:SolidColorStroke id = "s1" color="0x0000ff" weight="2"/>
</fx:Declarations>
<mx:LineChart id="chart" x="51" y="141" width="875" height="190" paddingLeft="5" paddingRight="5"
showDataTips="true"
mouseDown="mouseDownHandler(event)">
<mx:series>
<mx:LineSeries yField="Value" form="curve" displayName="Tracking" lineStroke="{s1}"/>
</mx:series>
<mx:horizontalAxis>
<mx:LinearAxis id="hAxis" minimum="0" maximum="{viewportMax}"/>
</mx:horizontalAxis>
</mx:LineChart>
</s:Application>
North America
Asia Pacific
