Hello,
I am rebuilding one of my PS extension with Configurator 3 and want to customize the infos delivered in the Adobe Extension Manager, name of the extension name of the author, description, the icon
With configurator 2 it was easy by modifying the .mxi file generated,but now how can I do this. I don't want to have "com.configurator.edgeFX" as name of the extension but "Edge FX", My name instead of "Configurator 3".
Many Thanks.
Sebastien
After you create a panel, Configurator 3 added a "CS Extension Attributes" section for the panel.
This section is listed on the right hand under "Basic Attributes" section.
you can see three properties there:
Name: this value will be shown as the panel name listed under "Window->extensions" menu. Its default value is the same as the "panel name" attribute.
Extension ID: this is the ID that will be shown in "Extenson Manager", its default value is as "com.configurator.$Panelname" if the panel name meets the nameing rule. You can modify it to be another value. But sorry the "space" is not allowed here. This ID will also be the unique ID shown and used in Agora when you submit your "zxp" into it.
Version: the value will be shown under the "version" field of Extension Manager.
Wish this can help you.
Xiaoyan
Hello,
Thank you for your answer.
I understand that the default value is "com.configurator.$Panelname" by design.
Why the name of the author is "Configurator 3" and not mine?
I have an other problem with the description, instead of the name of my panel, there is "Configurator-Panel"
Many thanks.
Sebastien
North America
Asia Pacific
