CLCTV
Title Tool not updating / saving when making revisions
May 31, 2012 9:35 AM
Tags: #not #saving #tool #title #updating #revision #preimere
I've made a few Title's in Premiere Pro and saved them as templates to use through out my production. With CS6 I'm having some issues with it. I'll create a new Title file from a template and make the chages. Everything works fine for a while, but then the changes I make within the title tool do not save after exiting the title tool. The text just reverts back to the point were it stopped working. If I restart Premiere it works again, but only for a while. I think this is a bug, but if anybody has a solution please let me know. Thanks
Branched to a new discussion.
    May 31, 2012 10:55 AM   in reply to CLCTV
    Are you using the "New Title Based on Current Title" button in the upper left corner of the interface?
    Jun 1, 2012 5:42 AM   in reply to Kevin Monahan
    The same is happening with me.  I also tried making a new title but when I try that the only thing I can do is add new text, but I can't change the font, alignment, nor anything else.  It won't even save the new title into my bin.
    Mac Pro 1,1, Lion 10.7.4, CS6, ATI 5770  Premiere Pro 6.0.1
    Jun 3, 2012 10:57 AM   in reply to CLCTV
    I'm having a similar problem.  I duplicated a title in the Project window, and I can add text but not edit the previous text.  And once I edit a title, adding text, I can't edit the original text.   This has to be a bug.  I can't imagine why text would be rendered uneditable.
    Scott See
    www.hammock.net
    Jun 3, 2012 9:51 PM   in reply to scott_see
    You guys aren't leaving the CTI parked on the original title in the sequence are you?  That will cause it to show through when creating the new title.
    Jun 4, 2012 8:08 AM   in reply to Jim Simon
    I dragged the CTI way off to the side and tried duplicating a Title again.  No problem this time.
    Thanks!
    Scott See
    Jun 4, 2012 10:13 AM   in reply to CLCTV
    I've noticed what I think is a similar problem, but it's intermittent.  I tried to change the font size of a title, and it kept reverting to the original 100%.  The 3rd time it took, but it was annoying. The time it worked I didn't close the titler window immediately, perhaps giving it the extra time makes a difference.
    Jun 20, 2012 11:56 AM   in reply to Bill Engeler
    Has there been any solution to this?  I am encountering the same issue.
    Nov 9, 2012 4:33 AM   in reply to 13736dave
    Reboot premiere. Works.
    Mar 20, 2013 8:17 PM   in reply to yash-lucid
    I had to save and reopen as well. I guess it goes without saying, this is a bug that should be fixed.
    Mar 22, 2013 3:59 PM   in reply to denmarch7
    I don't see this behavior myself.  Hard to say if it's a bug or something else.
    Apr 1, 2013 7:57 AM   in reply to Kevin Monahan
    I am having a semi-related problem. I am using the text tool, and when I move text, after exit, it also reverts back to the place where it was before I moved it. Any ideas? (Sorry I'm a year late - don't know if anybody will see this...
    Apr 1, 2013 9:58 AM   in reply to Adobe Elements User
    Wow, with so many reporting similar, there must be something to it, but I have just never encountered it, and I do tons of Titles. The changes always update instantly for me.
    Maybe state the Sequence Settings, where this is happening, and where your Title appears (Video Track), relative to other Clips?
    I cannot help but think that this is Sequence, or Project specific, and that is why many others have never encountered it.
    Apr 1, 2013 10:34 AM   in reply to CLCTV
    That is good news, and thank you for that update (no pun intended).
    Appreciated,
    Jul 6, 2013 9:22 PM   in reply to CLCTV
    I had this same problem, and I followed CLCTV's guidance to do the update to 6.0.2 and now my titles are working just fine, THANKS!
    Apr 8, 2014 12:19 PM   in reply to CLCTV
    I am still encountering this problem in Premier Pro 6.0.5 – My titles will not save or update, including when using the "New Title Based On Current Title" button, and even brand new titles (they are all blank).
