• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
What's the method for updating a book?
Contributor ,
Jun 01, 2012 Jun 01, 2012
I use a variation of FrameMaker 10's FM_Outputs_CondText.jsx to automate generation of PDFs.
What do I need to add to force a book update?
It looked to me as if it were doing that, but I just noticed that the build date variable in the front matter is updated only when I manually update the book.
TOPICS
Scripting
Views
692
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate , Jun 04, 2012 Jun 04, 2012
To be a little more elaborate: I checked the script you mentioned and it only updates cross-references when opening a book and its files. That is not the same as updating the book and all its variables. You do need to use the Book.UpdateBook method for that explicitly, after first opening all files in the book. That amounts to the same as manually updating the book.
Ciao again
Votes
Translate
Translate
Advocate ,
The FrameMaker 10 Scripting Guide lists all the objects and methods. For the Book object, there is an UpdateBook method. I guess that is the one you are looking for. It is described on pages 435 and following.
Good luck
Votes
Translate
Translate
Report
Report
Advocate ,
Ciao again
Votes
Translate
Translate
Report
Report
Contributor ,
LATEST
Thanks. It turned out the problem was that somebody used the Modification Date system where they should have used the Current Date variable, after I fixed that the script works fine as is.
Votes
Translate
Translate
Report
Report
