Install New Software... not working
Jun 1, 2012 9:27 PM
Tags: #coldfusion_builder_2
When I click  Help > Install New Software....  Nothing happens. I even uninstalled ColdFusion Builder 2 and reinstalled it. The first time I installed it with as un administrator. Then ColdFusion Builder would say to run as Administrator. I did but still no install update wizard. Then I reinstalled as Administrator and and still nothing. Anyone have this issue?
    Jun 5, 2012 12:05 AM   in reply to winner73896545
    Can you please let us know on which OS did you faced this issue. Also mention the mode of installation you tried (Standalone or plug-in) ?
    Nov 14, 2012 7:29 AM   in reply to konatala
    Also having this problem, 'Help > Install New Software...' and 'Help > Check for Updates' don't open the wizard.
    Platform:
    Windows 7 64bit
    Service Pack 1
    ColdFusion Builder 2.0.1
    Build: 282422
    Installed plugins:
    Subclipse
    One note that may be related:
    From the 'Help > Product Details' About  page, I've tried the 'Installation Details' button, and that throws an error 'Fetching children of _SELF_'.  Error details:
    An internal error occurred during: "Fetching children of _SELF_".
    Registry Directory not available: P:\cfc\p2\org.eclipse.equinox.p2.engine\profileRegistry.
    Any help with this would be appreciated.
    Dec 20, 2012 10:48 AM   in reply to FelixDR
    Updating this post.
    Opened up the Eror Log - 'Window > Show View > Error Log'
    Clicked on 'Help > Install New Software'
    Error log is reporting:
    Message:
    eclipse.buildId=unknown
    java.version=1.6.0_29
    java.vendor=Sun Microsystems Inc.
    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
    Command-line arguments:  -os win32 -ws win32 -arch x86 -clean
    Error
    Thu Dec 20 13:46:30 EST 2012
    Unhandled event loop exception
    java.lang.IllegalStateException: Registry Directory not available: P:\cfc\p2\org.eclipse.equinox.p2.engine\profileRegistry.
        at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.restore( SimpleProfileRegistry.java:419)
        at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfi leMap(SimpleProfileRegistry.java:277)
        at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.internal GetProfile(SimpleProfileRegistry.java:238)
        at org.eclipse.equinox.internal.p2.engine.SimpleProfileRegistry.getProfi le(SimpleProfileRegistry.java:168)
        at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler.ex ecute(PreloadingRepositoryHandler.java:57)
        at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.ja va:293)
        at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
        at com.adobe.ide.coldfusion.rcp.intro.IDEInstallNewSoftwareHandler.execu te(Unknown Source)
        at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(Para meterizedCommand.java:508)
        at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(Handle rService.java:169)
        at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(S laveHandlerService.java:241)
        at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(Co mmandContributionItem.java:829)
        at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContrib utionItem.java:815)
        at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandCon tributionItem.java:805)
        at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
        at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
        at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
        at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
        at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
        at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
        at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
        at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
        at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.ja va:332)
        at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.jav a:668)
        at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
        at com.adobe.ide.coldfusion.rcp.intro.Application.start(Unknown Source)
        at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandl e.java:196)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runAppli cation(EclipseAppLauncher.java:110)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ec lipseAppLauncher.java:79)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:344)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:179)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl. java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:597)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
    Plug-in:
    org.eclipse.ui
    Has anyone run into this before - or have any ideas?
    Thanks.
