I want to download and install all programs and features to drive E.
Here's what I did:
(I didn't notice any options to change it's install location)
Installation Failed
Insufficient disk space. Please clear space on C:\ and try again. (-30)
I figure that it might be trying to download it to drive C before installing it to drive E, if that's the case then how can I change that so that it both downloads AND installs on drive E?
Some installers let you choose the install location (e.g. Adobe Reader), but others don't (I don't know about Photoshop, but I found this http://helpx.adobe.com/photoshop/kb/install-uninstall-photoshop-cs2.ht ml - see 5.).
To clear some space on the C: drive try http://www.piriform.com/ccleaner
Thank you Mylenium! This is exactly what I was looking for.
I changed the temp directory and at first it still wasn't working for me. There were two variables, TEMP and TMP.. I changed them both to the same folder on my other drive and now it seems to be working great!
Thanks again for the response!!
I'm trying to do the same thing.. I want to install my adobe products on my D: drive.. I looked at the environment variables but I guess I'm not sure how to change the Temp folder. Woudl that be by editing the system variables or user variables? Under User variables right now I am seeing a line that reads: "%USERPROFILE%\AppData\Local\Temp". Under the System variables I see a line that reads TEMP "C:\Windows|TEMP" but if I select it to edit I get "%SystemRoot%\TEMP" So what should I be doing here?
OK I found out that there is indeed a preference option in the Adobe Application Manager app that will let you set the path where you want to install your Adobe products. Click on your name and then preferences and there you will see it. I'm not sure about every application but so far I've installed Photoshop & Bridge, After Effects, and Premier Pro and they are installed on my D: drive where I wanted them.
North America
Asia Pacific
