Raging Joe
this project contains a sequance that could not be opened
Jun 2, 2012 9:54 AM
I am getting this error on Premiere CS6:
"this project contains a sequance that could not be opened"
And I can´t open projects. Tried to shift+alt and open but it happens again after I close.
Any idea on this?
    Jun 2, 2012 10:24 AM   in reply to Raging Joe
    Is that a CS5/CS5.5 project, or a new CS6 project that will not reopen?
    If an earlier version project, do you have any plugin effects?
    More information needed for someone to help... click these links and provided the requested information
    -http://forums.adobe.com/message/4200840
    Jun 2, 2012 11:45 AM   in reply to Raging Joe
    This error message is caused by the project having a sequence whose settings are no longer available to Premiere Pro.  One example is if the sequence was created on a system with third-party hardware, like AJA or Blackmagic, and you try opening it on a system without that hardware.  Another example is if the sequence uses MPEG for preview, and your MPEG codecs get smurfed.
    Jun 2, 2012 11:57 AM   in reply to Raging Joe
    Start a new project.  What sequence settings do you have available?
    Jun 2, 2012 12:33 PM   in reply to Raging Joe
    OK.
    Close all the folders and post another screen grab of the CS6 sequences.
    Jun 2, 2012 12:34 PM   in reply to Raging Joe
    Reinstall.
    Available sequences should look like this:
    Jun 2, 2012 3:13 PM   in reply to Raging Joe
    I have no idea what 3rd party compenents it is talking about.
    All your MPEG presets are missing.  That happens sometimes.  Here's what I've seen suggested as a fix.
    • Deactivate if possible
    • Uninstall
    • Run Clean Script several times, rebooting after each run
    • Install
    • Activate
    • Update
    Jun 2, 2012 3:18 PM   in reply to Raging Joe
    Don't know.  I've never used it.
    Jun 2, 2012 4:06 PM   in reply to Raging Joe
    If you install the complete suite again, no.
    Jul 1, 2012 5:43 PM   in reply to Harm Millaard
    Just deactivate and reactivate. No need to uninstall.
    The problem is that the activation system is broken, and that is preventing the unlocking of certain codecs.
    The recommended series of actions is this:
    1. Deactivate.
    2. Quite Premiere Pro.
    3. Restart your computer.
    4. Restart Premiere Pro.
    5. Activate.
    6. Create a new project.
    7. See if the MPEG-based and RED sequence presets are available. If so, open your project. If not, something else is wrong.
    Jan 28, 2013 4:23 PM   in reply to Todd_Kopriva
    This is an ongoing problem for me.  Is there a permanent fix for this or am I going to have to jump through hoops everytime I want to open a project?
