bjele
Indesign CS5.5 Not Splitting at Chapters on ePub Export
Jun 5, 2012 9:29 AM
Tags: #epub
I have a single document book in InDesign CS5.5. (Version 7.5.2)
The file is DFSS55ePub.indd. It is just a single .indd file, not a .indb
Every time on export to ePub, it is not respecting the Break Document at Paragraph Style: Chapter Title.
I get a single 444K .html file in the OEBPS folder of the resulting ePub.
Since that is over the 300K limit, it fails validation.
I've defined a table of contents called TOC
Level 1: Chapter Title (using a numbered List called Chapter)
Level 1: Chapter Title FM (No numbers for these headings in the front matter)
Level 2: QH  (These are subheads within the chapter. There are admittedly a lot of these - 160 across 10 chapters)
The file started its life as DFSS55Print.indd with facing pages, a printing table of contents and index. The current file is a single story, no facing pages. I deleted the index and table of contents since I knew the export to epub would do this anyway.
I did generate a Table of Contents in a frame on the pasteboard based on a suggestion in another topic.
When I export, the settings on the Contents tab are:
Format for EPUB Content: XHTML
Use InDesign TOC Style: TOC
Generate CSS
Include Style Definitions
I even tried exporting to IDML, opening, updating the table of contents, and re-exporting. Same problem.
I realize I could open in Sigil and split the html, but I swore after I upgraded to 5.5 I would never have to go back to Sigil.
Any ideas on what could be causing this?
Thanks in advance
Bill
