As I understand it, TextFonts is a collection of all fonts available to Illustraot. Is there a collection of all fonts used in the open document? Or would I have to step through every textFrame an create that list myself?
What kind of details do you want? From "xmlString" you can get:
<xmpTPg:Fonts>
<rdf:Bag>
<rdf:li rdf:parseType="Resource">
<stFnt:fontName>Arial-Black</stFnt:fontName>
<stFnt:fontFamily>Arial</stFnt:fontFamily>
<stFnt:fontFace>Black</stFnt:fontFace>
<stFnt:fontType>Open Type</stFnt:fontType>
<stFnt:versionString>Version 5.06</stFnt:versionString>
<stFnt:composite>False</stFnt:composite>
<stFnt:fontFileName>ariblk.ttf</stFnt:fontFileName>
</rdf:li>
</rdf:Bag>
</xmpTPg:Fonts>
If you want process multiple files, you can load the XMP library to parse details instead of open every document with illustrator to get xmlString.
Please find my script below, it gives me script log file in txt format. but this works only for single file i need this for the entire files in the folder
And also i need the script error log for the open type and true type only not for ATM fonts
#target illustrator
var inputFolder = Folder.selectDialog("Select a folder contains '*.eps' files ");
var Loginfo = new File(inputFolder + "/Font.info.txt");
Loginfo.open("w", "TEXT", "????");
if (inputFolder) {
var fileList = inputFolder.getFiles('*.eps');
for (var i = 0; i < fileList.length; i++) {
if (fileList[i] instanceof File && fileList[i].hidden == false) {
var doc = app.open(fileList[i]);
doc.textFrames.length && writeLog(doc);
doc.close(SaveOptions.DONOTSAVECHANGES);
Loginfo.close();
// load the library
function writeLog(a) {
if (ExternalObject.AdobeXMPScript == undefined) {
ExternalObject.AdobeXMPScript = new
ExternalObject("lib:AdobeXMPScript");
var ns = "http://ns.adobe.com/xap/1.0/t/pg/"; // Fonts namespace
var propName = "Fonts"; // property name
var fieldFontName = "stFnt:fontName"; // field name
var fieldFontType = "stFnt:fontType"; // field name
var msg = ""
//Create an XMPMeta object from the active documents XMPString:
var myXmp = new XMPMeta(app.activeDocument.XMPString);
var fontNumber = myXmp.countArrayItems(ns,propName); // activeDocument used font count
if (fontNumber !=0) // if there's at least 1 font, proceed
for (i=1; i<=fontNumber; i++)
var fontname = myXmp.getProperty(ns,propName + "[" + i + "]" + fieldFontName);
var fonttype = myXmp.getProperty(ns,propName + "[" + i + "]" + fieldFontType);
msg += i + ". " + fontname + " - " + fonttype + "\n";
Loginfo.writeln("File: " + a.name + fontname + fonttype );
//alert(fonttype)
//if(fonttype == "Open Type"||"True Type"){
//alert(msg,"Font details",);
//alert(msg);
//else
Please advice us as i am not good in the scripting.
I don't know why and how you write error log, so I only add a single alert after all. "xmpString" and "XMP library" are two different methods, you only need one of then.
#target illustrator
if (inputFolder) {
var fileList = inputFolder.getFiles('*.eps'),
fontsInfo = [];
loadXMPLibrary();
fontsInfo.push(getFontsInfo(fileList[i]));
unloadXMPLibrary();
var Loginfo = new File(inputFolder + '/Font.info.txt');
Loginfo.open('w', 'TEXT', '????');
var info = fontsInfo.join('\n\n');
Loginfo.write(info);
Loginfo.close();
if (/(Open Type|TrueType)/.test(info)) {
alert('Open Type / TrueType font found, see log file for details!')
function getFontsInfo(file) {
var arr = ['File: ' + decodeURI (file.name)],
xmpFile, oXmp, fontNumber, i, path, fontname, fonttype, ns = 'http://ns.adobe.com/xap/1.0/t/pg/';
xmpFile = new XMPFile(file.fsName, XMPConst.UNKNOWN, XMPConst.OPEN_FOR_READ);
oXmp = xmpFile.getXMP(); //Returns an XMPMeta object
fontNumber = oXmp.countArrayItems(ns, 'xmpTPg:Fonts');
xmpFile.closeFile(XMPConst.CLOSE_UPDATE_SAFELY);
if (fontNumber) { // if there's at least 1 font, proceed
for (i = 1; i <= fontNumber; i++) {
path = XMPUtils.composeArrayItemPath(ns, 'xmpTPg:Fonts', i);
fontname = oXmp.getStructField(ns, path, XMPConst.TYPE_FONT, 'fontName');
fonttype = oXmp.getStructField(ns, path, XMPConst.TYPE_FONT, 'fontType');
arr.push([i, '. ', fontname, '-', fonttype].join(''));
return arr.join('\n');
function loadXMPLibrary() {
if (!ExternalObject.AdobeXMPScript) {
try {
ExternalObject.AdobeXMPScript = new ExternalObject('lib:AdobeXMPScript');
} catch (e) {
alert('Unable to load the AdobeXMPScript library!');
return false;
return true;
function unloadXMPLibrary() {
if (ExternalObject.AdobeXMPScript) {
try {
ExternalObject.AdobeXMPScript.unload();
ExternalObject.AdobeXMPScript = undefined;
} catch (e) {
alert('Unable to unload the AdobeXMPScript library!');
Thanks for the reply,
This works fine, I need litte adjustment in this script.
I need the log file to be writen only for the Open type and true type fonts.
ATM font is fine for us.
In addition i have another script for Text in grayscale this gives the details of the color info of the eps files.
Could you please combine both the script into a single script.
In need the log file in single format.
The text in gray scale is below
#target illustrator
var Loginfo = new File(inputFolder + "/Sep_preview.txt");
if (inputFolder) {
Loginfo.close();
//This function is to check the text objects in the document whether it contains any color text (non black text).
var i = 0, text = a.textFrames, len = text.length;
for (; i < len; i++) {
if (String(text[i].textRange.fillColor).search("Gray") != 1) {
Loginfo.writeln("File: " + a.name + " Text not in Black");
return
North America
Asia Pacific
