Cannot enable Mercury Playback Engine GPU Acceleration
Jun 7, 2012 8:05 AM
Tags: #pro #nvidia #cuda #premiere
Cannot enable Mercury Playback Engine GPU Acceleration.
Just bought a Asus GeForce GTX 560 Ti just so that I can use the graphics acceleration on Adobe Premiere Pro CS5.
Followed every step in most tutorials such as this great one http://vimeo.com/13440307 and yet the Mercury Playback Engine GPU Acceleration option is still faded out.
http://www.urbanistgame.com/wp-content/uploads/2012/06/Cuda-supported. gifAdded the last two lines as wasn't sure if it required "Ti" it only came up as "supported" in the cmd after the "Ti" so I'm guess that's what it required.
You can see in bold I've set the Multi-display/mixed-GPU acceleration option to "Compatibility performance mode"
   Splash screen confirms Version as 5.0.3 (update to enable Mercury Playback Engine GPU Acceleration).
After all that the "Video Rendering and Playback" option is still faded out.
Any ideas? System Information
List of installed Nvidia programs
Hope someone can help.
    Jun 7, 2012 8:16 AM   in reply to faz007
    1. Did you restart Pr?
    2. Did the .txt file save properly?  Usually, it requires elevated admin privileges to modify it.  Run Notepad as Administrator should work.
    3. Try setting the Global 3D settings to Let the Application Decide.
    4. Simply delete the cuda_supported_cards.txt file and re-launch Pr.
    Jeff
    Jun 7, 2012 9:11 AM   in reply to faz007
    3. Here:
    4. Try it.  Send it to the Recycle Bin just in case.
    Jeff
    Jun 7, 2012 9:54 AM   in reply to faz007
    Hi Faz,
    Two things to try.
    1. Go back into the cuda_supported_cards.txt file and make sure there is
    NOT a space at the end of each line. They need to end on a character and
    not a space. If there is a space, the video card entry will not be seen by
    Premiere.
    2. Re-Install the NVidia drivers and do a clean install. Follow the first
    two steps in this article
    http://www.studio1productions.com/Articles/Nvidia.htm
    Please let me know how you make out.
    Dave
    Jun 7, 2012 10:15 AM   in reply to faz007
    I have the same card that you do, and it works here.  So something is different with your hardware or system setup.  You did a good job with the initial barrage of screenshots, but some more info is needed.  A good list of required info is here:
    Adobe Forums: FAQ: What information should I provide when asking a question on this forum?
    Jeff
    Jun 7, 2012 11:25 AM   in reply to faz007
    >clean install of CS6 in the default location. Thats gonna eat up my SSD
    Does that mean you installed to something other than your boot drive?
    Jun 7, 2012 2:31 PM   in reply to faz007
    Logical, it is waiting for your slow CPU to catch up.
    Jun 7, 2012 2:46 PM   in reply to faz007
    >reinstalled CS5 on the bookdisk and it worked fine
    I have read other messages that Premiere does not like being installed on anything other than the boot drive
