estonianboy
Cannot uninstall Adobe Air, even though it won't run.
Jun 9, 2012 8:06 PM
Tags: #installation #adobe_air
Hi there,
After having problems with an Adobe Air based program (BBC iplayer Desktop) suddenly deciding that it wouldn't list any of the downloaded programs (28GB worth) anymore, even the programs are still where they have always been on the HD, I tried countless different actions to rectify the problem. One of them was to uninstall and then reinstall the BBC iplayer Desktop and Adobe Air 3.3. I did this a few times, but the problem remained. Getting a bit desperate, I tried System Restore in Windows Vista 32bit, running it back to a time when iplayer desktop worked fine. After the System Restore, I was informed that the version of Adobe Air was corrupted and needed to be reinstalled. On trying to uninstall from the programs and features menu within Control Panel, no uninstall took place. However running the Adobe Air 3.3 Installer file on it's own led to Adobe Air working again, even if BBC iplayer Desktop was not. I therefore undid the System Restore as it made no difference to the original problem and was once again informed that Adobe Air was corrupted and needed to be reinstalled. Once again I tried to uninstall it from within programs and features, but to no avail. I then tried to install Adobe Air 3.3 from the stand alone installer again. This time the installer informed me that Adobe Air 3.3 was already successfully installed, which of course it is not. So what on earth can I try now? I've included a copy of the install.txt file below. Any help would be most appreciated!
[2012-06-03:20:00:55] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:00:55] Application Installer end with exit code 0
[2012-06-03:20:00:57] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:00:57] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6800300385802984 onApplicationVersion
[2012-06-03:20:00:57] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:00:57] Application Installer end with exit code 0
[2012-06-03:20:01:03] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:01:03] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6890575746074319 onApplicationVersion
[2012-06-03:20:01:03] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:01:03] Application Installer end with exit code 0
[2012-06-03:20:01:03] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7972573516890407 onApplicationVersion
[2012-06-03:20:01:04] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:01:04] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqaGoyMC8= b01jhj17 2500 0 My4w b01jhj20 null "
[2012-06-03:20:01:04] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:01:04] Application Installer end with exit code 0
[2012-06-03:20:01:14] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:01:14] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.07586528221145272 onApplicationVersion
[2012-06-03:20:01:14] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:01:14] Application Installer end with exit code 0
[2012-06-03:20:01:41] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:01:41] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8918536487035453 onApplicationVersion
[2012-06-03:20:01:41] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:01:41] Application Installer end with exit code 0
[2012-06-03:20:01:41] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3358655022457242 onApplicationVersion
[2012-06-03:20:01:42] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:01:42] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9wMDByZGp2bi8= b01hkyvh 2500 0 My4w p00rdjvn null "
[2012-06-03:20:01:42] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:01:42] Application Installer end with exit code 0
[2012-06-03:20:01:48] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:01:48] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7281139111146331 onApplicationVersion
[2012-06-03:20:01:48] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:01:48] Application Installer end with exit code 0
[2012-06-03:20:01:48] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.980444798246026 onApplicationVersion
[2012-06-03:20:01:51] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:01:51] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9wMDByZGp2bi8= b01hkyvh 2500 0 My4w p00rdjvn null "
[2012-06-03:20:01:51] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:01:51] Application Installer end with exit code 0
[2012-06-03:20:01:53] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:01:53] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4647400490939617 onApplicationVersion
[2012-06-03:20:01:53] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:01:53] Application Installer end with exit code 0
[2012-06-03:20:02:04] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:02:04] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9wMDByZGp2bi8= b01hkyvh 2500 0 My4w p00rdjvn null "
[2012-06-03:20:02:04] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:02:04] Application Installer end with exit code 0
[2012-06-03:20:02:17] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:02:17] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9798997435718775 onApplicationVersion
[2012-06-03:20:02:17] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:02:17] Application Installer end with exit code 0
[2012-06-03:20:02:18] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:02:18] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.573088797274977 onApplicationVersion
[2012-06-03:20:02:18] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:02:18] Application Installer end with exit code 0
[2012-06-03:20:02:18] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.873427857644856 onApplicationVersion
[2012-06-03:20:02:20] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:02:20] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9wMDBwcWJmai8= b01h083t 2500 0 My4w p00pqbfj null "
[2012-06-03:20:02:20] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:02:20] Application Installer end with exit code 0
[2012-06-03:20:02:22] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:02:22] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8686890318058431 onApplicationVersion
[2012-06-03:20:02:22] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:02:22] Application Installer end with exit code 0
[2012-06-03:20:02:28] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:02:28] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5924168373458087 onApplicationVersion
[2012-06-03:20:02:28] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:02:28] Application Installer end with exit code 0
[2012-06-03:20:02:28] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8133757077157497 onApplicationVersion
[2012-06-03:20:02:29] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:02:29] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFoN21qcC8= b01h7mjk 2500 0 My4w b01h7mjp null "
[2012-06-03:20:02:29] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:02:29] Application Installer end with exit code 0
[2012-06-03:20:02:32] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:02:32] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7369150388985872 onApplicationVersion
[2012-06-03:20:02:32] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:02:32] Application Installer end with exit code 0
[2012-06-03:20:02:57] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:02:57] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5099142659455538 onApplicationVersion
[2012-06-03:20:02:57] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:02:57] Application Installer end with exit code 0
[2012-06-03:20:03:03] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:03:03] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.2777740997262299 onApplicationVersion
[2012-06-03:20:03:03] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:03:03] Application Installer end with exit code 0
[2012-06-03:20:03:13] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:03:13] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4631973262876272 onApplicationVersion
[2012-06-03:20:03:13] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:03:13] Application Installer end with exit code 0
[2012-06-03:20:03:13] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.12710570311173797 onApplicationVersion
[2012-06-03:20:03:16] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:03:16] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9wMDBxZ3I3Ny8= b01gxjv6 2500 0 My4w p00qgr77 null "
[2012-06-03:20:03:16] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:03:16] Application Installer end with exit code 0
[2012-06-03:20:03:31] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:03:31] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.10452864924445748 onApplicationVersion
[2012-06-03:20:03:31] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:03:31] Application Installer end with exit code 0
[2012-06-03:20:04:08] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:04:08] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9175295354798436 onApplicationVersion
[2012-06-03:20:04:08] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:04:08] Application Installer end with exit code 0
[2012-06-03:20:04:49] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-03:20:04:49] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8617058913223445 onApplicationVersion
[2012-06-03:20:04:49] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-03:20:04:49] Application Installer end with exit code 0
[2012-06-04:02:20:00] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-04:02:20:00] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.21324462164193392 onApplicationVersion
[2012-06-04:02:20:00] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-04:02:20:00] Application Installer end with exit code 0
[2012-06-04:02:20:03] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-04:02:20:03] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.44151102332398295 onApplicationVersion
[2012-06-04:02:20:03] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-04:02:20:03] Application Installer end with exit code 0
[2012-06-04:02:20:03] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4182365043088794 onApplicationVersion
[2012-06-04:02:20:14] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-04:02:20:14] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.37231224635615945 onApplicationVersion
[2012-06-04:02:20:14] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-04:02:20:14] Application Installer end with exit code 0
[2012-06-04:02:20:23] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-04:02:20:23] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.531041675247252 onApplicationVersion
[2012-06-04:02:20:23] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-04:02:20:23] Application Installer end with exit code 0
[2012-06-04:02:21:16] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-04:02:21:16] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7349629872478545 onApplicationVersion
[2012-06-04:02:21:16] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-04:02:21:16] Application Installer end with exit code 0
[2012-06-04:02:21:21] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-04:02:21:21] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5421080240048468 onApplicationVersion
[2012-06-04:02:21:21] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-04:02:21:22] Application Installer end with exit code 0
[2012-06-04:02:21:22] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-04:02:21:22] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4736835607327521 onApplicationVersion
[2012-06-04:02:21:22] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-04:02:21:24] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-04:02:21:24] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9732577572576702 onApplicationVersion
[2012-06-04:02:21:24] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-04:02:21:24] Application Installer end with exit code 0
[2012-06-04:02:21:29] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-04:02:21:29] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.2052983958274126 onApplicationVersion
[2012-06-04:02:21:29] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-04:02:21:29] Application Installer end with exit code 0
[2012-06-04:02:22:39] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-04:02:22:39] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.27935636555776 onApplicationVersion
[2012-06-04:02:22:39] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-04:02:22:39] Application Installer end with exit code 0
[2012-06-04:02:22:55] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-04:02:22:55] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.08542867423966527 onApplicationVersion
[2012-06-04:02:22:55] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-04:02:22:55] Application Installer end with exit code 0
[2012-06-05:02:23:47] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:02:23:47] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3848238689824939 onApplicationVersion
[2012-06-05:02:23:47] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:02:23:47] Application Installer end with exit code 0
[2012-06-05:18:19:20] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:18:19:20] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7227345746941864 onApplicationVersion
[2012-06-05:18:19:20] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:18:19:20] Application Installer end with exit code 0
[2012-06-05:18:19:44] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:18:19:44] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.15147437620908022 onApplicationVersion
[2012-06-05:18:19:44] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:18:19:44] Application Installer end with exit code 0
[2012-06-05:18:19:50] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:18:19:50] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.836393007542938 onApplicationVersion
[2012-06-05:18:19:50] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:18:19:50] Application Installer end with exit code 0
[2012-06-05:18:19:53] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:18:19:53] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.43879877822473645 onApplicationVersion
[2012-06-05:18:19:53] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:18:19:53] Application Installer end with exit code 0
[2012-06-05:18:19:53] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.16644199565052986 onApplicationVersion
[2012-06-05:18:19:58] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:18:19:58] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9wMDBuaDkyNS8= b01jmpdd 2500 0 My4w p00nh925 null "
[2012-06-05:18:19:58] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:18:19:58] Application Installer end with exit code 0
[2012-06-05:18:20:03] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:18:20:03] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3932350240647793 onApplicationVersion
[2012-06-05:18:20:03] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:18:20:03] Application Installer end with exit code 0
[2012-06-05:18:20:33] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:18:20:33] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5189227033406496 onApplicationVersion
[2012-06-05:18:20:33] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:18:20:33] Application Installer end with exit code 0
[2012-06-05:18:20:37] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:18:20:37] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.14154766965657473 onApplicationVersion
[2012-06-05:18:20:37] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:18:20:37] Application Installer end with exit code 0
[2012-06-05:18:20:37] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.799241510219872 onApplicationVersion
[2012-06-05:18:20:43] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:18:20:43] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.10579763446003199 onApplicationVersion
[2012-06-05:18:20:43] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:18:20:43] Application Installer end with exit code 0
[2012-06-05:18:20:46] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:18:20:46] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3079254552721977 onApplicationVersion
[2012-06-05:18:20:46] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:18:20:46] Application Installer end with exit code 0
[2012-06-05:18:20:46] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8509125034324825 onApplicationVersion
[2012-06-05:18:20:47] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:18:20:47] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqbXA0dy8= b01jmnx2 2500 0 My4w b01jmp4w null "
[2012-06-05:18:20:47] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:18:20:47] Application Installer end with exit code 0
[2012-06-05:18:21:15] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:18:21:15] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.34401776222512126 onApplicationVersion
[2012-06-05:18:21:15] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:18:21:15] Application Installer end with exit code 0
[2012-06-05:18:21:18] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-05:18:21:18] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8598949802108109 onApplicationVersion
[2012-06-05:18:21:18] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-05:18:21:18] Application Installer end with exit code 0
[2012-06-06:02:31:48] Launching subprocess with commandline c:\Program Files\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater -updatecheck
[2012-06-06:02:31:48] Runtime Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:02:31:48] Commandline is: -updatecheck
[2012-06-06:02:31:48] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:02:31:49] Performing pingback request
[2012-06-06:02:31:49] Starting runtime background update check
[2012-06-06:02:31:49] Clearing unused background update directory
[2012-06-06:02:31:49] Begin Background update download from http://airdownload.adobe.com/air/3/background/windows6.0/x86/patch/3.2 .0.2070/update
[2012-06-06:02:31:49] Unpackaging http://airdownload.adobe.com/air/3/background/windows6.0/x86/patch/3.2 .0.2070/update to C:\Users\Administrator\AppData\Roaming\Adobe\AIR\Updater\Background
[2012-06-06:02:31:50] Runtime update not available
[2012-06-06:02:31:50] Unpackaging cancelled
[2012-06-06:02:31:50] Runtime Installer end with exit code 0
[2012-06-06:02:59:23] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:02:59:23] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6893021799623966 onApplicationVersion
[2012-06-06:02:59:23] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:02:59:24] Application Installer end with exit code 0
[2012-06-06:02:59:26] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:02:59:26] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.2708099354058504 onApplicationVersion
[2012-06-06:02:59:26] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:02:59:26] Application Installer end with exit code 0
[2012-06-06:02:59:26] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.08067945530638099 onApplicationVersion
[2012-06-06:02:59:44] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:02:59:44] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.22462021140381694 onApplicationVersion
[2012-06-06:02:59:44] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:02:59:44] Application Installer end with exit code 0
[2012-06-06:03:08:29] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:08:29] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8528783256188035 onApplicationVersion
[2012-06-06:03:08:29] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:08:29] Application Installer end with exit code 0
[2012-06-06:03:24:09] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:24:09] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5116631337441504 onApplicationVersion
[2012-06-06:03:24:09] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:24:09] Application Installer end with exit code 0
[2012-06-06:03:24:17] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:24:17] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9886791668832302 onApplicationVersion
[2012-06-06:03:24:17] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:24:17] Application Installer end with exit code 0
[2012-06-06:03:24:21] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:24:21] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5571882715448737 onApplicationVersion
[2012-06-06:03:24:21] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:24:21] Application Installer end with exit code 0
[2012-06-06:03:24:21] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.41547881066799164 onApplicationVersion
[2012-06-06:03:24:21] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFjOTlubS8= b01c99nc 2500 0 My4w b01c99nm null "
[2012-06-06:03:24:26] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:24:26] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7323967730626464 onApplicationVersion
[2012-06-06:03:24:26] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:24:26] Application Installer end with exit code 0
[2012-06-06:03:24:33] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:24:33] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4032350601628423 onApplicationVersion
[2012-06-06:03:24:33] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:24:33] Application Installer end with exit code 0
[2012-06-06:03:24:53] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:24:53] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6054279981181026 onApplicationVersion
[2012-06-06:03:24:53] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:24:53] Application Installer end with exit code 0
[2012-06-06:03:25:04] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:25:04] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3810878633521497 onApplicationVersion
[2012-06-06:03:25:04] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:25:04] Application Installer end with exit code 0
[2012-06-06:03:25:04] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8470850680023432 onApplicationVersion
[2012-06-06:03:25:09] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:25:09] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.09703342197462916 onApplicationVersion
[2012-06-06:03:25:09] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:25:09] Application Installer end with exit code 0
[2012-06-06:03:25:09] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7169516319409013 onApplicationVersion
[2012-06-06:03:25:10] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:25:10] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqbXQ1dC8= b01jmsm3 2500 0 My4w b01jmt5t null "
[2012-06-06:03:25:10] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:25:10] Application Installer end with exit code 0
[2012-06-06:03:25:16] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:25:16] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.16966204391792417 onApplicationVersion
[2012-06-06:03:25:16] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:25:16] Application Installer end with exit code 0
[2012-06-06:03:25:19] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:25:19] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.013330970890820026 onApplicationVersion
[2012-06-06:03:25:19] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:25:19] Application Installer end with exit code 0
[2012-06-06:03:25:21] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:25:21] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.20727774128317833 onApplicationVersion
[2012-06-06:03:25:21] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:25:21] Application Installer end with exit code 0
[2012-06-06:03:25:21] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8690670221112669 onApplicationVersion
[2012-06-06:03:25:21] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqY2M4Yi8= b01jcc45 2500 0 My4w b01jcc8b null "
[2012-06-06:03:25:34] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:25:34] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5327624599449337 onApplicationVersion
[2012-06-06:03:25:34] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:25:34] Application Installer end with exit code 0
[2012-06-06:03:25:40] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:25:40] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.009500272572040558 onApplicationVersion
[2012-06-06:03:25:40] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:25:40] Application Installer end with exit code 0
[2012-06-06:03:25:57] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:25:57] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7355884788557887 onApplicationVersion
[2012-06-06:03:25:57] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:25:57] Application Installer end with exit code 0
[2012-06-06:03:26:12] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:26:12] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8342597223818302 onApplicationVersion
[2012-06-06:03:26:12] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:26:12] Application Installer end with exit code 0
[2012-06-06:03:26:12] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9304666486568749 onApplicationVersion
[2012-06-06:03:26:13] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:26:13] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqZzBudC8= b00wx7c2 2500 0 My4w b01jg0nt null "
[2012-06-06:03:26:13] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:26:13] Application Installer end with exit code 0
[2012-06-06:03:26:20] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:26:20] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3400919623672962 onApplicationVersion
[2012-06-06:03:26:20] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:26:20] Application Installer end with exit code 0
[2012-06-06:03:26:25] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:26:25] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3292773817665875 onApplicationVersion
[2012-06-06:03:26:25] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:26:25] Application Installer end with exit code 0
[2012-06-06:03:26:25] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.947293862234801 onApplicationVersion
[2012-06-06:03:26:25] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqZzBudC8= b00wx7c2 2500 0 My4w b01jg0nt null "
[2012-06-06:03:26:53] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:26:53] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.34116240544244647 onApplicationVersion
[2012-06-06:03:26:53] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:26:53] Application Installer end with exit code 0
[2012-06-06:03:26:54] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:26:54] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4332156842574477 onApplicationVersion
[2012-06-06:03:26:54] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:26:54] Application Installer end with exit code 0
[2012-06-06:03:26:54] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5212300689890981 onApplicationVersion
[2012-06-06:03:26:55] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:26:55] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqbXE5cS8= b01jmq8c 2500 0 My4w b01jmq9q null "
[2012-06-06:03:26:55] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:26:55] Application Installer end with exit code 0
[2012-06-06:03:27:20] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:03:27:20] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.33871179912239313 onApplicationVersion
[2012-06-06:03:27:20] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:03:27:20] Application Installer end with exit code 0
[2012-06-06:23:31:08] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:23:31:08] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8185103726573288 onApplicationVersion
[2012-06-06:23:31:08] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:23:31:08] Application Installer end with exit code 0
[2012-06-06:23:31:15] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:23:31:15] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9448050451464951 onApplicationVersion
[2012-06-06:23:31:15] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:23:31:15] Application Installer end with exit code 0
[2012-06-06:23:31:22] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:23:31:22] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9414487425237894 onApplicationVersion
[2012-06-06:23:31:22] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:23:31:22] Application Installer end with exit code 0
[2012-06-06:23:31:28] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:23:31:28] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5979450764134526 onApplicationVersion
[2012-06-06:23:31:28] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:23:31:28] Application Installer end with exit code 0
[2012-06-06:23:31:31] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:23:31:31] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7093738876283169 onApplicationVersion
[2012-06-06:23:31:31] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:23:31:33] Application Installer end with exit code 0
[2012-06-06:23:31:33] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:23:31:33] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqcmxzZi8= b01jrls7 2500 0 My4w b01jrlsf null "
[2012-06-06:23:31:33] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:23:31:48] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:23:31:48] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5184684582054615 onApplicationVersion
[2012-06-06:23:31:48] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:23:31:48] Application Installer end with exit code 0
[2012-06-06:23:36:20] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:23:36:20] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8674118313938379 onApplicationVersion
[2012-06-06:23:36:20] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:23:36:20] Application Installer end with exit code 0
[2012-06-06:23:39:08] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:23:39:08] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6527324547059834 onApplicationVersion
[2012-06-06:23:39:08] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:23:39:08] Application Installer end with exit code 0
[2012-06-06:23:39:08] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.299543384462595 onApplicationVersion
[2012-06-06:23:39:08] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFna3BnNC9zaWduL w== b01jrt0w 2500 0 My4w b01gkpg4 null "
[2012-06-06:23:42:29] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-06:23:42:29] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.47920897928997874 onApplicationVersion
[2012-06-06:23:42:29] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-06:23:42:29] Application Installer end with exit code 0
[2012-06-07:19:37:54] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-07:19:37:54] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.1863403543829918 onApplicationVersion
[2012-06-07:19:37:54] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-07:19:37:54] Application Installer end with exit code 0
[2012-06-09:00:41:35] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:00:41:35] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.06774656241759658 onApplicationVersion
[2012-06-09:00:41:35] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:00:41:35] Application Installer end with exit code 0
[2012-06-09:00:41:55] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:00:41:55] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.39968983037397265 onApplicationVersion
[2012-06-09:00:41:55] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:00:41:55] Application Installer end with exit code 0
[2012-06-09:00:42:00] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:00:42:00] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.812603575643152 onApplicationVersion
[2012-06-09:00:42:00] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:00:42:00] Application Installer end with exit code 0
[2012-06-09:00:42:21] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:00:42:21] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5648137554526329 onApplicationVersion
[2012-06-09:00:42:21] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:00:42:21] Application Installer end with exit code 0
[2012-06-09:00:42:40] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:00:42:40] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.40000650053843856 onApplicationVersion
[2012-06-09:00:42:40] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:00:42:40] Application Installer end with exit code 0
[2012-06-09:00:43:56] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:00:43:56] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6643671100027859 onApplicationVersion
[2012-06-09:00:43:56] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:00:43:56] Application Installer end with exit code 0
[2012-06-09:17:40:01] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:40:01] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.433096026070416 onApplicationVersion
[2012-06-09:17:40:01] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:40:01] Application Installer end with exit code 0
[2012-06-09:17:40:06] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:40:06] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9827269520610571 onApplicationVersion
[2012-06-09:17:40:06] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:40:06] Application Installer end with exit code 0
[2012-06-09:17:40:16] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:40:16] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6338226781226695 onApplicationVersion
[2012-06-09:17:40:16] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:40:16] Application Installer end with exit code 0
[2012-06-09:17:40:16] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3891263329423964 onApplicationVersion
[2012-06-09:17:40:17] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:40:17] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9wMDBwcWJmai8= b01h083t 2500 0 My4w p00pqbfj null "
[2012-06-09:17:40:17] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:40:17] Application Installer end with exit code 0
[2012-06-09:17:41:11] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:41:11] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.41994029376655817 onApplicationVersion
[2012-06-09:17:41:11] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:41:11] Application Installer end with exit code 0
[2012-06-09:17:41:20] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:41:20] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9394125542603433 onApplicationVersion
[2012-06-09:17:41:20] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:41:20] Application Installer end with exit code 0
[2012-06-09:17:41:23] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:41:23] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.28255286160856485 onApplicationVersion
[2012-06-09:17:41:23] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:41:23] Application Installer end with exit code 0
[2012-06-09:17:41:23] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.06683188863098621 onApplicationVersion
[2012-06-09:17:41:24] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:41:24] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqMmZjcS8= b01j2fb9 2500 0 My4w b01j2fcq null "
[2012-06-09:17:41:24] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:41:24] Application Installer end with exit code 0
[2012-06-09:17:42:00] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:42:00] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6777877192944288 onApplicationVersion
[2012-06-09:17:42:00] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:42:00] Application Installer end with exit code 0
[2012-06-09:17:43:41] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:43:41] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.40669478103518486 onApplicationVersion
[2012-06-09:17:43:41] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:43:41] Application Installer end with exit code 0
[2012-06-09:17:43:49] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:43:49] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7307401918806136 onApplicationVersion
[2012-06-09:17:43:49] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:43:49] Application Installer end with exit code 0
[2012-06-09:17:45:40] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:45:40] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6100839404389262 onApplicationVersion
[2012-06-09:17:45:40] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:45:40] Application Installer end with exit code 0
[2012-06-09:17:47:01] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:47:01] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.23164898715913296 onApplicationVersion
[2012-06-09:17:47:01] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:47:01] Application Installer end with exit code 0
[2012-06-09:17:47:05] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:47:05] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.15858520474284887 onApplicationVersion
[2012-06-09:17:47:05] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:47:05] Application Installer end with exit code 0
[2012-06-09:17:47:05] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.19450878398492932 onApplicationVersion
[2012-06-09:17:47:05] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqMmZjcS8= b01j2fb9 2500 0 My4w b01j2fcq null "
[2012-06-09:17:47:08] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:17:47:08] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5062600374221802 onApplicationVersion
[2012-06-09:17:47:08] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:17:47:08] Application Installer end with exit code 0
[2012-06-09:21:08:33] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:21:08:33] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8576160408556461 onApplicationVersion
[2012-06-09:21:08:33] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:21:08:33] Application Installer end with exit code 0
[2012-06-09:22:03:10] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:03:10] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.0294821267016232 onApplicationVersion
[2012-06-09:22:03:10] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:03:10] Application Installer end with exit code 0
[2012-06-09:22:03:28] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:03:28] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7648956328630447 onApplicationVersion
[2012-06-09:22:03:28] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:03:28] Application Installer end with exit code 0
[2012-06-09:22:04:08] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:04:08] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5572112710215151 onApplicationVersion
[2012-06-09:22:04:08] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:04:08] Application Installer end with exit code 0
[2012-06-09:22:04:28] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:04:28] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4153113039210439 onApplicationVersion
[2012-06-09:22:04:28] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:04:28] Application Installer end with exit code 0
[2012-06-09:22:05:03] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:05:03] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8453543581999838 onApplicationVersion
[2012-06-09:22:05:03] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:05:03] Application Installer end with exit code 0
[2012-06-09:22:05:14] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:05:14] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9035109663382173 onApplicationVersion
[2012-06-09:22:05:14] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:05:14] Application Installer end with exit code 0
[2012-06-09:22:05:28] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:05:28] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.41008166829124093 onApplicationVersion
[2012-06-09:22:05:28] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:05:28] Application Installer end with exit code 0
[2012-06-09:22:46:49] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:46:49] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9532648692838848 onApplicationVersion
[2012-06-09:22:46:49] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:46:49] Application Installer end with exit code 0
[2012-06-09:22:47:21] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:47:21] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6398530476726592 onApplicationVersion
[2012-06-09:22:47:21] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:47:21] Application Installer end with exit code 0
[2012-06-09:22:48:43] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:48:43] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8929452421143651 onApplicationVersion
[2012-06-09:22:48:43] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:48:43] Application Installer end with exit code 0
[2012-06-09:22:49:07] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:49:07] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6670562904328108 onApplicationVersion
[2012-06-09:22:49:07] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:49:07] Application Installer end with exit code 0
[2012-06-09:22:49:11] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:49:11] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.539048592094332 onApplicationVersion
[2012-06-09:22:49:11] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:49:11] Application Installer end with exit code 0
[2012-06-09:22:49:11] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.13692229008302093 onApplicationVersion
[2012-06-09:22:49:12] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:49:12] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7579852268099785 onApplicationVersion
[2012-06-09:22:49:12] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:49:12] Application Installer end with exit code 0
[2012-06-09:22:49:13] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:49:13] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8715528533793986 onApplicationVersion
[2012-06-09:22:49:13] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:49:13] Application Installer end with exit code 0
[2012-06-09:22:49:14] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:49:14] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqazVuZw== b01jk5nd 2500 0 My4w b01jk5ng normal "
[2012-06-09:22:49:14] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:49:15] Begin air file download from http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-09:22:49:15] Download destination is C:\Users\Administrator\AppData\Local\Temp\fla2413.tmp
[2012-06-09:22:49:17] Received download status 200
[2012-06-09:22:49:17] Response URL is http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-09:22:49:19] Download success
[2012-06-09:22:49:20] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:49:20] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.005843374878168106 onApplicationVersion
[2012-06-09:22:49:20] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:49:20] Application Installer end with exit code 0
[2012-06-09:22:49:23] Unpackaging file:///C:/Users/Administrator/AppData/Local/Temp/fla2413.tmp to C:\Users\Administrator\AppData\Local\Temp\fla4347.tmp
[2012-06-09:22:49:24] Application signature verified
[2012-06-09:22:49:24] Unpackaging/validation complete
[2012-06-09:22:49:24] No app located for appID 'BBCiPlayerDesktop' and pubID '61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1'
[2012-06-09:22:49:25] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:49:25] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4939270871691406 onApplicationVersion
[2012-06-09:22:49:25] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:49:25] Application Installer end with exit code 0
[2012-06-09:22:49:30] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:49:30] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7118122163228691 onApplicationVersion
[2012-06-09:22:49:30] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:49:30] Application Installer end with exit code 0
[2012-06-09:22:49:35] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:49:35] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6379713909700513 onApplicationVersion
[2012-06-09:22:49:35] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:49:35] Application Installer end with exit code 0
[2012-06-09:22:49:41] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:49:41] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.48292741645127535 onApplicationVersion
[2012-06-09:22:49:41] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:49:41] Application Installer end with exit code 0
[2012-06-09:22:49:41] Converting unpackaged application to a native installation package in C:\Users\Administrator\AppData\Local\Temp\fla8759.tmp
[2012-06-09:22:49:42] Native installation package creation succeeded
[2012-06-09:22:49:42] Starting app installation to C:\Program Files. Installing app BBCiPlayerDesktop.61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 version 3.2.14 using the source file at file:///C:/Users/Administrator/AppData/Local/Temp/fla2413.tmp
[2012-06-09:22:49:42] Installing msi at C:\Users\Administrator\AppData\Local\Temp\fla8759.tmp\setup.msi with guid {F6B3B47B-C6F9-51F8-256A-68C0D113C12A}
[2012-06-09:22:49:44] Launching subprocess with commandline C:\Program Files\BBC iPlayer Desktop\BBC iPlayer Desktop.exe
[2012-06-09:22:49:45] Application Installer end with exit code 0
[2012-06-09:22:49:46] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:49:46] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.36690775537863374 onApplicationVersion
[2012-06-09:22:49:46] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:49:46] Application Installer end with exit code 0
[2012-06-09:22:51:42] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:51:42] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6438835989683867 onApplicationVersion
[2012-06-09:22:51:42] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:51:42] Application Installer end with exit code 0
[2012-06-09:22:52:37] Application Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:22:52:37] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4135242532938719 onApplicationVersion
[2012-06-09:22:52:37] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:22:52:37] Application Installer end with exit code 0
[2012-06-09:23:09:49] Runtime Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:23:09:49] Commandline is: -arp:uninstall
[2012-06-09:23:09:49] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:23:09:58] Runtime Installer end with exit code 6
[2012-06-09:23:10:08] Runtime Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:23:10:08] Commandline is: -arp:uninstall
[2012-06-09:23:10:08] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:23:10:10] Relaunching with elevation
[2012-06-09:23:10:10] Launching subprocess with commandline c:\program files\common files\adobe air\versions\1.0\resources\adobe air updater.exe -eu
[2012-06-09:23:10:10] Runtime Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-09:23:10:10] Commandline is: -stdio \\.\pipe\AIR_5172_0 -eu
[2012-06-09:23:10:10] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-09:23:10:10] Starting runtime uninstall. Uninstalling runtime version 3.2.0.2070
[2012-06-09:23:10:10] Uninstalling product with GUID {47FA2C44-D148-4DBC-AF60-B91934AA4842}
[2012-06-09:23:10:12] Runtime Installer end with exit code 0
[2012-06-09:23:10:13] Elevated install completed
[2012-06-09:23:10:13] Runtime Installer end with exit code 0
[2012-06-10:00:45:53] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:45:53] Commandline is:
[2012-06-10:00:45:53] No installed runtime detected
[2012-06-10:00:45:56] Relaunching with elevation
[2012-06-10:00:45:56] Launching subprocess with commandline c:\users\admini~1\appdata\local\temp\aire83c.tmp\adobe air installer.exe -ei
[2012-06-10:00:45:56] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:45:56] Commandline is: -stdio \\.\pipe\AIR_4532_0 -ei
[2012-06-10:00:45:56] No installed runtime detected
[2012-06-10:00:45:56] Starting silent runtime install. Installing runtime version 3.3.0.3650
[2012-06-10:00:45:56] Installing msi at c:\users\admini~1\appdata\local\temp\aire83c.tmp\setup.msi with guid {65CB4C08-C47B-4A7E-A6A4-50C06ADA5FC6}
[2012-06-10:00:46:02] Runtime Installer end with exit code 0
[2012-06-10:00:46:02] Elevated install completed
[2012-06-10:00:46:04] Launching subprocess with commandline c:\Program Files\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater -installupdatecheck
[2012-06-10:00:46:04] Runtime Installer end with exit code 0
[2012-06-10:00:46:05] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:46:05] Commandline is: -installupdatecheck
[2012-06-10:00:46:05] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:46:05] Performing pingback request
[2012-06-10:00:46:06] Pingback request completed with HTTP status 200
[2012-06-10:00:46:06] Starting runtime background update check
[2012-06-10:00:46:06] Begin Background update download from http://airdownload.adobe.com/air/3/background/windows6.0/x86/patch/3.3 .0.3650/update
[2012-06-10:00:46:06] Unpackaging http://airdownload.adobe.com/air/3/background/windows6.0/x86/patch/3.3 .0.3650/update to C:\Users\Administrator\AppData\Roaming\Adobe\AIR\Updater\Background
[2012-06-10:00:46:07] Runtime update not available
[2012-06-10:00:46:07] Unpackaging cancelled
[2012-06-10:00:46:07] Runtime Installer end with exit code 0
[2012-06-10:00:46:35] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:46:35] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.27818247955292463 onApplicationVersion
[2012-06-10:00:46:35] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:46:35] Application Installer end with exit code 0
[2012-06-10:00:46:42] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:46:42] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4032257688231766 onApplicationVersion
[2012-06-10:00:46:42] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:46:43] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:46:43] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9459409359842539 onApplicationVersion
[2012-06-10:00:46:43] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:46:43] Application Installer end with exit code 0
[2012-06-10:00:46:44] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:46:44] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3825549683533609 onApplicationVersion
[2012-06-10:00:46:44] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:46:44] Application Installer end with exit code 0
[2012-06-10:00:46:45] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:46:45] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6859996486455202 onApplicationVersion
[2012-06-10:00:46:45] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:46:45] Application Installer end with exit code 0
[2012-06-10:00:46:47] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:46:47] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqdDA1ZA== b01jt02k 2500 0 My4w b01jt05d normal "
[2012-06-10:00:46:47] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:46:47] Begin air file download from http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:00:46:47] Download destination is C:\Users\Administrator\AppData\Local\Temp\flaCAAE.tmp
[2012-06-10:00:46:48] Received download status 200
[2012-06-10:00:46:48] Response URL is http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:00:46:48] Download success
[2012-06-10:00:46:52] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:46:52] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4707798417657614 onApplicationVersion
[2012-06-10:00:46:52] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:46:52] Application Installer end with exit code 0
[2012-06-10:00:46:57] Unpackaging file:///C:/Users/Administrator/AppData/Local/Temp/flaCAAE.tmp to C:\Users\Administrator\AppData\Local\Temp\flaF086.tmp
[2012-06-10:00:46:57] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:46:57] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7500687632709742 onApplicationVersion
[2012-06-10:00:46:57] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:46:58] Application Installer end with exit code 0
[2012-06-10:00:46:58] Application signature verified
[2012-06-10:00:46:58] Unpackaging/validation complete
[2012-06-10:00:46:58] No app located for appID 'BBCiPlayerDesktop' and pubID '61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1'
[2012-06-10:00:47:02] Converting unpackaged application to a native installation package in C:\Users\Administrator\AppData\Local\Temp\fla35C.tmp
[2012-06-10:00:47:03] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:47:03] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.1354829673655331 onApplicationVersion
[2012-06-10:00:47:03] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:47:03] Application Installer end with exit code 0
[2012-06-10:00:47:03] Native installation package creation succeeded
[2012-06-10:00:47:03] Starting app installation to C:\Program Files. Installing app BBCiPlayerDesktop.61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 version 3.2.14 using the source file at file:///C:/Users/Administrator/AppData/Local/Temp/flaCAAE.tmp
[2012-06-10:00:47:03] Installing msi at C:\Users\Administrator\AppData\Local\Temp\fla35C.tmp\setup.msi with guid {F6B3B47B-C6F9-51F8-256A-68C0D113C12A}
[2012-06-10:00:47:04] Launching subprocess with commandline C:\Program Files\BBC iPlayer Desktop\BBC iPlayer Desktop.exe
[2012-06-10:00:47:07] Application Installer end with exit code 0
[2012-06-10:00:47:08] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:47:08] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7146123647689819 onApplicationVersion
[2012-06-10:00:47:08] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:47:09] Application Installer end with exit code 0
[2012-06-10:00:47:15] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:47:15] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.13774698181077838 onApplicationVersion
[2012-06-10:00:47:15] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:47:15] Application Installer end with exit code 0
[2012-06-10:00:47:20] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:47:20] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.926290228497237 onApplicationVersion
[2012-06-10:00:47:20] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:47:20] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6332368995063007 onApplicationVersion
[2012-06-10:00:47:20] Application Installer end with exit code 0
[2012-06-10:00:47:21] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:47:21] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -launch BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqdDA1ZC8= b01jt02k 2500 0 My4w b01jt05d null "
[2012-06-10:00:47:21] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:47:21] Application Installer end with exit code 0
[2012-06-10:00:50:38] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:50:38] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8295672023668885 onApplicationVersion
[2012-06-10:00:50:38] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:50:38] Application Installer end with exit code 0
[2012-06-10:00:50:43] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:50:43] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8324918034486473 onApplicationVersion
[2012-06-10:00:50:43] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:50:43] Application Installer end with exit code 0
[2012-06-10:00:50:45] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:50:45] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.16435157880187035 onApplicationVersion
[2012-06-10:00:50:45] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:50:45] Application Installer end with exit code 0
[2012-06-10:00:50:48] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:50:48] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.33373206993564963 onApplicationVersion
[2012-06-10:00:50:48] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:50:48] Application Installer end with exit code 0
[2012-06-10:00:50:48] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.27393177105113864 onApplicationVersion
[2012-06-10:00:50:49] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:50:49] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3933612206019461 onApplicationVersion
[2012-06-10:00:50:49] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:50:49] Application Installer end with exit code 0
[2012-06-10:00:50:50] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:50:50] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.0768702644854784 onApplicationVersion
[2012-06-10:00:50:50] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:50:51] Application Installer end with exit code 0
[2012-06-10:00:50:52] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:50:52] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqdDA1ZA== b01jt02k 2500 0 My4w b01jt05d normal "
[2012-06-10:00:50:52] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:50:52] Begin air file download from http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:00:50:52] Download destination is C:\Users\Administrator\AppData\Local\Temp\fla88AF.tmp
[2012-06-10:00:50:53] Received download status 200
[2012-06-10:00:50:53] Response URL is http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:00:50:53] Download success
[2012-06-10:00:50:55] Unpackaging file:///C:/Users/Administrator/AppData/Local/Temp/fla88AF.tmp to C:\Users\Administrator\AppData\Local\Temp\fla9157.tmp
[2012-06-10:00:50:55] Application signature verified
[2012-06-10:00:50:55] Unpackaging/validation complete
[2012-06-10:00:50:55] No app located for appID 'BBCiPlayerDesktop' and pubID '61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1'
[2012-06-10:00:50:57] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:50:57] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.2241145591251552 onApplicationVersion
[2012-06-10:00:50:57] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:50:57] Application Installer end with exit code 0
[2012-06-10:00:50:58] Converting unpackaged application to a native installation package in C:\Users\Administrator\AppData\Local\Temp\fla9CEC.tmp
[2012-06-10:00:50:59] Native installation package creation succeeded
[2012-06-10:00:50:59] Starting app installation to C:\Program Files. Installing app BBCiPlayerDesktop.61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 version 3.2.14 using the source file at file:///C:/Users/Administrator/AppData/Local/Temp/fla88AF.tmp
[2012-06-10:00:50:59] Installing msi at C:\Users\Administrator\AppData\Local\Temp\fla9CEC.tmp\setup.msi with guid {F6B3B47B-C6F9-51F8-256A-68C0D113C12A}
[2012-06-10:00:51:00] Launching subprocess with commandline C:\Program Files\BBC iPlayer Desktop\BBC iPlayer Desktop.exe
[2012-06-10:00:51:01] Application Installer end with exit code 0
[2012-06-10:00:51:03] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:51:03] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5962243950925767 onApplicationVersion
[2012-06-10:00:51:03] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:51:03] Application Installer end with exit code 0
[2012-06-10:00:51:07] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:00:51:07] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6319911661557853 onApplicationVersion
[2012-06-10:00:51:07] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:00:51:07] Application Installer end with exit code 0
[2012-06-10:01:02:46] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:02:46] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7211096938699484 onApplicationVersion
[2012-06-10:01:02:46] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:02:46] Application Installer end with exit code 0
[2012-06-10:01:02:50] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:02:50] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7599492287263274 onApplicationVersion
[2012-06-10:01:02:50] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:02:50] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9707843968644738 onApplicationVersion
[2012-06-10:01:02:50] Application Installer end with exit code 0
[2012-06-10:01:02:52] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:02:52] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.0192999760620296 onApplicationVersion
[2012-06-10:01:02:52] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:02:52] Application Installer end with exit code 0
[2012-06-10:01:02:53] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:02:53] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6873192824423313 onApplicationVersion
[2012-06-10:01:02:53] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:02:53] Application Installer end with exit code 0
[2012-06-10:01:02:55] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:02:55] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqdDA1ZA== b01jt02k 2500 0 My4w b01jt05d normal "
[2012-06-10:01:02:55] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:02:55] Begin air file download from http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:01:02:55] Download destination is C:\Users\Administrator\AppData\Local\Temp\fla90F9.tmp
[2012-06-10:01:02:56] Received download status 200
[2012-06-10:01:02:56] Response URL is http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:01:02:56] Download success
[2012-06-10:01:02:57] Unpackaging file:///C:/Users/Administrator/AppData/Local/Temp/fla90F9.tmp to C:\Users\Administrator\AppData\Local\Temp\fla9888.tmp
[2012-06-10:01:02:58] Application signature verified
[2012-06-10:01:02:58] Unpackaging/validation complete
[2012-06-10:01:02:58] No app located for appID 'BBCiPlayerDesktop' and pubID '61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1'
[2012-06-10:01:03:00] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:03:00] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9592119413428009 onApplicationVersion
[2012-06-10:01:03:00] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:03:00] Application Installer end with exit code 0
[2012-06-10:01:03:01] Converting unpackaged application to a native installation package in C:\Users\Administrator\AppData\Local\Temp\flaA7D5.tmp
[2012-06-10:01:03:02] Native installation package creation succeeded
[2012-06-10:01:03:02] Starting app installation to C:\Program Files. Installing app BBCiPlayerDesktop.61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 version 3.2.14 using the source file at file:///C:/Users/Administrator/AppData/Local/Temp/fla90F9.tmp
[2012-06-10:01:03:02] Installing msi at C:\Users\Administrator\AppData\Local\Temp\flaA7D5.tmp\setup.msi with guid {F6B3B47B-C6F9-51F8-256A-68C0D113C12A}
[2012-06-10:01:03:04] Launching subprocess with commandline C:\Program Files\BBC iPlayer Desktop\BBC iPlayer Desktop.exe
[2012-06-10:01:03:05] Application Installer end with exit code 0
[2012-06-10:01:03:06] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:03:06] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.004675321280956268 onApplicationVersion
[2012-06-10:01:03:06] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:03:06] Application Installer end with exit code 0
[2012-06-10:01:03:10] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:03:10] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.22403651103377342 onApplicationVersion
[2012-06-10:01:03:10] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:03:10] Application Installer end with exit code 0
[2012-06-10:01:19:22] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:19:22] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5829677637666464 onApplicationVersion
[2012-06-10:01:19:22] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:19:22] Application Installer end with exit code 0
[2012-06-10:01:19:33] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:19:33] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9717108081094921 onApplicationVersion
[2012-06-10:01:19:33] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:19:33] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.07170981960371137 onApplicationVersion
[2012-06-10:01:19:33] Application Installer end with exit code 0
[2012-06-10:01:19:34] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:19:34] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6580652254633605 onApplicationVersion
[2012-06-10:01:19:34] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:19:34] Application Installer end with exit code 0
[2012-06-10:01:19:36] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:19:36] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9042624887079 onApplicationVersion
[2012-06-10:01:19:36] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:19:36] Application Installer end with exit code 0
[2012-06-10:01:19:37] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:19:37] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqdDA1ZA== b01jt02k 2500 0 My4w b01jt05d normal "
[2012-06-10:01:19:37] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:19:37] Begin air file download from http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:01:19:37] Download destination is C:\Users\Administrator\AppData\Local\Temp\fla820A.tmp
[2012-06-10:01:19:38] Received download status 200
[2012-06-10:01:19:38] Response URL is http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:01:19:38] Download success
[2012-06-10:01:19:41] Unpackaging file:///C:/Users/Administrator/AppData/Local/Temp/fla820A.tmp to C:\Users\Administrator\AppData\Local\Temp\fla902F.tmp
[2012-06-10:01:19:42] Application signature verified
[2012-06-10:01:19:42] Unpackaging/validation complete
[2012-06-10:01:19:42] No app located for appID 'BBCiPlayerDesktop' and pubID '61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1'
[2012-06-10:01:19:42] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:19:42] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.15883719408884645 onApplicationVersion
[2012-06-10:01:19:42] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:19:42] Application Installer end with exit code 0
[2012-06-10:01:19:45] Converting unpackaged application to a native installation package in C:\Users\Administrator\AppData\Local\Temp\flaA094.tmp
[2012-06-10:01:19:46] Native installation package creation succeeded
[2012-06-10:01:19:46] Starting app installation to C:\Program Files. Installing app BBCiPlayerDesktop.61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 version 3.2.14 using the source file at file:///C:/Users/Administrator/AppData/Local/Temp/fla820A.tmp
[2012-06-10:01:19:46] Installing msi at C:\Users\Administrator\AppData\Local\Temp\flaA094.tmp\setup.msi with guid {F6B3B47B-C6F9-51F8-256A-68C0D113C12A}
[2012-06-10:01:19:48] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:19:48] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.1091549382545054 onApplicationVersion
[2012-06-10:01:19:48] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:19:48] Application Installer end with exit code 0
[2012-06-10:01:19:48] Launching subprocess with commandline C:\Program Files\BBC iPlayer Desktop\BBC iPlayer Desktop.exe
[2012-06-10:01:19:49] Application Installer end with exit code 0
[2012-06-10:01:19:53] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:19:53] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.1182427080348134 onApplicationVersion
[2012-06-10:01:19:53] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:19:53] Application Installer end with exit code 0
[2012-06-10:01:20:22] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:20:22] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.31732273008674383 onApplicationVersion
[2012-06-10:01:20:22] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:20:23] Application Installer end with exit code 0
[2012-06-10:01:21:26] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:21:26] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.745123072527349 onApplicationVersion
[2012-06-10:01:21:26] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:21:26] Application Installer end with exit code 0
[2012-06-10:01:21:32] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:21:32] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6917169662192464 onApplicationVersion
[2012-06-10:01:21:32] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:21:32] Application Installer end with exit code 0
[2012-06-10:01:21:37] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:21:37] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6950905225239694 onApplicationVersion
[2012-06-10:01:21:37] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:21:37] Application Installer end with exit code 0
[2012-06-10:01:21:41] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:21:41] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8850821978412569 onApplicationVersion
[2012-06-10:01:21:41] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:21:41] Application Installer end with exit code 0
[2012-06-10:01:21:48] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:21:48] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5886558606289327 onApplicationVersion
[2012-06-10:01:21:48] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:21:48] Application Installer end with exit code 0
[2012-06-10:01:27:41] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:27:41] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9406360010616481 onApplicationVersion
[2012-06-10:01:27:41] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:27:41] Application Installer end with exit code 0
[2012-06-10:01:27:53] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:27:53] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.578052390832454 onApplicationVersion
[2012-06-10:01:27:53] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:27:53] Application Installer end with exit code 0
[2012-06-10:01:28:03] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:03] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.34124178206548095 onApplicationVersion
[2012-06-10:01:28:03] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:03] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.1455891919322312 onApplicationVersion
[2012-06-10:01:28:03] Application Installer end with exit code 0
[2012-06-10:01:28:04] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:04] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.43804680835455656 onApplicationVersion
[2012-06-10:01:28:04] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:04] Application Installer end with exit code 0
[2012-06-10:01:28:05] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:05] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.02062847837805748 onApplicationVersion
[2012-06-10:01:28:05] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:06] Application Installer end with exit code 0
[2012-06-10:01:28:12] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:12] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqdDA1ZA== b01jt02k 2500 0 My4w b01jt05d normal "
[2012-06-10:01:28:12] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:12] Begin air file download from http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:01:28:12] Download destination is C:\Users\Administrator\AppData\Local\Temp\fla5C62.tmp
[2012-06-10:01:28:13] Received download status 200
[2012-06-10:01:28:13] Response URL is http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:01:28:13] Download success
[2012-06-10:01:28:14] Unpackaging file:///C:/Users/Administrator/AppData/Local/Temp/fla5C62.tmp to C:\Users\Administrator\AppData\Local\Temp\fla629A.tmp
[2012-06-10:01:28:14] Application signature verified
[2012-06-10:01:28:14] Unpackaging/validation complete
[2012-06-10:01:28:14] No app located for appID 'BBCiPlayerDesktop' and pubID '61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1'
[2012-06-10:01:28:16] Cancel request received
[2012-06-10:01:28:16] Application Installer end with exit code 6
[2012-06-10:01:28:17] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:17] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.7678180490620434 onApplicationVersion
[2012-06-10:01:28:17] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:17] Application Installer end with exit code 0
[2012-06-10:01:28:21] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:21] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3685863856226206 onApplicationVersion
[2012-06-10:01:28:21] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:21] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3885097368620336 onApplicationVersion
[2012-06-10:01:28:21] Application Installer end with exit code 0
[2012-06-10:01:28:22] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:22] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.786595509853214 onApplicationVersion
[2012-06-10:01:28:22] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:22] Application Installer end with exit code 0
[2012-06-10:01:28:23] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:23] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9046253459528089 onApplicationVersion
[2012-06-10:01:28:23] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:24] Application Installer end with exit code 0
[2012-06-10:01:28:24] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:24] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqdDA1ZA== b01jt02k 2500 0 My4w b01jt05d normal "
[2012-06-10:01:28:24] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:25] Begin air file download from http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:01:28:25] Download destination is C:\Users\Administrator\AppData\Local\Temp\fla8ED6.tmp
[2012-06-10:01:28:25] Received download status 200
[2012-06-10:01:28:25] Response URL is http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:01:28:25] Download success
[2012-06-10:01:28:30] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:30] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9042360996827483 onApplicationVersion
[2012-06-10:01:28:30] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:30] Application Installer end with exit code 0
[2012-06-10:01:28:35] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:35] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.4420218733139336 onApplicationVersion
[2012-06-10:01:28:35] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:35] Application Installer end with exit code 0
[2012-06-10:01:28:40] Application Installer end with exit code 0
[2012-06-10:01:28:41] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:41] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.30093218106776476 onApplicationVersion
[2012-06-10:01:28:41] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:41] Application Installer end with exit code 0
[2012-06-10:01:28:44] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:44] Commandline is: C:\Users\Administrator\Desktop\bbc_iplayer_desktop_v3214.air
[2012-06-10:01:28:44] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:44] Unpackaging file:///C:/Users/Administrator/Desktop/bbc_iplayer_desktop_v3214.air to C:\Users\Administrator\AppData\Local\Temp\flaD99C.tmp
[2012-06-10:01:28:45] Application signature verified
[2012-06-10:01:28:45] Unpackaging/validation complete
[2012-06-10:01:28:45] No app located for appID 'BBCiPlayerDesktop' and pubID '61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1'
[2012-06-10:01:28:46] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:46] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.3904147632420063 onApplicationVersion
[2012-06-10:01:28:46] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:46] Application Installer end with exit code 0
[2012-06-10:01:28:52] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:52] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8014948833733797 onApplicationVersion
[2012-06-10:01:28:52] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:28:52] Application Installer end with exit code 0
[2012-06-10:01:28:54] Converting unpackaged application to a native installation package in C:\Users\Administrator\AppData\Local\Temp\fla11A.tmp
[2012-06-10:01:28:55] Native installation package creation succeeded
[2012-06-10:01:28:55] Starting app installation to C:\Program Files. Installing app BBCiPlayerDesktop.61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 version 3.2.14 using the source file at file:///C:/Users/Administrator/Desktop/bbc_iplayer_desktop_v3214.air
[2012-06-10:01:28:55] Installing msi at C:\Users\Administrator\AppData\Local\Temp\fla11A.tmp\setup.msi with guid {F6B3B47B-C6F9-51F8-256A-68C0D113C12A}
[2012-06-10:01:28:57] Launching subprocess with commandline C:\Program Files\BBC iPlayer Desktop\BBC iPlayer Desktop.exe
[2012-06-10:01:28:57] Application Installer end with exit code 0
[2012-06-10:01:28:57] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:28:57] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9425638355314732 onApplicationVersion
[2012-06-10:01:28:57] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:29:18] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:01:29:18] Commandline is: -playerVersion=11,2,202,233 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.19907301012426615 onApplicationVersion
[2012-06-10:01:29:18] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:01:29:18] Application Installer end with exit code 0
[2012-06-10:02:27:10] Runtime Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-10:02:27:10] Commandline is: -arp:uninstall
[2012-06-10:02:27:10] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:27:10] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="app:/setup.swf" errorID=0]
[2012-06-10:02:38:44] Runtime Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-10:02:38:44] Commandline is: -arp:uninstall
[2012-06-10:02:38:44] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:38:44] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="app:/setup.swf" errorID=0]
[2012-06-10:02:44:57] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:02:44:57] Commandline is:
[2012-06-10:02:44:57] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:45:09] Relaunching with elevation
[2012-06-10:02:45:09] Launching subprocess with commandline c:\users\admini~1\appdata\local\temp\aira6aa.tmp\adobe air installer.exe -ei
[2012-06-10:02:45:09] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:02:45:09] Commandline is: -stdio \\.\pipe\AIR_6136_0 -ei
[2012-06-10:02:45:09] Installed runtime (3.2.0.2070) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:45:09] Starting silent runtime update. Updating runtime from version 3.2.0.2070 to version 3.3.0.3650
[2012-06-10:02:45:09] Installing msi at c:\users\admini~1\appdata\local\temp\aira6aa.tmp\setup.msi with guid {65CB4C08-C47B-4A7E-A6A4-50C06ADA5FC6}
[2012-06-10:02:45:19] Runtime Installer end with exit code 1
[2012-06-10:02:45:19] Elevated install completed
[2012-06-10:02:45:22] Launching subprocess with commandline c:\Program Files\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater -installupdatecheck
[2012-06-10:02:45:22] Runtime Installer end with exit code 0
[2012-06-10:02:45:24] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:02:45:24] Commandline is: -installupdatecheck
[2012-06-10:02:45:24] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:45:24] Performing pingback request
[2012-06-10:02:45:25] Pingback request completed with HTTP status 200
[2012-06-10:02:45:25] Starting runtime background update check
[2012-06-10:02:45:25] Begin Background update download from http://airdownload.adobe.com/air/3/background/windows6.0/x86/patch/3.3 .0.3650/update
[2012-06-10:02:45:25] Unpackaging http://airdownload.adobe.com/air/3/background/windows6.0/x86/patch/3.3 .0.3650/update to C:\Users\Administrator\AppData\Roaming\Adobe\AIR\Updater\Background
[2012-06-10:02:45:25] Runtime update not available
[2012-06-10:02:45:25] Unpackaging cancelled
[2012-06-10:02:45:25] Runtime Installer end with exit code 0
[2012-06-10:02:45:34] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:02:45:34] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.012469654437154531 onApplicationVersion
[2012-06-10:02:45:34] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:45:34] Application Installer end with exit code 0
[2012-06-10:02:45:39] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:02:45:39] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5074591301381588 onApplicationVersion
[2012-06-10:02:45:39] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:45:39] Application Installer end with exit code 0
[2012-06-10:02:45:53] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:02:45:53] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.6847715699113905 onApplicationVersion
[2012-06-10:02:45:53] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:45:53] Application Installer end with exit code 0
[2012-06-10:02:45:53] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9171641119755805 onApplicationVersion
[2012-06-10:02:45:57] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:02:45:57] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.23209324572235346 onApplicationVersion
[2012-06-10:02:45:57] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:45:57] Application Installer end with exit code 0
[2012-06-10:02:45:58] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:02:45:58] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.9426251030527055 onApplicationVersion
[2012-06-10:02:45:58] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:45:58] Application Installer end with exit code 0
[2012-06-10:02:46:00] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:02:46:00] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=true -- -url http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air -- "-d aHR0cDovL3d3dy5iYmMuY28udWsvaXBsYXllci9wbGF5bGlzdC9iMDFqdDA1ZA== b01jt02k 2500 0 My4w b01jt05d normal "
[2012-06-10:02:46:00] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:46:00] Begin air file download from http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:02:46:00] Download destination is C:\Users\Administrator\AppData\Local\Temp\flaA91A.tmp
[2012-06-10:02:46:01] Received download status 200
[2012-06-10:02:46:01] Response URL is http://www.bbc.co.uk/iplayer/dm/version2/revisions/bbc_iplayer_desktop _v3214.air
[2012-06-10:02:46:01] Download success
[2012-06-10:02:46:03] Unpackaging file:///C:/Users/Administrator/AppData/Local/Temp/flaA91A.tmp to C:\Users\Administrator\AppData\Local\Temp\flaB4FD.tmp
[2012-06-10:02:46:04] Application signature verified
[2012-06-10:02:46:04] Unpackaging/validation complete
[2012-06-10:02:46:04] No app located for appID 'BBCiPlayerDesktop' and pubID '61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1'
[2012-06-10:02:46:05] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:02:46:05] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.601597957778722 onApplicationVersion
[2012-06-10:02:46:05] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:46:05] Application Installer end with exit code 0
[2012-06-10:02:46:06] Converting unpackaged application to a native installation package in C:\Users\Administrator\AppData\Local\Temp\flaC1BA.tmp
[2012-06-10:02:46:07] Native installation package creation succeeded
[2012-06-10:02:46:07] Starting app installation to C:\Program Files. Installing app BBCiPlayerDesktop.61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 version 3.2.14 using the source file at file:///C:/Users/Administrator/AppData/Local/Temp/flaA91A.tmp
[2012-06-10:02:46:07] Installing msi at C:\Users\Administrator\AppData\Local\Temp\flaC1BA.tmp\setup.msi with guid {F6B3B47B-C6F9-51F8-256A-68C0D113C12A}
[2012-06-10:02:46:09] Launching subprocess with commandline C:\Program Files\BBC iPlayer Desktop\BBC iPlayer Desktop.exe
[2012-06-10:02:46:09] Application Installer end with exit code 0
[2012-06-10:02:46:10] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:02:46:10] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.8101561404764652 onApplicationVersion
[2012-06-10:02:46:10] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:46:10] Application Installer end with exit code 0
[2012-06-10:02:46:16] Application Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:02:46:16] Commandline is: -playerVersion=11,2,202,235 -sandboxType=remote -securityDomain=airdownload.adobe.com -https=false -fromUserEvent=false -- -isinstalled BBCiPlayerDesktop 61DB7A798358575D6A969CCD73DDBBD723A6DA9D.1 adobe.com:air0.5776416691951454 onApplicationVersion
[2012-06-10:02:46:16] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:02:46:16] Application Installer end with exit code 0
[2012-06-10:03:06:54] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:03:06:54] Commandline is: -arp:uninstall
[2012-06-10:03:06:54] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:03:06:54] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="app:/setup.swf" errorID=0]
[2012-06-10:03:10:31] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:03:10:31] Commandline is:
[2012-06-10:03:10:31] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:03:10:35] Launching subprocess with commandline c:\Program Files\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater -installupdatecheck
[2012-06-10:03:10:35] Runtime Installer end with exit code 0
[2012-06-10:03:10:35] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:03:10:35] Commandline is: -installupdatecheck
[2012-06-10:03:10:35] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:03:10:35] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="app:/setup.swf" errorID=0]
[2012-06-10:03:11:50] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:03:11:50] Commandline is:
[2012-06-10:03:11:50] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:03:11:55] Launching subprocess with commandline c:\Program Files\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater -installupdatecheck
[2012-06-10:03:11:55] Runtime Installer end with exit code 0
[2012-06-10:03:11:55] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:03:11:55] Commandline is: -installupdatecheck
[2012-06-10:03:11:55] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:03:11:55] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="app:/setup.swf" errorID=0]
[2012-06-10:03:25:57] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:03:25:57] Commandline is: -arp:uninstall
[2012-06-10:03:25:57] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:03:25:57] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="app:/setup.swf" errorID=0]
[2012-06-10:03:26:55] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:03:26:55] Commandline is:
[2012-06-10:03:26:55] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:03:26:59] Launching subprocess with commandline c:\Program Files\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater -installupdatecheck
[2012-06-10:03:26:59] Runtime Installer end with exit code 0
[2012-06-10:03:26:59] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:03:26:59] Commandline is: -installupdatecheck
[2012-06-10:03:26:59] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:03:26:59] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="app:/setup.swf" errorID=0]
[2012-06-10:03:28:47] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:03:28:47] Commandline is:
[2012-06-10:03:28:47] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:03:28:49] Launching subprocess with commandline c:\Program Files\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater -installupdatecheck
[2012-06-10:03:28:49] Runtime Installer end with exit code 0
[2012-06-10:03:28:49] Runtime Installer begin with version 3.3.0.3650 on Windows Vista x86
[2012-06-10:03:28:49] Commandline is: -installupdatecheck
[2012-06-10:03:28:49] Installed runtime (3.3.0.3650) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-10:03:28:49] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="app:/setup.swf" errorID=0]
  • Chris Campbell
    May 4, 2010
    Jun 19, 2012 10:03 PM   in reply to estonianboy
    I'm sorry you're running into installation issues with AIR.  Microsoft has released a new utility that can help resolve installation problems.  Would you mind giving this a try and let us know how it works for you?  When running the Fix it, go through the uninstall process and try to remove Adobe AIR from your system.  Once finished, download the latest version of AIR and install again.
    Microsoft Install and Uninstall Fix It
    Chris
