Installing Creative Cloud CS6 on Win7 32bit Dell Precision M6400 - all Win7 updates installed. Have Web Premium CS4 installed. Had issues with updating Acrobat X reader in the past. Other Cloud apps install fine. Have tried to uninstall Acrobat X reader (OK). Acrobat 9 pro still installed - can't find a way to uninstall. Need to keep CS4 installed.
Install fails with the log as shown below.
Exit Code: 6
Please see specific errors and warnings below for troubleshooting. For example, ERROR: DW050 ... WARNING: DW066 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 3 error(s), 2 warning(s)
WARNING: DW066: OS requirements not met for {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0
WARNING: DW066: OS requirements not met for {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0
----------- Payload: {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0 -----------
ERROR: Error 1714.The older version of Adobe Acrobat X Pro - English, Français, Deutsch cannot be removed. Contact your technical support group.
ERROR: Install MSI payload failed with error: 1603 - Fatal error during installation.
MSI Error message: Error 1714.The older version of Adobe Acrobat X Pro - English, Français, Deutsch cannot be removed. Contact your technical support group.
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Acrobat Professional: Install failed
Might check to see if you have an older version of Acrobat X installed previously under
Mac HD > Applications > Utilities > Adobe Installers
If you have an uninstaller for Acrobat X try uninstalling it then installing again like you did through Creative Cloud.
-Dave
Thank you for your reply. I am installing on my Windows 7 PC. I have uninstalled and reinstalled Acrobat X several times. The result is the same each time. There is also no obvious uninstaller for Acrobat 9 Pro that is installed as a part of CS4. I need to leave CS4 on the computer but can dump Acrobat 9 Pro and use Acrobat X Pro.
hi
