With Muses, How to insert images in a block of text
Jun 10, 2012 6:31 AM
Tags: #image #textflow
How could I insert an image within a text block and have it flowing around. I am able to import the image but, even if I found the buttons to have the text flowing, nothing happens and the image stay above the text ... and there is no user manual ....
    Jun 12, 2012 12:36 PM   in reply to aimetc2
    In order to have the text flowing around with the text you have to,
    1. Create a text box with some text on it.
    2. Insert an image.
    3. Select the image and frame and go to Edit Cut.
    4. Double click the text frame so that it comes in the edit mode.
    5. Go to Edit Paste.
    6. After which you should be able to select the appropriate wrap option.
    Let me know if you have more issues.
    Regards,
    Abhishek Maurya
    Jun 12, 2012 12:39 PM   in reply to aimetc2
    Please have a look at the following recording and let me know if it helps: http://screencasteu.worldsecuresystems.com/Cristi/2012-06-12_2234.swf
    Basically you have to create the text area and then inser the picture, then cut and paste inside the text area, and modify the wrap around the picture wiht the image selected and not with the text area select.
    Cheers,
    Cristian
    Jun 20, 2012 4:50 AM   in reply to aimetc2
    Hi aimetc2,
    Because links point to static content and they are "pre-defined" during the design process this isn't possible and in fact this is a browser feature (back and forth buttons within a browser), because browsers keep a history of visited pages and can navigate back and forth through them so your site visitors will be able to use the functionality that's already built in browsers.
    Cristian
    Jun 21, 2012 9:57 PM   in reply to aimetc2
    Hi Michael,
    If you are comfortable with code, you can achieve the back button functionality by adding code using the Insert HTML feature.
    The code you need to insert it below:
    <a href="javascript:history.go(-1);">Go Back</a>
    You can change the "Go Back" text with any image using the <img src=... /> tag.
    Cheers,
    Vikas
