I have large amount of tagged ASCII content in hand, something like this
<title>Chapter title
<h1>Heading 1
<p>paragraph text
<bib>some thext
On the other hand, I also have a FrameMaker 10 unstructured template where title, h1, p, bib, etc style elements are already defined.
Please suggest me a way to flow my text onto the template, which my page composition makes easy.
I am looking forward to hear from you.
Arul
You could use FrameMaker's MML markup to match things up to your existing template.
See: http://help.adobe.com/en_US/FrameMaker/8.0/mml_reference.pdf
With your current mark-up style (as shown in the original posting), all you would need to do is to add two statements to the start of your file, e.g.
<MML>
<Include "formats.mml">
<h1>Heading 1
<p>paragraph text
<bib>some thext
and create a file called formats.mml that contains DefineTag statements listing exactly the styles that you've used to mark-up the text and that correspond to the catalog entries in your template, e.g.
<MML>
<!DefineTag title>
<!DefineTag h1>
<!DefineTag p>
<!DefineTag bib>
etc.
Then in your template file that already has the predefined styles, File > Import > File and select the data file.
When FM imports the MML file, the included formats.mml file tells FM that the tags already exist in the template and to apply them to the content as it comes in. Note: if you have many of these source files using the same template, you will only need one copy of this formats file.
Note: to separate paragraphs (if not tagged with a preceding <p> or whatever), you must use two or more consecutive return characters, so this might be another minor modification to your input stream depending upon the tagging consistency.
Any "transformation" for your content appears to very minor/trivial from what you've shown so far. Otherwise, I am not aware of any other method of getting the contnt in AS IS without some work up front to transform it to a format that FM can decipher.
North America
Asia Pacific
