jamestparker
is this a bad way to write this switch?
Jun 11, 2012 1:27 PM
stage.addEventListener(KeyboardEvent.KEY_DOWN, myKeyDown);
function myKeyDown(e:KeyboardEvent):void
    switch (e.keyCode)
        case Keyboard.LEFT :
            prevFrame();
            if (currentFrame < totalFrames)
                nav_mc.next_btn.mouseEnabled = true;
                nav_mc.next_btn.alpha = 1;
            if (currentFrame == 1)
                nav_mc.back_btn.mouseEnabled = false;
                nav_mc.back_btn.alpha = .6;
                nav_mc.text_btn.mouseEnabled = false;
                nav_mc.text_btn.alpha = .6;
            break;
        case Keyboard.RIGHT :
            nextFrame();
            if (currentFrame > 1)
                nav_mc.back_btn.mouseEnabled = true;
                nav_mc.back_btn.alpha = 1;
                nav_mc.text_btn.mouseEnabled = true;
                nav_mc.text_btn.alpha = 1;
            if (currentFrame == totalFrames)
                nav_mc.next_btn.mouseEnabled = false;
                nav_mc.next_btn.alpha = .6;
            break;
    Jun 11, 2012 2:12 PM   in reply to jamestparker
    I see well the switch, maybe you could have problems with the nextFrame () and prevFrame (), but if you do not preocipan, are well
    function myKeyDown(e:KeyboardEvent):void {
        switch (e.keyCode) {
                if (currentFrame > 1) {
                    prevFrame();
                if (currentFrame < totalFrames) {
                    nav_mc.next_btn.mouseEnabled=true;
                    nav_mc.next_btn.alpha=1;
                if (currentFrame == 1) {
                    nav_mc.back_btn.mouseEnabled=false;
                    nav_mc.back_btn.alpha=.6;
                    nav_mc.text_btn.mouseEnabled=false;
                    nav_mc.text_btn.alpha=.6;
                break;
                    nextFrame();
                    nav_mc.back_btn.mouseEnabled=true;
                    nav_mc.back_btn.alpha=1;
                    nav_mc.text_btn.mouseEnabled=true;
                    nav_mc.text_btn.alpha=1;
                if (currentFrame == totalFrames) {
                    nav_mc.next_btn.mouseEnabled=false;
                    nav_mc.next_btn.alpha=.6;
                break;
    Jun 11, 2012 10:49 PM   in reply to jamestparker
    I would recomment you to brake the code into smaller methods/functions
    function myKeyDown(e:KeyboardEvent):void{
        switch (e.keyCode){
                this.turnLeft();
                break;
              this.turnRight();
                break;
    function turnLeft(){
                prevFrame();
                if (currentFrame < totalFrames){
                if (currentFrame == 1){
    function turnRight(){
                nextFrame();
                if (currentFrame > 1){
                if (currentFrame == totalFrames){
    Also, better to add states for buttons, like enabled() and disabled() methods
    Back button code example:
    function enable() {
         this.mouseEnabled=true;
         this.alpha=1;
    function disable() {
         this.mouseEnabled=false;
         this.alpha=0;
    Navigation panel code:
    function enableBackButton() {
         this.back_btn.enable();}
    function disableBackBtn() {
         this.back_btn.disable();
    Later this will allow you to easier change UI elements behaviour, for example, when you will need to add animation for "enable" state. To make development more comfortable try to use classes, with classes you will be able to write code once and use it for all buttons or other UI elements in the movie.
