Newer installation on Win 7 64-bit. If I simply start Flash Pro, wait a minute, and then Exit, I receive an Windows error dialog "Adobe Flash CS5.5 has stopped working. Windows is checking for a solution to the problem..." Nothing ever returns any information, including Debug.
Version 11.5.1.349
Event Viewer shows:
Log Name: Application
Source: Application Error
Date: 6/11/2012 3:51:16 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: <FQ computername>
Description:
Faulting application name: Flash.exe, version: 11.5.1.349, time stamp: 0x4e5bcaea
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc000041d
Fault offset: 0x745c4f0d
Faulting process id: 0x12ac
Faulting application start time: 0x01cd4813e9de84a3
Faulting application path: C:\Program Files (x86)\Adobe\Adobe Flash CS5.5\Flash.exe
Faulting module path: unknown
Report Id: 2fa74946-b407-11e1-9ab6-f0def139320a
I'm assuming none of my files are getting corrupted upon exit...
Any thoughts?
Thanks.
Apologize for the delayed response.
We have had several threads posted reporting the same issue and this is issue is being looked in to by the Flash Professional engineering team on high priority. Could you please try the following workaround to see if it helps resolve your issue?
Go to
C:\Users\«YourUserName»\AppData\Local\Adobe\Flash CS6\en_US\Configuration
there is a fontinfo.txt file. Open this in notepad and delete everything in it and save it, but before starting Flash again, change the properties of that fontinfo.txt file to read only so Flash can't overwrite it again. Seems to clear up the loading crash issue.
Thank you for your patience,
Suhas Yogin
Suhas,
I appreciate the response.
Just to clarify,
Is that still a suggested solution?
Thanks.
Hello,
Yes, you should try the solution I suggested.
If that doesn't work, try recreating your preferences and see if that helps. Please let me know if the solutions worked for you.
Regards,
Suhas Yogin
Suhas,
I cleared the fontinfo.txt file, set it to Read-Only, and still received the error upon exit.
I started Flash while depressing Ctrl-Alt-Shift, received the dialog asking if I wanted to delete the Settings, clicked Yes, and still received the error upon exit.
Let me know what you'd like me to try next.
Thanks!
You can quickly check for a system error to rule that out. Make sure you're on an Administrator level account. Open your run dialog (Winkey + R) and type cmd and click ok. In the black DOS box type:
SFC /SCANNOW
Let the check complete and see if it found any corrupt or fishy files that it can fix for you.
Otherwise I've only seen that specific exception from 32bit apps running on a 64bit OS. And, well, Flash is 32bit and you're running Win7 64bit. However I'm running the same (CS5.5 on Win7 64bit) and do not have this issue.
SCF ran 100% and returned::
"Windows Resource Protection did not find any integrity violations."
Any other suggestions?
This is kind of frustrating. I have Windows 7 64 running on a couple of systems and never had an application crash consistently like this. I'm concerned that the crashing may corrupt files, so would really like to get it figured out.
If the issue is CS5.5 running 32 bit on a 64 bit OS, is there a CS 64 bit version available?
Thanks for any help on this!
I'm having the same problem when exiting Flash CS5.5. I tried the 'fontinfo.txt' file steps but that didn't help.
What DID work was to shut down "TeamViewer" - Free version that let's me access by PC remotely - and try again. And with TeamViewer not running Flash CS5.5 exits normally. To verify, I started TeamViewer back up, and tried opening CS5.5 again, and now the error is back when I exit flash. Maybe Flash is trying to do some final communication before closing, and that doesn't work when certain kinds of programs are also running.
Maybe you've got something similar running?
I'm using CS5.5 on Windows 7 64bit.
An alternative is the open source remote frame buffer protocol that started most of the freeware viewers, VNC. You can get a free personal edition here:
http://www.realvnc.com (Personal Edition, Windows Only, or Open Source for all platforms).
If you buy their premier version you enable things like file sharing and such. This is an ancient technology that's worked for me for half a decade or more and I still rely on it daily (Mac, PC and Linux compatible). TeamViewer is nice because you don't need an IP or to forward ports but you will need to do that with VNC. It's really only second to RDC.
Found this today and it works for me.
"Open TeamViewer, go to Extras>options>Advanced>Show Advanced Options?>QuickConnect then click on Configure. In these options, please uncheck the box that states "Show QuickConnect button".
Then please restart TeamViewer and test the connection again."
Adobe should behave normally now.
North America
Asia Pacific
