I require Freehand support for Illustrator CS6!
Jun 12, 2012 8:12 AM
Do I need to say more? Hey Adobe, do your job!!!
    Jun 12, 2012 9:10 AM   in reply to Peter Idler
    You're not talking to Adobe here. Just a bunch of users helping other users.
    Jun 12, 2012 9:19 AM   in reply to Peter Idler
    No matter what you want, the possibility of Adobe changing their mind on Freehand support in CS6 and beyond are slim and none. Use CS5 or CS5.5 if you need Freehand support.
    Jun 12, 2012 2:23 PM   in reply to Peter Idler
    I will explain it a little bit more to the point, the computer age is moving towards 64 bit only and that soon enought no 32 bit applications will run, at least not native on anyones computer. CS 6 for instance on the Mac only runs in OS  10.6.8 and 10.7.x and evententually the 32 bit support has to be dropped and that goes for Windows operating systems as well and so soon enough no computers on the market will be able to run FH.
    There is therefore no reason to support it. It means you have to move on so start now.
    Now you can always react like we are not helping the cause but the truth is is that we are just stating the facts.
    We are giving you the best advice.
    You should always archive your old files but you should also convert them as soon as possible and I suggest doing it in small groups so you do not encounter purprising in the future.
    I mentioned this a long time ago as soon as Macromedia was absorbed by Adobe but the FH users persist to argue a point that is quite dead. Go figure!
    It has all worked out as I originally stated way back when and what I write here will come to be as well.
    So do yourself a good service with a little extra work it can save you a lot of issues in the future.
    Jun 14, 2012 10:08 PM   in reply to Wade_Zimmerman
    That's an apple mistake and we have no plans to drop 32 bit support for quite awhile, if ever.
    So i suggest to the original poster to consider moving to windows for more freedom.
    As we say the computer does what you want, not what that other company says it should.
    Jun 15, 2012 5:09 AM   in reply to Wade_Zimmerman
    ...evententually the 32 bit support has to be dropped and that goes for Windows operating systems as well and so soon enough no computers on the market will be able to run FH...
    I would rhetorically ask where you come up with such nonsense, but I (and no doubt everyone else) knows you just make it up.
    First off, what does a 64-bit OS running 64-bit applications have to do with preventing one of those 64-bit applications from opening a file? You don't have to run FreeHand to open a FreeHand document with AI CS5 and prior. It's just a data import filter.
    Secondly, I'm still running FreeHand just fine on 64-bit Windows. And many other 32-bit applications, too. In short, you don't know what you're talking about.
    Just who do you think you are Wade? Peter needs to be able to open his legacy FreeHand files in order to "move on," as you put it. "Moving on" is exactly what he's doing by opening his FreeHand files and converting them to AI files.
    Now you can always react like we are not helping the cause but the truth is is that we are just stating the facts. We are giving you the best advice.
    What is all this "we" crap? You don't speak for anyone in this forum but yourself. Get off your high horse and stop pretending you run the show here.
    Peter (as I'm sure he knows) has two choices:
    Since evidently Adobe has removed the FreeHand import from AI CS6, he can open his files in FreeHand and export them to AI format.
    OR...
    SInce evidently Adobe has removed the FreeHand import from AI CS6, he can count this as one more reason not to purchase CS6. He can simply judge that Adobe is not providing enough value for the price of this version, and opt to skip it. If he does, that's probably more Adobe's loss than Peter's.
    After a point as these long-in-the-tooth programs continue to age, less and less practical value is added with new releases for the amounts charged for them, because they are still building upon antequated foundations. Some versions just beg to be skipped (to wit: CS5.5).
    Whichever he choses to do, Peter is free to express here his dissatisfaction at the fact that an omission of justifiably expected functionality in the new version has added a significant amount of inconvenience for him--which is all he was doing.
    JET
    Dec 12, 2012 9:28 AM   in reply to Peter Idler
    I agree with Jet, have freehand 11 still installed on my home system and it runs just fine on a 64 bit OS (Mac and Windows) and the freehand import was only a file format in the plug-ins folder all they had to do was recompile it for CS6...nothing changed in the format itself, still the same thing so I don't understand why tey took it out. I even tried installing the old format plug-in and CS6 just disables it.
    My suggestion is to send in a "wish list" request to have it re-instated
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    if enough people ask maybe they will put it back in ...at work we have over 100k old freehand art files (freehand was nixed from all systems) that are perfectly good and just need updating sometimes (copy, color, etc) so "moving on" is a long and tedios prospect, it could be CS11 before we get to them all.
    Dec 12, 2012 2:27 PM   in reply to Vikingnm
    You can certianlydo that but that will not get you anywhere!
    And even if you want to live by the motto FreeHand is Dead Long Live FreeHand it is still dead and beating a dead horse is futile.
    If you are actually expecting to now just have this plug in available on the basis that FreeHand operates fine on a 64 bit system then think about that again and you will see why your request will be ignored.
    The logic is a bit amiss it is not that the software works or deoes not work on a 64 bit system but the fact that Adobe would have to write the plugin to work ona 64 bit system in order for it to work with a 64 bit Illustrator and that takes resourcess as well as internal and exteernal testing  and since it would be a feature of a current version of Illustrator tht would require customer and tech support at a cost to who? I don't think Adobe would pay for it and certainly the loyal customer base is not going to want to pay for it, especially since there is no future use for such a plug in. Unless youwish to pay for the development. Which is not a bad idea if you guys could somehow show that there are more than a couple of dozen Freehand users out there that actually would pay for the development of such a plug in that one of Adobe's partners would develop such a plug in, well then you might get your wish.
    Someone has to pay!
    Dec 12, 2012 3:22 PM   in reply to Peter Idler
    I know freehand is "dead" the problem is them taking away something that is necissary to utalise older assets that was available until this...which brings me to the 64 bit thing. the last version WAS a 64 bit version that worked in CS5 and the point of the freehand working is that 64 bit makes no difference in the operation of a program, 32 bit programs work mostly fine and just ignore the upper 32 bits (over simplification but that's the general idea)...freehand is just an example of that fact. There is no expense to Adobe save a recompile to be more with CS6. I'm actually a coder so know about this little tidbit. In fact having a 32 bit plug-in means nothing...anyone who works in after effects can atest to this as some of the plug-ins are actually still 16 bit and a few 8 bit. So again the only thing they really have to do is re-compile it to work better with CS6.
    Yes using the link and submitting the request is more a sanity thing on our end hense the word "maybe"
    last note...the only thing a 64 bit OS gives you is a larger pointer address for accessing more memory it also helps with program performance (and if it's programmed for 64 bit native) but memory is the main thing...plus 64 bit looks more impressive on the packaging ...here is a few links in case anyone is interested...
    http://support.microsoft.com/kb/946765
    http://en.wikipedia.org/wiki/64-bit_computing
    http://forums.extremeoverclocking.com/t283289.html (note the second post)
    http://www.ni.com/white-paper/5709/en#toc1
    Dec 12, 2012 7:18 PM   in reply to Vikingnm
    Ok according to you all they have to do is nothing but move the plug in to CS  6 being the prhgrammer you are I am sure you ae correct and it is nothing at all to do this.
    So why don't you take the plug in and copy it to the appropriate folder in CS 6 and there you are…or does that nbot work? So simply?
    Then as the programmer you are why not make the plug in compatible with CS 6 and post it for everyone who needs it since it is so simple, if it is as simple as you say I see no reason why you can't do this yourself.
    Good idea huh?
    Dec 13, 2012 9:23 AM   in reply to Wade_Zimmerman
    as I said before moving the plug in doesn't work; however, them having the original source code and knowledge of how it works makes it extremely easy for them to recompile it to make it CS6 compatable...if they send the source code I would be happy to work on it.
    Dec 13, 2012 12:06 PM   in reply to Vikingnm
    So there you are if they think that they want to do this they will contact you and if you do not hear from them then you will know there is no interest.
    I guess that would be pretty cler about the futrue one way or the other.
    But I do not see why you cannot use the SDK to write such a simple plug in to work for Illustrator CS6 I mean that contains all the code you need to accomplish such an easy task as it seems so important to you.
    And there is a forum for the SDK as well and though I have not been there recently I wonder if anyone with this complaint has not wonder over there to ask if it could be done and if the said yes o ask how and if they said no to ask why?
    Makes sense to me.
    Dec 13, 2012 1:36 PM   in reply to Wade_Zimmerman
    the freehand file format isn't open, "copywrited" by Macromedia and still like that under Adobe (unless they opened it up) so in order for anyone to make a plug-in they would need their permission. Does anyone know if the format is open or not?
    Dec 13, 2012 5:13 PM   in reply to Vikingnm
    You're asking in the wrong forum. why i shis so hard to understand go to the SDK forum and inquire with other developers and the like why waste our time here?
    See the screen shot, what  could be more appropriate than to ask people who actally might know. For all you know the plug in already exist
    Dec 14, 2012 5:45 AM   in reply to Peter Idler
    You should read some of those psoing on that forum and you will see that the hand writing is on the wall and they know it as well.
    I am trying to help but you are correct that sometimes one cannot help and one has to accept it.
    I wish you all well and hope you all find a solution to your issues with Adobe.
    Dec 14, 2012 7:40 AM   in reply to Vikingnm
    This is the way to go through the correct channels at Adobe but you will want to have a LOT of requests on the wishlist. Plenty of active FreeHand users are out there but it sure ain't going to be here in this forum. Start with the Adobe FreeHand forum on this longstanding thread where a large number of subscribers will see the notice. Then post to the FreeHand Forum where they have an Illustrator section. It would be smart to send a request email to info@freehandforum.org too. And the FreeHand Discussion list too where long-time users are. I'd love to see the conversion reinstated in CS7.
