TD99
Using new Adove Media Encoder with Premiere pro cs4
Jun 14, 2012 12:24 PM
I have Premiere Pro Cs4 and Design&Web premium CS6 -  which comes with Adobe Media Encoder cs6. Can I get Premiere Pro CS4 to use the new encoder (and hopefully speed up)?
    Jun 14, 2012 9:26 PM   in reply to TD99
    Try it.  If it works, then yes.  If it doesn't, then no.
    Jun 15, 2012 4:04 PM   in reply to TD99
    You probably have to work the other way around.
    Import Premiere sequences and then set the encoder.
    Jun 19, 2013 6:07 AM   in reply to Ann Bens
    I am on Window 7 32-bit that Premiere CS6 does not work. So I use CS4 for editing. For one specific project, I kept getting errors when using AME CS4 and it was extremely slow (8min of video estimated 20 hours). Someone said CS4 4.2 is really slow so I'd like to use AME CS6 to render project files from CS4. Tried that but got adobe dynamic link components error. I think it may be because I didn't include Premiere and After Effects when installing CS6.
    Do you have success using AME CS6 on CS4 project file? Is it likely to make it work without installing CS6 one more time?
