Cant find a name
Digital Editions Activation Error
Jun 14, 2012 7:09 PM
I am trying to activate Adobe Digital Editions and I keep getting an activation error that I can't seem to paste here.  Adept request required is the way it starts.  Any suggestions?
    Jun 15, 2012 9:30 AM   in reply to Cant find a name
    Moving this discussion to the Adobe Digital Editions forum.
    Jun 15, 2012 3:08 PM   in reply to Jeff A Wright
    It seems that these types of errors come in bunches to the Forum.....
    This is the text from ADE HELP (which you can review using the F1 key from
    Library or Reading view):
    "Activation and authorization
    After installation, the Setup Assistant wizard prompts you to activate
    Adobe Digital Editions (you must be online during this process). During
    activation, you have the option to authorize your computer with an Adobe
    ID. If you don't have an Adobe ID, creating one is free and only takes a
    minute. The Adobe ID enables you to transfer items protected by digital
    rights management (DRM) between multiple computers or devices and restore
    them after a data loss or system reinstallation.
    An Adobe ID also includes an Adobe membership, which gives you access to
    trial downloads, hundreds of free product extensions, and special community
    areas. It also allows you to view and manage your activity in the Adobe
    Worldwide Store.
    Adobe strongly recommends that you authorize your computer at initial
    activation to protect your digital content. If you choose to authorize at a
    later time, you can do so by choosing Library > Authorize Computer.
    After activation, any books, magazines, or other documents you previously
    bought with Adobe Acrobat® or Reader® software are migrated to Adobe
    Digital Editions. This is usually a relatively quick process. Adobe Digital
    Editions opens each item and reverifies its license to the user. If you
    don't have DRM-protected items, you don't need to be online during the
    migration. If you have a large number of items (for example, more than
    100), then this process may take a while, but you will see a progress bar
    indicating the state of the migration as it proceeds.
    Note: Items that you previously borrowed from a public library with Adobe
    Acrobat® or Reader® software are not migrated to Adobe Digital Editions.
    You need to return the library item and then borrow the item again with
    Digital Editions.
    Adobe Digital Editions then does some housekeeping (setting up the manifest
    and application shortcuts) and launches."
    Translation: when you download and install ADE, you should have an Adobe
    ID that you got when you registered with Adobe, and you should use that ID
    during the activation process.  If you did not have an Adobe ID, then you
    could fix that by going to Adobe and registering during the installation
    process.  If you've done that, then ADE should be on autopilot.
    You mentioned a message.  I'd bet the message says something like
    E_ADEPT_REQUEST_EXPIRED.  That message means your computer's time, date and
    time zone are not in agreement with Adobe's record of your computer.  Check
    that information and MAKE SURE that they are correct.  If the message
    persists, that can mean your attempt at installing Digital Editions has
    passed its 'good until' time and/or date, and you might be better off to
    reinstall it.
