Been trying to setup a roll over button thst shows the button as being visted by an image.
I have Dreamweaver CS6 Here is the roll over button sequence:
The above image button is what you would see before the mouse cursor goes over.
The following button is what you'll see once you put your mouse cursor on it:
And the last button you'll see once you already clicked on it:
I am using the latest Firefox browser and from Dreamweaver - Insert - Image Objects - Rollover Image and went through the process of insert button image #1 and button image #2.
I've looked at the code that was generated by Dreamweaver and feel I am missing something, yet not sure what it is.
Any suggestions/recommendations would be a BIG help.
Below is the code that was generated by Dreamweaver.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
<style type="text/css">
a:visited {
background-image: url(Country4Animal-4-web-images/91132.jpg);
</style>
</head>
<body onload="MM_preloadImages('Country4Animal-3-web-images/9112.jpg')">
<a href="http://forums.adobe.com/message/1037124#1037124" target="_blank" onmouseover="MM_swapImage('Image1','','Country4Animal-3-web-images/91 12.jpg',1)" onmouseout="MM_swapImgRestore()"><img src="Country4Animal-2-web-images/9112.jpg" width="123" height="40" id="Image1" /></a>
</body>
</html>
This can be done very effectively with CSS.
http://alt-web.com/DEMOS/CSS-Button-Sprite.shtml
a:link = normal, unvisited link
a:visited = a link that has been previously visited
a:hover = on mouse over
a:active = immediately when clicked
a:focus = when reached with tab key
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
North America
Asia Pacific
