I have 5.5 MacBook Pro 13 running 10.7.4.
I am trying to install Flash Pro CS6 Trial .. this error appears in the beginning of the installation process (when the progress bar is around 1%) :
Exit Code: 34
-------------------------------------- Summary --------------------------------------
- 1 fatal error(s), 0 error(s), 0 warning(s)
FATAL: Payload '{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.98.0' information not found in Media_db.
Any ideas how to fix that ?
p.s. i did restart, closed all apps, etc, etc ..
Okay, plenty of time has passed.
Seriously, I need some help guys.
I am ActionScript developer from Macromedia Flash 8 till now .. it is really sad that I can't use Adobe Flash CS6 ...
Do you meet the minimum specs:
Which Intel Processor do you have? Early Intels won't cut it.
It is MacBook Pro 13 inch 5.5, this means : 2.26 P8400 Core 2 Duo Intel Processor, 2 GB RAM 1033 MHZ, 1280x800, 160GB HDD (basic version).
Mine has 4 gigs of ram. All my 3rd party software (that are mentioned in the reqs) products are up-to-date.
Do you have any previous version Adobe software already installed like CS5 or CS5.5 ?
Log into the Root user account and check the status.
I had Adobe Flash CS5 and Adobe Flash CS5.5 trial, i have non of them now. Probably some files left / settings left ?
I enabled the root user account, tried to intall again - same error. What status should I check ?
Hello ?
I can't install, this is pretty major issue for me ..
Any more ideas ? Send log to somebody ?
I should i reinstall the OS ?
Run the Cleaner tool to remove the remaining component and then check installing.
www.adobe.com/support/contact/cscleanertool.html
Thank you, that do the trick (y)
It will be quite useful if there is "Can't install FAQ" ..
