Output exception NullPointer Exception
Jun 17, 2012 8:55 PM
Hi all
I get this error when updating a record:
The cause of this output exception was that: java.lang.NullPointerException.
78 :    MEETING= <cfqueryparam cfsqltype="cf_sql_timestamp" value="#meetingDate#" />
This is the code that sets the meetingDate:
<cfset meetingDate = trim(form.meeting)>
<cfif not isDate(meetingDate)>
<cfelseif DayOfWeek(Now()) eq 5>
<cfset meetingDate = dateAdd("d", 4, now())>
<cfelseif DayOfWeek(Now()) eq 1>
<cfset meetingDate = dateAdd("d", 3, now())>
<cfelse>
<cfset meetingDate = dateAdd("d", 2, now())>
</cfif>
It works when I use this code, but I am using some more conditions now:
</cfif>
Why does it throw the java error? Thank you
    Jun 18, 2012 4:55 AM   in reply to goodychurro1
    When in doubt, look at your data.  What is the value of form.meeting?  What is the value of meetingDate after the block of code?
    I suggest outputting bits of text after each if, elseif, and else tag so you can see which ones return true.
    Jun 20, 2012 4:56 AM   in reply to goodychurro1
    If you have all that stuff working correctly, leave it and check to see if your meetingDate is a holiday afterwards.
