jeffbottom
how to save a UTF-8 encoded text file ?
Jun 18, 2012 7:01 PM
Tags: #file #utf-8
hi People
I have a little script which reads the source text from a layer and saves it to a .txt file. This is on a Mac and all was good until recently when I tried opening the .txt file on a PC in Notepad and found my ˚ degree symbols all whack.
Resaving the .txt file in TextEdit as Unicode (UTF-8) encoding solved the problem, now opens fine in Notepad.
But ideally I'd like the script to output the .txt as UTF-8 in the first place. It's currently Western (Mac OS Roman). I've tryed adding in myfile.encoding = "UTF8" but the resulting file is still Western (and the special charaters have wigged out again)
any help greatly appreciated../daniel
    var theComp = app.project.activeItem;
    var dataRO = theComp.layer("dataRO").sourceText;
    // prompt user to save file
    var theFile = new File ("~/Desktop/"+ theComp.name + "_output.txt");
    theFile = theFile.saveDlg("Save an ASCII export file.");
    if (theFile != null) {          // check user didn't cancel dialog
        theFile.lineFeed = "windows";
        //theFile.encoding = "UTF8";
        theFile.open("w","TEXT","????");
        theFile.writeln("move details:");
        theFile.writeln(dataRO.value.toString());
    theFile.close();
    Jun 18, 2012 9:51 PM   in reply to jeffbottom
    Have you tried setting the encoding after you open the file?
    Dan
    Jun 19, 2012 6:44 PM   in reply to jeffbottom
    I remember working hard two years ago on creating a correct text file on OSX, but did not remember if it was a utf-8 case or anything. As my home computer is not a mac, I have no mean to test it tonight, but anyway, here is the big line of it. :
    var theFile= new File(.........);
    theFile.open("w", "TEXT");
    theFile.encoding = "BINARY"
    theFile.linefeed = "Unix"
    theFile.writeln("éàçËôù")
    theFile.close();
    Let me know if it is working.
    Jun 20, 2012 7:18 AM   in reply to jeffbottom
    Hi, I was just looking at how a  text software knows what is the text encoding of a file is and I found that on wikipedia. http://en.wikipedia.org/wiki/Byte_order_mark
    So I created a utf8 file in notepad, and look at the binary. At the start of the file, there is those caracters : 0xEF,0xBB,0xBF or
    So you should try to add those characters at the start of the  file.
    theFile.write("");//or theFile.write(String.fromCharCode (0xEF) + String.fromCharCode (0xEB) + String.fromCharCode (0xBF)
    theFile.write("Your stuff éàçËôù");
    theFile.close();
    Jun 21, 2012 5:39 PM   in reply to jeffbottom
    Got it, it seems, the utf-8 standard use 2-bytes (and more) encoding on accents and special characters.
    I found some info there with some code http://ivoronline.com/Coding/Theory/Tutorials/Encoding%20-%20Text%20-% 20UTF%208.php
    However there was some error so I fixed it. (However for 3 and 4 bytes characters i didnt test it. So maybe you'll have to change back the 0xbf to 0x3f or something else.)
    So here is the code.
    Header 1
    function convertCharToUTF(character){
        var utfBytes = "";
        c = character.charCodeAt(0)
        if (c < 0x80) {
            utfBytes =  String.fromCharCode (c);
        else if (c < 0x800) {
            utfBytes =  String.fromCharCode (0xC0 | c>>6);
            utfBytes +=  String.fromCharCode (0x80 | c & 0xbF);
        else if (c < 0x10000) {
            utfBytes = String.fromCharCode (0xE0 | c>>12);
            utfBytes += String.fromCharCode (0x80 | c>>6 & 0xbF);
        else if (c < 0x200000) {
            utfBytes += String.fromCharCode (0xF0 | c>>18);
            utfBytes += String.fromCharCode (0x80 | c>>12 & 0xbF);
            utfBytes =+ String.fromCharCode (0x80 | c & 0xbF);
            return utfBytes
    function convertStringToUTF(stringToConvert){
        var utfString = ""
        for (var i = 0 ; i < stringToConvert.length; i++){
            utfString = utfString + convertCharToUTF(stringToConvert.charAt (i))
        return utfString;
    var theFile= new File("~/Desktop/_output.txt");
    theFile.write(convertStringToUTF("Your stuff éàçËôù"));
    theFile.close();
