What’s new in this release
Jun 19, 2012 6:15 AM
Branched to a new discussion.
    Oct 5, 2012 1:56 PM   in reply to Community Help
    The new video overlay features are not working correctly. I loaded a .mp4 file to use on the cover, the poster (start frame) won't set correctly nor does it end on the last frame when complete, it resets to the start frame. I have all the check boxes set (Do Not Allow Pause, Stop on Last Frame, ect.)
  • Bob Bringhurst
    May 29, 2007
    Oct 5, 2012 2:55 PM   in reply to baddmojo67
    Are you looking at a v23 folio?
    Oct 8, 2012 6:52 AM   in reply to Bob Bringhurst
    That was it Bob, the build was defualted to v20. Switched it to v23, republished and works. Awesome!
    Nov 12, 2012 3:29 AM   in reply to Community Help
    Any improvement on the download counter details ?
    Finance need download details per application account to do cost allocation.
    Now I am doing it manually based on analytics download data, lots of maths.
    Can I export the analytics data to Excel, it helps a lot !!
    Jan 23, 2013 9:48 AM   in reply to Community Help
    Does V25 address the known bug with Content viewer and most of DPS apps on Android when run on Android 4.2 or android 4.1.2 or the DPS Apps crashing issue on ASUS tablets.
    Bob
    Jan 23, 2013 10:01 AM   in reply to Bob.houlihan
    Yes, it should. We updated to a new version of AIR with several bug fixes around these issues.
    Neil
    Jan 23, 2013 10:08 AM   in reply to Neil Enns - Adobe
    Thanks Neil.
    Jan 24, 2013 3:50 PM   in reply to Community Help
    What is the 'preview pane' mentioned in the UI Improvements? Is that just the cover image taken from the Folio Producer or is it possible to present a preview of the inside pages of the publication?
  • Bob Bringhurst
    May 29, 2007
    Jan 24, 2013 4:00 PM   in reply to micfur563
    At this time, the preview pane that pops up when you select an undownloaded folio displays the same cover image. The ability to preview additional images is planned for a future release.
    Jan 25, 2013 6:56 AM   in reply to Community Help
    Hi there,
    Where can I find the latest documentation of the Adobe DPS - JavaScript Library API and Custom HTML Store API?
    My custom Library and Custom Store don't work on v25 anymore.
    Thanks.
    Jan 25, 2013 8:48 AM   in reply to John J Metzger
    Hmm, I wasn't aware of breaking changes in the API. William, was there an error you were getting? What wasn't working?
    Neil
    Jan 25, 2013 11:04 AM   in reply to Neil Enns - Adobe
    Ok, scratch what this post used to say. Misunderstanding on my end. There are no explicit breaking changes, your v24 store should be working fine. I need to know what specific issue you are seeing so we can pass that on to the engineering team to investigate. Thanks!
    Neil
    Jan 28, 2013 1:50 AM   in reply to Neil Enns - Adobe
    Hi Neil,
    you are correct. The Custom HTML Store that we have developed worked just fine. What about Custom HTML Libraries?
    I compared the file AdobeLibraryAPI.js from r23 and r25 and they are quite different.
    Up to r24, the Custom HTML Library was incompatible with Custom HTML Store. Apparently, the Store API (adobe.dps.store) was replaced by the Library API (adobeDPS.libraryService). Can you confirm if this is still the case?
    Also, I really need a way to switch from one application state to another, something like adobe.dps.store.goToLibrary() or adobe.dps.store.goTo('library'). Is there anyway to achieve this? Maybe using the Library API?
    Thanks a lot for your help. Cheers!
    PS: I'm from Amsterdam. The time difference is just annoying.
    Jan 28, 2013 5:43 AM   in reply to William R. J. Ribeiro
    Hi Neil,
    Just to give you more info on this issue, I tested one of Adobe's HTML Store template (http://www.adobe.com/devnet/digitalpublishingsuite/articles/library-st ore-combined-template.html) and it doesn't work with r25. For what I could see, this call never returns:
    adobeDPS.initializationComplete.addOnce(function(){ init(true) });
    To go a bit deeper, I guess this line is not working:
    window.location = bridge://%7B%22event%22%3A%7B%22type%22%3A%22BridgeInitialized%22%2C% 22bridgeLocation%22%3A%22adobeDPS._bridge%22%7D%7D
    Looking forward to your reply.
    Jan 28, 2013 7:56 AM   in reply to William R. J. Ribeiro
    Thanks for the info William, and for the clarification that you are moving from v23, not v24. I'm checking with both our engineering team and our developer documentation team to see what they know.
    Neil
    Jan 28, 2013 9:10 AM   in reply to William R. J. Ribeiro
    Hi William,
    Are you replacing the default library with a custom library?
    Derek
    Jan 29, 2013 2:17 AM   in reply to derek_lu
    Hi Derek,
    Nope. I just create a new toolbar icon and use my custom html store. Adobe's HTML Store template - the link from my previous comment - doesn't work with r24 and r25 neither. None of my tests are working with the new Library API but all work when I use the old Store API and this is quite frustrating. Could you please provide a bare minimal sample of how to use the Library API that works on r25?
    Thanks!
    Jan 29, 2013 9:04 AM   in reply to William R. J. Ribeiro
    Hi William,
    You need to replace the default library with a custom library in order for the v2 library APIs to work. If you grab HTMLResources.zip from the set of files in http://www.adobe.com/devnet/digitalpublishingsuite/articles/library-st ore-combined-template.html and replace the default library then the v2 library will work. If you don't replace the default library then the v1 APIs are the only thing available.
    If you cannot use a custom library then contact me offline and I can send you a workaround, delu at adobe.
    Derek
    Jan 30, 2013 1:16 AM   in reply to derek_lu
    Hi Derek,
    your suggestion worked! But in my case, I want to use the default DPS Library and use just my custom HTML Store developed with v2 Library APIs. Is this possible?
    Thank you so much for your help.
    Regards.
    Jan 30, 2013 7:58 AM   in reply to William R. J. Ribeiro
    Currently that isn't possible.
    Neil
    Jan 30, 2013 9:20 AM   in reply to William R. J. Ribeiro
    Hi William,
    I contacted you offline with a workaround.
    Derek
    Feb 6, 2013 1:15 AM   in reply to derek_lu
    It seems that initializationComplete don't work now in any case: with old AdobeLibraryAPI.js (from HTMLResources.zip) and with new official AdobeLibraryAPI v2.25.
    Feb 6, 2013 8:06 AM   in reply to Yuriy Petrov
    Hi Yuriy,
    Are you replacing the default library with a custom library? Without a custom library the v2 apis will not work.
    Derek
