Darcus78
Embed pdf in document
Jun 20, 2012 4:45 AM
Tags: #illustrator #pdf #script
Hi all
First post and first script
Im trying to add a pdf on top of an existing PDF in illustrator using a script. This is supposed to be done by anyone at my firm so that is why I want it in a script. I also have a lot of other functions that works that will do some other stuff with this document.
Created this from the scripting guide but it doesnt work. Im pretty sure its the embedDoc var thats empty and i dont understand why.
Im not sure if the File "points" to the directory of the script or the original file but Ive tried both ofcoarse.
This is the masterpiece
var embedDoc = new File("/temp/testfile1.pdf");
if ( app.documents.length > 0 && embedDoc.exists ) {
var doc = app.activeDocument;
var placed = doc.groupItems.createFromFile( embedDoc );
}else {alert("suck")}
//Marcus
    Jun 20, 2012 6:26 AM   in reply to Darcus78
    I would not have thought your path was valid have you tried to just test that condition on its own?
    alert ( File("/temp/testfile1.pdf").exists );
    Jun 20, 2012 2:44 PM   in reply to Darcus78
    / always starts at the root of your current drive. What *that* means depends on your OS!
    You'd get the path from your current file by something like
    currPath = app.activeDocument.path;
    .. then you can add your temp folder with
    embedDoc = new File(currPath+'/temp/testfile.pdf");
    .. but *only* if that sub-folder actually exists in the path you stored the file in. The actual code depends entirely on your workflow, I guess.
    Jun 20, 2012 2:49 PM   in reply to Darcus78
    Are you debugging your script in the ESTK or just writing it in a text editor? What OS are you on? Where is this PDF file? ( the full path )
