Presenter 7 add-in disabled itself in PPT 2010 can't enable it
Jun 20, 2012 3:12 PM
I have the Acrobat X Suite (including Adobe Presenter). I upgraded to Office 2010.
The Adobe Presenter menu item stopped appearing when I opened Powerpoint .
I uninstalled Presenter and downloaded Presenter 7.07 and installed it as a trial. I then used the installer for Presenter in the Acrobat X Suite to apply the license key.
Everything worked fine for awhile and then the Presenter add-in disabled itself.
I tried to enable it with no luck. I went through the whole process that I just described again (uninstalling, downloading, re-installing as a trial, and then running the install from Acrobat X Suite for Presenter, and I still can't enable the Presenter add-in (though it appears on the add-in list--as disabled). I'd appreciate help. I have some files I need to re-publish for a course.
Thanks. Susan
  • Jorma Jennings
    Jul 5, 2007
    Jun 21, 2012 10:54 AM   in reply to campbellsusan
    Launch PPT.
    Select the File menu
    Select PowerPoint Options
    Choose the Add-Ins section
    At the bottom you should see a Manage: option with a drop down menu
    Select the Disabled items option and click Go.
    Select Presenter and then Enable
    Close and restart PPT.
    Keep an eye on the messages that come up if PPT crashes again, and if you see the "There was a problem with the Presetner plug-in, do you want to disable it?" dialog, say no.
