Will imported html articles run natively?
Jun 20, 2012 8:42 PM
Tags: #digital_publishing_suite #import_html_articles #run_natively
Will an html article (created with CSS & Javascript) that is imported into DPS and published to the App store run natively on an iPad tablet or will the html pages still require access to the internet to run? Do DPS imported html pages become part of the native app?
    Jun 20, 2012 11:53 PM   in reply to HONGina
    The HTML will be included for offline viewing in the folio.
    —Johannes
    Jul 22, 2012 12:27 PM   in reply to HONGina
    No it won't as it is requesting a live site. Just use the common practice for that:
    <!-- Grab Google CDN's jQuery, with a protocol relative URL; fall back to local if offline -->
        <script src="//ajax.googleapis.com/ajax/libs/jquery/1.7.2/jquery.min.js"></script>
        <script>window.jQuery || document.write('<script src="local/js/jquery-1.7.2.min.js"><\/script>')</script>
    Jul 23, 2012 11:41 PM   in reply to HONGina
    This now should work if you edit the local jQuery path to where your local jQuery file is located.
    <!doctype html>
    <html>
    <head>
              <meta charset="UTF-8">
              <title>DPS HTML5-Boilerplate</title>
              <meta name="description" content="Description">
              <!-- Please be aware that this prevents the user from scaling your website via pinch-gesture. The user is not able to zoom text or other elements. If you need scaling, do not use this snippet but the one listed on h5bp.com/viewport -->
              <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no, target-densitydpi=device-dpi">
              <!-- add css here and meta as well as a title -->
    </head>
    <body>
       <div id="showquestion" class="answers"></div>
       <!-- Now load your javascript regardless it is online or offline -->
       <script src="http://code.jquery.com/jquery-1.7.2.min.js"></script>
       <script>
         $('document').ready(function(){
                        var count = 0;
                            $('#questions').hide();
                            $('#answers').hide();
                            $('#questions tr:nth-child(2)').attr('id','currow');
                            var q1 = $('#currow td:nth-child(2)').html();
                            var q3 = '<div id="d' + count + '"><p>' + q1 + '</p>' ;
                            var a1 =  $('#currow td:nth-child(3)').html();
                            var r1 = q3 + a1 +'</div>';
                            $('#showquestion').html(r1);
                            $('li').live('click',function(){
                                $(this).addClass('selected').siblings().removeClass('selected');
                                var target = $(this).attr('id');
                                var parid = $(this).parent().parent().attr('id');
                                var parnum = parseInt(parid.slice(1,3));
                                count = count + 1;
                                var ps = $('#showquestion div').length;
                                $('#showquestion div').each(function() {
                                    var divid = $(this).attr('id');
                                    var divnum = parseInt(divid.slice(1,3));
                                    if(divnum > parnum)
                                        $(this).remove();
                                $('td' ).each(function(){
                                    var qnum = $(this).text();
                                    if(qnum == target) {
                                        var q = $(this).next('td').html();
                                        var q2 = '<div  id="d' + count + ' "><p>' + q + '</p>';
                                        var a = $(this).next('td').next('td').html();
                                        var qs = $('#showquestion').html();
                                        var r = qs + q2 + a +'</div>';
                                        $('#showquestion').html(r);
                                        window.scrollBy(0,400);
       </script>
    </body>
    </html>
    Jul 24, 2012 10:07 AM   in reply to HONGina
    Then the only chance how I can help: Get Adobe Shadow, test it and inspect in console what's going on there. Or send me your files and I will look into this but it may take some more time as I nearly have no spare time at the moment.
  • Casey Jensen
    May 4, 2011
    Jul 24, 2012 10:18 AM   in reply to HONGina
    HONGina,
    You're missing part of what users are saying here. You need to include the jquery/css locally, not path to it at an external internet address. Doing that will always require an internet connection. So you must include these resources it in the HTMLResources.zip, or use a local path so that it is pulled in when the HTML article is bundled.
    Example:
       <script src="../HTMLResources/js/jquery-1.7.2.min.js"></script>
    Please read the PDF for more details.
    http://help.adobe.com/en_US/digitalpubsuite/using/digitalpubsuite_help .pdf
