It's posible a custom eventListener to detect copy and paste.
myDocument.eventListeners.add("beforePaste", myBeforePasteFunction);
"beforePaste" is not listed anywhere in the Help as a supported event. The current list is beforeClose, beforeDeactivate, beforeDelete, beforeDisplay, beforeEmbed, beforeExport, beforeImport, beforeInvoke, beforeMove, beforeNew, beforeOpen, beforePlace, beforePrint, beforeQuit, beforeRevert, beforeSave, beforeSaveACopy, beforeSaveAs, befureUnembed, and beforeUpdate.
See http://jongware.mit.edu/idcs5.5js_html/idcs5.5js/pc_Event.html for the complete list of events (CS5.5, but it seems CS6 has changed nothing). Note that not all events are applicable to all objects. Select one of the objects in the "parent" list to see which ones are supported for that. If an object supports events, these are listed under the sub-heading "Class", below "Properties".
See for example http://jongware.mit.edu/idcs5.5js_html/idcs5.5js/pc_Link.html. This one contains "AFTER_DELETE" and "BEFORE_DELETE", but that only applies to links, and not to any other object such as text or pages.
You can monitor copy/paste by attaching event listeners to menu items of "Copy" and "Paste" commands.
Something like this:
#targetengine "tomaxxiTEST"
( function () {
main ();
function main () {
var
beforeCopy = app.menuActions.itemByID ( 270 ).addEventListener ( "beforeInvoke", eventHandler ), // COPY
afterCopy = app.menuActions.itemByID ( 270 ).addEventListener ( "afterInvoke", eventHandler ), // COPY
beforeCut = app.menuActions.itemByID ( 269 ).addEventListener ( "beforeInvoke", eventHandler ), // CUT
afterCut = app.menuActions.itemByID ( 269 ).addEventListener ( "afterInvoke", eventHandler ), // CUT
beforeClear = app.menuActions.itemByID ( 272 ).addEventListener ( "beforeInvoke", eventHandler ), // CLEAR
afterClear = app.menuActions.itemByID ( 272 ).addEventListener ( "afterInvoke", eventHandler ), // CLEAR
beforePaste = app.menuActions.itemByID ( 271 ).addEventListener ( "beforeInvoke", eventHandler ), // PASTE
afterPaste = app.menuActions.itemByID ( 271 ).addEventListener ( "afterInvoke", eventHandler ), // PASTE
beforePasteInPlace = app.menuActions.itemByID ( 273 ).addEventListener ( "beforeInvoke", eventHandler ), // PASTE IN PLACE
afterPasteInPlace = app.menuActions.itemByID ( 273 ).addEventListener ( "afterInvoke", eventHandler ), // PASTE IN PLACE
beforePasteInto = app.menuActions.itemByID ( 274 ).addEventListener ( "beforeInvoke", eventHandler ), // PASTE INTO
afterPasteInto = app.menuActions.itemByID ( 274 ).addEventListener ( "afterInvoke", eventHandler ); // PASTE INTO
function eventHandler ( evt ) {
alert ( evt.eventType + " | " + evt.currentTarget.name );
Hope that helps.
Marijan (tomaxxi)
See also the 2nd snippet at:
http://www.indiscripts.com/post/2010/02/how-to-create-your-own-indesig n-menus
which illustrates how to 'spy' the Paste action. The same approach can be used for Copy/Cut/etc. as Marijan showed.
Marc
This will do the job:
var
menuActions = app.menuActions,
menuActionsLength = menuActions.length,
menuActionsList = [],
newDoc = app.documents.add (),
docPage = newDoc.pages [ 0 ],
docMargins = docPage.marginPreferences,
actionsTextFrameBounds = [
docPage.bounds [ 0 ] + docMargins.top,
docPage.bounds [ 1 ] + docMargins.left,
docPage.bounds [ 2 ] - docMargins.bottom,
docPage.bounds [ 3 ] - docMargins.right, ],
actionsTextFrame = newDoc.pages [ 0 ].textFrames.add ( { geometricBounds : actionsTextFrameBounds } ),
actionsTable = actionsTextFrame.insertionPoints [ 0 ].tables.add ( { columnCount : 3, bodyRowCount : menuActionsLength } ),
i = 0;
for ( i ; i < menuActionsLength ; i++ )
menuActionsList.push ( menuActions [ i ].name.toString () ),
menuActionsList.push ( menuActions [ i ].area.toString () ),
menuActionsList.push ( menuActions [ i ].id.toString () );
actionsTable.contents = menuActionsList;
HTH.
Marijan (tomaxxi)
North America
Asia Pacific
