• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Use Of XmlFormat() in ColdFusion - 9
Participant ,
Jun 21, 2012 Jun 21, 2012
Hi All,
I found that XmlFormat() function does the formatting of the any Xml text and removes any XML unsafe characters from that XML text.
I just wrote below code to test this function.
<cfsavecontent variable="x" >
<?xml version = "1.0"?>
<someXML>
    <someElement someAttribute="'a quoted value'">
       Body of element with <, >, "" and & goes here.
    </someElement>
</someXML>
</cfsavecontent>
<cfset x = XmlFormat(x) />
<cfscript>
          y = XmlParse(trim(x));
          writeDump(y);
</cfscript>
Then I got another error message
An error occured while Parsing an XML document.
Reference is not allowed in prolog.
I know that by replacing the special characters from the XML text by string replace functions everything will be fine. But, I want to know what is the exact use of XmlFormat() function.
Thanks in advance for any help.
Views
1.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate ,
You don't encode the entire document. Only the pieces that should be encoded.
<someXML>
       #xmlFormat("Body of element with <, >, "" and & goes here.")#
    </someElement>
</someXML>
</cfsavecontent>
Votes
Translate
Translate
Report
Report
Participant ,
Thanks for the quick response.
I can understand what you are saying. Suppose I am getting the result from one HTTP call and which contains some special characters in the XML text. How could I do it?
Votes
Translate
Translate
Report
Report
Advocate ,
If the XML is already constructed without proper encoding then you'll have a hard time getting it encoded properly.  You could try parsing it and reconstructing it with proper encoding, but if it has characters that interfere with the parsing, then you are hosed.
jason
Votes
Translate
Translate
Report
Report
Participant ,
Does the above line means Xml Parsing or regular expression Parsing of Xml string. Can you please explain your idea?
Votes
Translate
Translate
Report
Report
LEGEND ,
Jun 22, 2012 Jun 22, 2012
The first thing I would do is to get in touch with whoever is providing the XML and let them know it's malformed.  They might just fix it at their end.  This would be the best (initial ~) approach.
Adam
Votes
Translate
Translate
Report
Report
Advocate ,
LATEST
Agreed
Votes
Translate
Translate
Report
Report
Resources
Documentation
