I justed downloaded Adobe Captivate 6, and installed it as a trial. I didn't find the Multi-SCO Packager. So it was still not included in Adobe Captivate 6?
It hasn't been in the last two releases of Captivate 5 and 5.5. Captivate 4 was the only standalone version of Cp to include the Multi-SCORM Packager.
No doubt it will be included in the next version of the E-learning Suite. From what I've heard, it will also be a much more functional tool. Should be worth waiting for.
Much more functional? I'm curious! I'd like to see the Aggregator be more functional - in include SCORM support...
Aggregator with SCORM support? Log an enhancement request...
Thanks, Rod. To be frank, I was a bit disappointed to find that Adobe neglected our suggestions.
By the way, the launch screen of Adobe Captivate 6 is very ugly, so is the Cp icon.
Beauty is in the eye of the beholder...so is ugliness.
Someone must have liked them. I notice that similar logos are being rolled out for a lot of CS6 apps.
I agree about the ugliness of the Captivate icon, it is indeed similar to other Adobe applications but some of them are looking much better:
This looks much better than the Captiave 6 launch screen.
Hi There,
As Rodward mentioned, this tool is only available only in eLearning suite, it is not a part of standalone captivate.
Regards
Priyank
We own multiple licenses of the Technical Communications Suite, which includes Captivate. For some reason we cannot fathom Multi-Sco packager is disabled. Seriously? As if users of the e-Learning Suite are the only users who could possibly want to output multi-sco's. Come on Adobe.
Passing no judgement on whether this alignment was a good idea or not...do then consider the eLearning Suite for your next upgrade if the packager is indeed important. HOWEVER, be sure it is - it's a nice tool for easing the upload of many lessons into the LMS...but it does NOT automate Sequencing, which is the somewhat automatic transition between lessons based, as far as I know. It's simply a tool for bundling several separate SCORM packages into one .zip. For instance, in our LMS, uploading a SCORM package made with the Multi-SCO Packager saves time, but results in several separate lessons that have to be individually launched from the LMS anyway...
So you may not be missing out on much
NOW, having the Aggregator suppor Sequencing, THAT would be cool!
I've seen a preview of the SCORM Packager tool that will come with ELS 6 and it has vastly improved capabilities that can accommodate much more of the SCORM 2004 model.
Haven't had a chance to play with it as yet but it looks very promising.
Our issue is that we are not just an eLearning developer. We also produce long technical documents in FrameMaker, and electronic documents and help documents from RoboHelp. Tech Comm Suite is our best fit. eLearning Suite wouldn't be an upgrade for us.
I've also looked at the SCO packager in CP6 and it does look good. Sequencing and dependencies look great. TCS has Captivate. Multi-SCO packager is in the menu. It just not available because of the license structure. I see no technical reason why it isn't turned on in TCS. As if a TCS user would not want to produce Multi SCOs. That function is not worth acquiring ELS.
