Hi, I'm a newbie in Indesign SDK (CPP), and I have one problem in my code: I can't add two widgets on panel (StaticTextWidget), this following code is my problem:
resource BscPnlPanelWidget(kSDKDefPanelResourceID + index_enUS)
__FILE__, __LINE__, // Localization macro
kBscPnlPanelWidgetID, // WidgetID
kPMRsrcID_None, // RsrcID
kBindNone, // Binding (0=none)
0, 0, 207, 295, // Frame: left, top, right, bottom.
kTrue, kTrue, // Visible, Enabled
kFalse, // Erase background
kInterfacePaletteFill, // Erase to color
kFalse, // Draw dropshadow
kBscPnlPanelTitleKey, // Panel name
StaticTextWidget
0, // WidgetId (default=0)
kSysStaticTextPMRsrcId, // RsrcId
kBindNone, // Frame binding
5, 10, 202, 27, // Frame: left, top, right, bottom.
kAlignLeft, kEllipsizeEnd, kTrue, // Alignment, ellipsize style, convert ampersands
"Add tool", // Initial text.
0 // No associated widget
StaticTextWidget
10, // WidgetId (default=0)
5, 80, 202, 27, // Frame: left, top, right, bottom.
"Properties", // Initial text.
kBscPnlInternalPopupMenuNameKey // Popup menu name (internal)
How I can show all these widgets ?
In the second widget place the values of left, top, right bottom as 5, 80, 202, 97
If you still have problems you can use the "Panel Edit Mode" submenu under the "DevTools" menu of the debug version of your Indesign to allign your controls. Your problem seems to be that your controls are placed over each other. Try changing the placement and dimension of the widgets, your problem will solve out.
Manan Joshi
- Efficient InDesign Solutions -
MetaDesign Solutions
http://metadesignsolutions.com/services/indesign-development.php
North America
Asia Pacific
