mrmillersr
item in drop down menu does not show up when I print
Jun 22, 2012 3:14 AM
Created an interactive form that has a drop down menu to selec US state.  Problem is the state selected does not show up when the form is printed.  Instead the field is blank.  What do I need to do to correct this?
    Jun 22, 2012 1:42 PM   in reply to mrmillersr
    Is this the only field which does not print or is there just this one field. (When printing, toggle Document and Markups if there is only one field)
    It sounds like the properties for this one field are set not to print.
    Insepect the Field properties, or remove it and add it new.
    Jun 24, 2012 12:55 PM   in reply to mrmillersr
    I'm using AA 9, your menu's may vary.
    From the Forms menu, Add or Edit Fields
    The Fields pane should appear, right click the field and select Properties. An entry as shown would prevent the field from printing.
