OriiumtechUK
Combine files hangs on Terminal Server
Jun 22, 2012 6:26 AM
Tags: #windows #combine #convert #hanging #terminal_server #2008 #r2
Hello
We are having an issue with Acrobat Pro (versions 10 and 9) running on a Windows Server 2008 R2 Terminal Server used by approximately 30 users. The application is installed as a terminal server application.
When we use the combine files feature it converts the first document then seems to just hang - it doesn't matter how big the original file was (anything from 50k to 2mb) or the file type. It does create the PDF but only puts in the first document it converted - nothing else.
We've tried both version 9 and version 10 with no improvement.
On version 10 if we run it in administartor mode it doesn't have this problem. (Version 9 hangs whether it's run as administrator or not). For security reasons we can not (under any circumstances) make our users administrators.
It's critical we get this working as this feature is extremely important.
Has anyone had any experience with this before or know of a way we can get this working?
Appreciate any help that can be provided.
Kind Regards
Andy
    Jun 25, 2012 12:08 PM   in reply to OriiumtechUK
    Since you have posted your process here, you may want to go back and check your license and the number you have purchased. Normally, Acrobat is not allowed on a server as a server application. You may have a version that is so licensed. If not, you should check your license carefully and adjust your installations accordingly. There are volume licenses, but on the surface it does not sound like you are using one.
    Jun 26, 2012 5:23 AM   in reply to OriiumtechUK
    Thanks for the information. I am glad you checked the license issue and have more importantly found the problem. It seems that plug-ins are often a problem and finding them typically means disabling them and bringing them back one at a time. Glad your problem is resolved -- I had seen the other post.
