Problem with <cfqueryparam null="#ListFindNoCase('NULL',argument.name)#">
Jun 22, 2012 8:49 AM
This is my query i'm doing here:
         SELECT *
         FROM DB_NAME
         WHERE 0=0
            <cfif arguments.NAME is not ''>
               AND NAME_FIELD = <cfqueryparam value="#arguments.NAME#"  null='#ListFindNoCase("NULL",arguments.NAME)#'/>
            </cfif>
      </cfquery>
The resulting query ends up being
SELECT *
FROM DB_NAME
WHERE 0=0
AND NAME_FIELD = ''
instead of being
SELECT *
FROM DB_NAME
WHERE 0=0
AND NAME_FIELD is NULL
I am currently working in Coldfusion 9.
    Jun 22, 2012 9:45 AM   in reply to Khovel
    What was the value of argument.name?  What does the listfindnocase function return for that value?
    Jun 22, 2012 11:59 AM   in reply to Khovel
    Why not just do <cfif arguments.name IS "NULL">IS NULL<cfelse> = <cfqueryparam value="#arguments.name#"></ciff>
    Also ListFindNoCase is probably not the correct function to use here, that is for dealing with lists, FindNoCase would be more appropriate... but that too may have an issue if the persons name is Nully it would still match.
    Jun 29, 2012 4:40 AM   in reply to Khovel
    Jun 29, 2012 5:27 AM   in reply to Khovel
    I get the advertised results when I use the null attribute.  What did you do to arrive at the following conclusion?
    It ends up being
    AND NAME_FIELD = ''
    Jun 30, 2012 12:17 AM   in reply to Khovel
    Hi Khovel,
    Just to Confirm: You want to insert NULL values in some database fields by your condition checking.
    If it is the case then use YesNoFormat() function of ColdFusion to do so. Which was described in the above blog post.
    Jun 30, 2012 12:34 AM   in reply to Upen@Roul
    Your blog post is correct except for the need for yesNoFormat(), which is unnecessary in your example, and not really what yesNoFormat() is intended for (it's for formatting boolean values for output).  I tried to add a comment to your blog to that effect, but it didn't seem to show up (maybe you need to moderate it first?)
    Adam
    Jun 30, 2012 5:39 AM   in reply to Khovel
    Khovel wrote:
    I ended up doing a <cfif> to solve for this.
    But doesn't that defeat the purpose of using the null tag in cfqueryparam?
    Also, it shouldn't matter what i use as a conditional case to make this work.
    You could make the logic tighter without cfif. I was thinking of something like
    <cfset isArgNameBlank = trim(arguments.NAME) is ''>
    <cfquery>
    SELECT *
    FROM DB_NAME
    WHERE NAME_FIELD = <cfqueryparam value="#arguments.NAME#"  null='#isArgNameBlank#'/>
    </cfquery>
    Jun 30, 2012 3:25 PM   in reply to Khovel
    SELECT *
    FROM DB_NAME
    WHERE 0=0
    AND NAME_FIELD = ''
    instead of being
    SELECT *
    FROM DB_NAME
    WHERE 0=0
    Hi Khovel,
    If you enable profiling in your database server, I believe you will find it actually becomes:
    SELECT *
    FROM DB_NAME
    WHERE 0=0
    AND NAME_FIELD = NULL
    And 0 rows will be selected. (tested w/ CF10 and MSSQL Server 2008 R2)  B/c, in a SELECT, cfqueryparam's null="1|yes|true" replaces the cfqueryparam tag w/ NULL and the '=' is not changed to 'IS'.
    If you are cfdumping cfquery's result (ex: <cfquery result="r") struct, CF displays NULL sqlParameters as [empty string].  Best to enable profiling in the db server, to see what is actually sent.
    -Aaron
    Jun 30, 2012 3:53 PM   in reply to itisdesign
    Except w/in a QoQ, which disallows this.  Examples (CF10 syntax):
    Example 1:
    <cfset q = queryNew("col1,col2", "integer,varchar", [[1,''],[2,javaCast("null", "")]]) />
    <cfquery name="q" dbtype="query">
    SELECT * FROM q WHERE col2 = NULL
    </cfquery>
    <cfdump var="#q#" />
    Example 2: replace '= NULL' w/ '<cfqueryparam null="1" value="ignored" />'
    Example 3: replace '= NULL' w/ '<cfqueryparam null="0" value="#javaCast('null', '')#" />'
    All throw:
    Query Of Queries syntax error.
      Encountered "col2 = NULL.  Incorrect conditional expression,  Expected one of [like|null|between|in|comparison] condition,
    -Aaron
    Jun 30, 2012 7:12 PM   in reply to itisdesign
    Regarding
    All throw:
    Of course it throws an error.  It's "is null" not "= null".
    Jun 30, 2012 7:52 PM   in reply to Dan Bracuk
    Dan Bracuk wrote:
    Regarding
    All throw:
    Hi Dan,
    Exactly.  And '= NULL' is what his code boils down to.  I was just explaining to him that it returns 0 rows, instead of an exception, in a non-QoQ query.
    -Aaron
    Message was edited by: itisdesign
